Powerlabs guys - emissions
Old Apr 26, 2011 | 10:32 AM
UMW350Z's Avatar
UMW350Z
Default Powerlabs guys - emissions
Those who have PL set-ups (maybe other setups). How do you get your cars through emissions inspections with OBD2? I run a Haltech with Osiris and the O2 sensors and Evap system won't ready. It keeps the CEL off, but it won't reset and I have well over 3,000 miles. Also, since these don't ready, does this affect anything else in the performance?
How do you guys get through emissions or do you even try?
thanks
Old Apr 26, 2011 | 10:56 AM
str8dum1's Avatar
str8dum1
you shouldnt have an evap code, unless you removed something. have you tried non-foulers?
Old Apr 26, 2011 | 11:03 AM
UMW350Z's Avatar
UMW350Z
I think something is disabled via the Osiris or haltech to make the Evap not ready, maybe the 02 sensors as well...no code shows...is this possible for either to manually override the system from readying? My system is semi-abnormal due to the Vibrant cat welded into the downpipe. it never even threw an O2 code with the UTEC in it, only a/f bank sensor codes prior to the haltech/osiris install. I'm worndering if I took it to a Haltech expert, they could turn the readyness back on, if that makes sense.
Old Apr 26, 2011 | 11:05 AM
UMW350Z's Avatar
UMW350Z
I will try uninstalling my 6mt and put in an AT to see if it clears the 02 codes
Old Apr 26, 2011 | 01:03 PM
str8dum1's Avatar
str8dum1
you have to get reflashed to turn everything back on.
Old Apr 26, 2011 | 01:39 PM
bluelineshooter's Avatar
bluelineshooter
Hmmm ... sounds like you need to just cut your losses and get a GT-R
Old Apr 26, 2011 | 01:56 PM
UMW350Z's Avatar
UMW350Z
30k for my car and sold
Old May 1, 2011 | 06:32 AM
UMW350Z's Avatar
UMW350Z
Has anyone heard of a patch for the Haltech which makes the sensors always read 'ready'? I heard this exists for some Evo's, but I am not sure if it is rumor or fact.
Old May 1, 2011 | 06:41 AM
rcdash's Avatar
rcdash
Even with everything enabled I have never gotten my EVAP SRT to show ready. ....
Old May 1, 2011 | 08:37 AM
BlinkerFluid's Avatar
BlinkerFluid
I have also NEVER been able to get my EVAP rediness flag set, with all equipment installed and Osiris.
I have been able to get it to set all the others though so it pases in PA with 1 flag not set.
Old May 1, 2011 | 10:43 AM
UMW350Z's Avatar
UMW350Z
Interesting...I'm getting a new laptop in 2 weeks and I'm going to install the Haltech software on it so i can mess with the readyness.
RC, I may need more detailed information once I find out if I can have 1 'not ready' in NJ. Otherwise it might be time for a 'move' back to VA or PA.
Old May 1, 2011 | 10:45 AM
JET MECH's Avatar
JET MECH
Part of the reason i still have my trusty U-TECH. Have never had a problem passing smog here in vegas and no nuisance CEL'S either.
Old May 1, 2011 | 06:14 PM
UMW350Z's Avatar
UMW350Z
I have to say, despite the emissions headaches, good fuggin riddance to the UTEC. Maybe it was the tune in it, but it surged, bucked, hot-'started'....absolute POS.
Old May 2, 2011 | 07:01 AM
IIQuickSilverII's Avatar
IIQuickSilverII
werd..utec was never meant to be be used for a "stock like" performance...not sure mine was as bad as you describe it, but it was always something to just get things running and then upgrade later on.
either way, hope you get the emissions issue resolved man, not much i can say since i dont have to worry about it where i live.
Old May 2, 2011 | 07:57 AM
psychoballistic's Avatar
psychoballistic
Talking
I just did this in NY in the past two weeks... Had my stock ecu reflashed, which is necessary if you still have a stock ecu most of the times where emissions and readiness monitors are part of the inspection.
Long story short, I went to Performance Motorsports East in Long Island after speaking with the guys at Uprev. They shut all the readiness monitors off the Read "Not Supported" this is what is necessary cars on inspection with OBDII in NY. NJ is almost an identical inspection I beleive. I put my stock ecu back in my car yesterday, went down to my shop, cleared my system of any codes, and then plugged my OBDII inspection computer into my car, and it passed with ZERO issues. In NY it is an extremely difficult process to pass emissions inspection, the reflash made it extremely easy for me.
I have attached a copy of the readiniess monitor screen that the OBDII looks at when doing an OBD emissions inspection. In the photo there are two monitors that are "not ready" I sent my ecu back with this photo and Performance Motorsports was able to flash the ecu for those two specific monitors, got it back and everything was perfect. +1 to Andrew for getting it overnighted back to me too. I would suggest them since they aren't far and have done this now, and it worked out awesome. No more screwing around TRYING to pass on the inspection.
Attached Thumbnails Powerlabs guys - emissions-vq35de-inspection-computer.jpg
Old May 2, 2011 | 09:01 AM
str8dum1's Avatar
str8dum1
so you can reflash to make the sensor "not supported" instead of "test not complete"
wonder why this hasnt been promoted before, as we all need this functionality!!
Old May 2, 2011 | 09:58 AM
rcdash's Avatar
rcdash
So you didn't even have to go through some drive cycles after you cleared codes?
Old May 2, 2011 | 03:38 PM
Lightning Guy's Avatar
Lightning Guy
Are your rear O2s cycling?
The entire nissan drive cycle is pretty intense for all of the readiness codes to go ready.
The EVAP and O2s make me think that there is something prior to them not going ready and hindering going forward in the drive test.
My recommendation, take it a Z shop that knows their stuff. A dealership most likely wont be any help. I can try to find the drive cycle test, but I won't be home until the weekend.
Performance motorsport, vinny ten, RTT, come to mind in your area
Old May 3, 2011 | 03:24 AM
psychoballistic
I do not have to go through any drive cycles now. I actually had a misfire code because i'm running extremely rich at the moment. I cleared the codes, and all my readiniess monitors read "not supported"... In NY that will allow you to pass inspection, and sure enough I had no problems.
I personally used performance motorsport and was extremely happy. 2+ years of fighting inspection is over.
Old May 3, 2011 | 03:29 AM
psychoballistic
Not to mention, I also had my throttle access set to 100% instead of the dialed down setting that comes stock (whatever that percentage actually is) and in doing this my limp mode issue with my Utec went away, no more apps sensor issue, sucks to find it out now right before getting ready to install my 128 box. Lots of benefits from the Uprev software I am seeing.
