Vortech kit instal question
Old May 2, 2011 | 04:47 PM
JustAnotherZ's Avatar
JustAnotherZ
Default Vortech kit instal question
Had my kit installed by a local guy, well he didnt hook up a line, not sure what it goes to hoping someone can help, also he didnt run the vacume for the bov if someone can post a pic of how they ran their line. Thanks
Old May 2, 2011 | 04:51 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
wow.
Wonder where else he cut corners?
Those worm gear clamps look like they are the wrong size, coupler is not oem vortech.
That hose should have been extended and run to the breather port on the vortech filter.
You dont have a BOV on the vortech, you have a BPV. T off the vacuum line on the front of the plenum.
Old May 2, 2011 | 06:01 PM
JustAnotherZ
Originally Posted by Cux350z
wow.
We were missing oem couplings and intake elbow, I have the correct ones on it now. So extend that line to breather? I do have a bov, just not line hooked up to it. Thanks for your help
Old May 2, 2011 | 06:31 PM
suprasam's Avatar
suprasam
That line is coming from the back of the valve cover to vent the crankcase pressure. Usually it runs into the intake, but FI guys usually run it to an oil catch can.
Old May 2, 2011 | 07:00 PM
chrisjersey06's Avatar
chrisjersey06
I just stuck a little ricer breather filter on it when I ditched the standard filter for a custom cold air setup. Just do that or run it to a catch can like what was said above.
Old May 2, 2011 | 07:10 PM
suprasam's Avatar
suprasam
I tried a breather filter, but I spewed oil everywhere. had to run a catch can. but either way will serve it's purpose to vent the gases.
Old May 2, 2011 | 09:23 PM
chrisjersey06
I would look into why that's happening. Sounds like you have an excess of crankcase pressure that's pushing oil out. The filter on mine is as dry as the day it went on.
Old May 2, 2011 | 11:50 PM
maXmood's Avatar
maXmood
Under Boost!
+1 ...
Old May 3, 2011 | 04:53 AM
suprasam's Avatar
suprasam
I know a few of us built FI guys have varying issues with crankcase pressure. There was a whole thread on how to vent it, which is why I have a filter there and on the pcv.
BEBO'S ZEE
Jun 7, 2016 07:48 AM
Juztin
Nov 22, 2015 07:03 AM
Bodyboarder81
Nov 2, 2015 12:17 AM
Calinismo350z
Sep 14, 2015 04:04 PM
juang20
Intake
Sep 7, 2015 05:37 PM
