How long/miles on a TT.
Old May 17, 2011 | 09:03 AM
draft's Avatar
draft
Default How long/miles on a TT.
So I’m just kicking around adding TT system.
How long or is there a mileage you guys see were things just need replacement or wear out.
I understand this question is based on the build, tune quality boost your running.
Old May 17, 2011 | 09:08 AM
dikspiel's Avatar
dikspiel
Chestons Toilet
Old May 17, 2011 | 09:13 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Old May 17, 2011 | 09:14 AM
IslandZavage's Avatar
IslandZavage
Try and use the search function. This has been discussed before so you will find your answer if you search. Use search and you'll last a lot longer.
As you said yourself that you know it depends on tune and build, so the answer you get will be different ....
Old May 17, 2011 | 09:21 AM
red350track's Avatar
red350track
The major factors are basically what you listed.... who tuned it, Build quality, how hard its run, and how often its run hard.
Alberto's Avatar
Alberto
Cranky FI Owner
Unbelievable this same question gets asked every month it seems.
Old May 17, 2011 | 09:26 AM
djamps's Avatar
djamps
Anywhere from 0 to 150,000 miles.
Frosty87's Avatar
Frosty87
I hate how everyone is thinking of throwing a turbo on their car ..first its not cheap in the first place second you must realize the car isn't made to handle fi so your motor could go at any time. Add power = less reliable
Old May 17, 2011 | 09:31 AM
draft's Avatar
draft
Default search !
Search NICE!
Old May 17, 2011 | 11:04 AM
rh_334's Avatar
rh_334
Old May 17, 2011 | 11:08 AM
60053man's Avatar
60053man
In...
Old May 17, 2011 | 11:35 AM
ImWeeZzel's Avatar
ImWeeZzel
Old May 17, 2011 | 12:05 PM
chaparro78's Avatar
chaparro78
you guys are ruthless
just depends man. even if everything goes right, it could go boom tomorrow because of one weak link. the risk you take when going FI. I have over 100k miles on my SC but i am not pushing the numbers some people on here are. The more you push it, the more risk you have in making pretty white smoke
Old May 17, 2011 | 12:06 PM
RudeG_v2.0's Avatar
RudeG_v2.0
でたらめ検出器
Old May 17, 2011 | 12:17 PM
RudeG_v2.0's Avatar
RudeG_v2.0
でたらめ検出器
Hmmm... Maybe it's time for a new video Alberto.
Old May 17, 2011 | 12:33 PM
chrisjersey06's Avatar
chrisjersey06
Your best bet is to find one of the reputable shop sponsors on here and give them a blank check to TT your car. Not the cheapest route, but it will most likely be a very reliable setup.
Also keep in mind that SC setups are generally the more reliable option, but you will sacrifice some power and more torque.
Old May 17, 2011 | 01:41 PM
going deep
FI FAQ's
181
Jan 28, 2008 01:05 PM
Bat
May 19, 2005 02:15 PM
Gman2004
Mar 25, 2005 12:07 PM
