FI 3.5 to 3.3 FD comparison question
Old May 18, 2023 | 06:43 PM
DarkZ03's Avatar
DarkZ03
Wheel size is irrelevant if the proper TIRE size is chosen.
Old May 18, 2023 | 09:32 PM
VQplatform's Avatar
VQplatform
Hi I am not quite sure what the relationship is between tire size and RPM at a given speed. Are you talking about the height of the tire wall?
Old May 19, 2023 | 12:52 AM
DarkZ03's Avatar
DarkZ03
Yes, a 26" tire will still be a 26" tire, whether it's on 18s, 19s or 20s. That is THE only thing that will change the interaction between RPM and gearing.
Old May 19, 2023 | 06:49 AM
i8acobra's Avatar
i8acobra
With boost, you want to go down with gearing, not up. The car makes enough torque with boost that going to a numerically lower gearing actually improves acceleration, by increasing the speed before the next gear. By holding first and second gears longer before the shift to third, acceleration is improved.
Old May 19, 2023 | 10:24 AM
VQplatform's Avatar
VQplatform
Wow I didnt realize that the stock configuration for the 350z was 255/45 rear tires which changes everything, thank you! 🙏
Wouldn't the higher gears feel more sluggish as others prior have stated unless you are running boost on a built block?
3.3 FD for 440whp? - MY350Z.COM - Nissan 350Z and 370Z Forum Discussion
Old May 19, 2023 | 05:03 PM
i8acobra's Avatar
i8acobra
That would be why I said, "with boost".
Sirk17
Jan 4, 2011 04:25 AM
4drmadness
NA Builds
Jun 8, 2009 08:43 PM
bovi
Dec 23, 2008 11:48 AM
dannyboi2088
Jul 24, 2006 04:48 PM
