Questions/ thoughts on upgrading 18g's v.s BW EFR's
Old Jul 26, 2011 | 07:46 AM
psychoballistic's Avatar
psychoballistic
Default Questions/ thoughts on upgrading 18g's v.s BW EFR's
I’m starting to do some homework on upgrading my 18g Greddy kit, and have been looking into the borgwarner turbo systems… Granted the common change I have seen is twin 6265 or a set of the garret systems.
I’m looking at two things, one is the EFR turbos from Borgwarner, where if it makes sense, I would retain all the Greddy piping and fabricate new flanges to match things up. That would be option A, and it would allow me to get rid of the wastegate and dump tubes as everything would be part of the turbo assembly.
The second thought I have is just upgrading the turbos through forced performance and doing the 18g upgrade to the comparable 20g specs. That would be option B. Would it make more sense to just get 20g’s or do the upgrade? What kind of difference will there realistically be with an 18g upgrade v.s the 18g’s I currently run?
I know the Borgwarner is the best way in the end to go, but will my piping be too restrictive to flow such a setup… I wouldn’t be going too much larger in size for the turbo as the power band in the 18’s is instant and strong throughout the entire rpm range.
What are some thoughts on this? Is it even worth doing? Anyone have any experience with the Borgwarners on the Z platform?
Thanks guys for the input in advance.
Old Jul 26, 2011 | 08:26 AM
str8dum1's Avatar
str8dum1
the greddy housings are physically tiny while the BWs are huge.
YOu are going to be limited by the space off those manifolds. The headaches associated with trying to mount anything besides a greddy turbo there will be enormous.
If you want bigger, non-greddy turbos, get a different turbo kit. Also, you'd have to go with something quite a bit bigger (ie alot laggier) to make #'s that were significantly different enough to justify the cost.
Old Jul 26, 2011 | 08:35 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Talk to Ray about it and go make power.
The clowns on this site haven't figured out how to make good power on 18G's in 8yrs, and you are asking them about 20G's and/or more power?
Old Jul 26, 2011 | 09:33 AM
psychoballistic
I hear what your saying Bert, and Ray and I have spoken about the EFR's, and he says to go for it if I have the means of doing so, but I haven't seen a VQ setup running one yet. I'm curious to say the least at the moment.
Old Jul 26, 2011 | 10:14 AM
usingthejohn's Avatar
usingthejohn
Kinda OT, but what's a good shop to get 18g's rebuilt here on the west coast? My turbos have some shaft play to go along with it's cracked manifolds.
Old Jul 26, 2011 | 10:53 AM
str8dum1's Avatar
str8dum1
heres a thread with some info on the 6258 which is about the size EFR you'd be using
http://www.supraforums.com/forum/sho...e-and-personal
But the supra guys really arent using these yet, and they are early adopters, so you wont find any VQ specific data
Old Jul 26, 2011 | 11:54 AM
psychoballistic
That's actually the exact thread that got me thinking about doing this... When I saw that, I started researching the BW's and was just curious if anyone had any experience on this forum... Thanks for posting that up Rich.
Old Jul 26, 2011 | 12:25 PM
midz350's Avatar
midz350
Do you have a xxxwhp target in mind?
Old Jul 26, 2011 | 12:45 PM
psychoballistic
Honestly i'm a little under 700 now, and would like to get closer to 800 as i'm looking to drag it more... I'd like to flow more volume while retaining an aggressive power band similiar to that of which I have now. When I put it to the floor, there is ZERO lag, it just rockets, and I want to retain that, hence the BW potential, but I may getting to far out there for what has been accomplished thus far.
Maybe some of the shops could chime in if they have dealt with BW's at all?
Justin100
Nov 25, 2021 06:26 AM
apex locator
Jul 23, 2021 02:27 AM
