My Vortech Build
Old Nov 20, 2011 | 06:00 PM
  #61
- bigc -'s Avatar
- bigc -
Originally Posted by bikinilust
Doesn't it say somewhere that the vortech system doesntt like aftermarket headers n hfc's/testpipes?
something about how it needs around stock backpressure???
Im just working off of memory, but im pretty sure that's what I read and heard...
Also, wonder if a vortech system would benefit from greater amounts of volume in the intake manifold?
I mean, a supercharger is creating positive pressure/force feeding the cylinders (cylinders not feeding themselves)...
where as a natural aspirated system relies of vacuum created by the cylinders and atmosperic pressure to feed the cylinders..
and on a na system having a spacer/mrev2 lessens restrictions and allows the cylinder to breath more easily...
So would a spacer/mrev2 allow the supercharger to forcefeed the cylinders more easily?
also, and I might be wrong about this.... if a vortech system does improve w a spacer, wouldn't it have better results w say a 5/8" spacer and a mrev2 (on a nonrevup) compared to just a 5/16" And a reg nonrevup lower plenum?
you should check out the vortech faq
https://my350z.com/forum/forced-indu...questions.html
Old Nov 21, 2011 | 03:22 AM
  #62
brandon7219's Avatar
brandon7219
been a subscriber to this thread for a while, definitely can not wait to hear the numbers man!
Old Nov 21, 2011 | 03:27 AM
  #63
ESP350Z's Avatar
ESP350Z
Gauge pod looks great. I had Rob put some stri gauges in my Z a few months back and they did a cleeeeean job. Your car is going to be very quick when you get it back Its not even my ride and I cant wait to read about it
Old Nov 22, 2011 | 03:54 PM
  #64
unvmyg35's Avatar
unvmyg35
Thanks Looks like im going to wait another week.
I went to ZCG today to drop off a 350z carbon fiber engine cover. Rob showed me the other set up for the edfc controller, oil pressure, and A/F gauge in the upper compartment box and looks ****. But, I forgot to take a picture to post.
I should see my car mid-week of next pending no issue with the tune, crossing fingers. I will continue to keep you all posted!
ZCG had been amazing thus far! They have been keeping up with my everyday add-ons and changes throughout the build. Hence it’s taking longer than expected. I keep throwing ***** at them! Lol
Old Dec 2, 2011 | 12:38 PM
  #65
the3kgt2's Avatar
the3kgt2
Updates?
Old Dec 2, 2011 | 04:56 PM
  #66
unvmyg35's Avatar
unvmyg35
Delayed into next week.
1st issue: The Tein coilover/edfc system I purchased from another member (won't discuss name at this time, giving the member a chance to rectify). The edfc was bad, it powered on but the display wasn't working so I had to order a new one. Edfc replaced and suspension all good now.
2nd issue: One injector was bad, Injector Dynamics shipped a new batch of injectors. All good now.
Started to tune yesterday and came to find out Rob installed a 2.87 pulley and it boosted to fast/high. Rob had to pull alot of timing and didn’t like the way it felt. I agree with him that the 2.87 is too much for my stock block. Keep in mind I’m running an SI trim. It was my bad for not being specific (I thought I was, guess not) when I told him I wanted to go with a smaller pulley. Ordered 3.12 today and will be here Monday.
This is where I decided to install the EDFC, Oil Pressure, and A/F gauges.
Old Dec 2, 2011 | 05:06 PM
  #67
the3kgt2's Avatar
the3kgt2
Hopefully Rob can get you all squared away. Small things like that are bound to happen on such a big build.
Rob finished my car today...had everything installed and tuned. Dyno numbers are in. He took it out to get it washed before I picked it up and the rear differential/subframe bolt snapped and my pumpkin fell out Landed on my exhaust, dented it, and now I have to overnight another diff carrier bushing. So close to getting my car back!
Old Dec 2, 2011 | 05:22 PM
  #68
gabe3d's Avatar
gabe3d
Doh x 2
Old Dec 2, 2011 | 06:55 PM
  #69
unvmyg35's Avatar
unvmyg35
Ouch! Hopefully you are up and running in no time. Can you post up your new dyno sheet?
Im not really tripping off the car being delayed. What's several more days, lol.
Old Dec 2, 2011 | 08:08 PM
  #70
- bigc -'s Avatar
- bigc -
well, at least all of our cars are keeping each other company
Old Dec 2, 2011 | 08:11 PM
  #71
gabe3d's Avatar
gabe3d
^your car is there too? is this about the new intercooler you were talking about?
Old Dec 2, 2011 | 08:18 PM
  #72
- bigc -'s Avatar
- bigc -
yeah, i dropped it off on monday morning. rob is installing momentum headers, ART test pipes, fluidampr crank pulley (should increase the supercharger's impeller speed to where it was with the 2.87 pulley ), swapping out my Fuji catback for a FI catback, and retuning. i've also asked him to check on a few odds and ends as well. they've been backed up for a while now, so i'm glad he was able finally able to fit me in.
Old Dec 3, 2011 | 04:21 AM
  #73
unvmyg35's Avatar
unvmyg35
That's for sure!
Old Dec 5, 2011 | 06:58 PM
  #74
unvmyg35's Avatar
unvmyg35
Another delay today. Throttle Body gave out. Rob tested it twice and recv'd the same code. He ordered a new unit and has been installed. The 3.12 pulley came in and has also been installed. Rob ran out of time for tuning. Hopefully no more issue will come up during tuning tomorrow. Update to follow.....
Old Dec 6, 2011 | 06:50 AM
  #75
str8dum1's Avatar
str8dum1
what was the code you guys saw?
Old Dec 6, 2011 | 03:05 PM
  #76
unvmyg35's Avatar
unvmyg35
He said it was sticking, and kept closing slightly in the higher rpm and the engine would stall. Then it went into a fault code and the throttle would not react. This happened twice same code. At this point, I just said go ahead and replace the unit. I didn't even bother to ask for the code but will once the car is ready.
Old Dec 6, 2011 | 03:34 PM
  #77
str8dum1's Avatar
str8dum1
i've had my share of TB issues and always interested to see what other had and their solution. I am assuming with the new TB its all 100% now?
Old Dec 6, 2011 | 03:35 PM
  #78
Classy's Avatar
Classy
TB and maf issues plagued me on my G35, so far so good on the 350z, I am excited to see how your car turns out
Old Dec 6, 2011 | 03:58 PM
  #79
str8dum1's Avatar
str8dum1
mt TB seems to keep losing its calibration. It will show 2-3 %tps at idle which f's with my adaptive idle setpoint. I do the TB foot pedal reset and it goes back to 0% tps at idle like expected. Not much of an issue know that I know whats going on, but its in teh bucket list to fix somehow.
Old Dec 6, 2011 | 04:00 PM
  #80
unvmyg35's Avatar
unvmyg35
Just got the phone call that made me get wet!
TB issues are all gone now. Car is tuned and ready for pick up. We didnt discuss anything more, I want it to be a surprise tomorrow.
