My Momentum ST build
Old Dec 19, 2011 | 12:12 PM
G3po's Avatar
G3po
Default My Momentum ST build
My G build has just posted on Zcarblog.
I don't think i'ts mentioned , but tuned for 91 (built 9:1 LongBlock).
Gotta alot left in it , but plenty for the moment.
It's a DD so it's as stealth as possible.
Fitment was really tight but spot on.
Not mentioned the exhaust is a modified Stillen TD setup.
reverse-y , Hi-flow Cats where the resonators once where.
Lots of pics can be found here.
http://www.zcarblog.com/
Old Dec 19, 2011 | 12:42 PM
konrad's Avatar
konrad
Good numbers for a daily driver
Old Dec 19, 2011 | 03:51 PM
TRYNALIVEPRO's Avatar
TRYNALIVEPRO
nice sleeper, congrats
Old Dec 19, 2011 | 04:23 PM
robertgtz's Avatar
robertgtz
Default WT..........
no pistons, valves, can you post more info and how much you spen and parts.
Old Dec 19, 2011 | 04:32 PM
unvmyg35's Avatar
unvmyg35
I'd hate to run into you on 101! Congrats!!
Old Dec 19, 2011 | 05:00 PM
ImWeeZzel's Avatar
ImWeeZzel
pics of ride?
Old Dec 19, 2011 | 05:50 PM
unvmyg35's Avatar
unvmyg35
Originally Posted by ImWeeZzel
pics of ride?
OP provided link.. check it out.
Old Dec 20, 2011 | 11:55 AM
G3po's Avatar
G3po
Parts:
Wiseco pistons (9:1)
GTM® rods
Rear main seal assembly
GTM® Race bearings
ARP® 8740 main studs
ARP® L19 head studs (torqued to 95ft. lbs.)
HR head gaskets
OEM valve stem seals
OEM valves , mild port/polish job
OEM Rev-Up Oil Pump
Stillen lower oil pan + fumoto valve
Stillen Torque dampener
Mocal T-stat and custom twin oil coolers. Oil warmer removed.
JWT valve springs
OEM retainers, locators, and keepers
OEM Engine Gasket Set
Polished plenum and spacer
Iridiums one step cooler
Powder coated timing cover and water hard pipes
GTM Stage 1 turbo Cams
Note the Cams are very mild , my intent was to make great mid range power with a smooth idle. This G is a 99% DD and a 1% Weekend warrior.
MTM headers, GT35R Kit (cold side polished) , all hot parts ceramic coated, 600cc DWs , DW300 pump, GT MAF and Uprev . IC coated with Black Thermal Dispersant.
Part costs on top of the OEM roller:
North of $20k
...including JWT 50/50 clutch + fly , ST brakes , HKS coilovers , DS half shafts, Quaife LSD....Profec B., Innovate WB..Six old school Defi-D gauges etc.
Old Dec 20, 2011 | 01:40 PM
ace32x's Avatar
ace32x
Originally Posted by G3po
Parts:
GTM® rods (with their alignment and resizing)
GTM® Race bearings (OEM bearings available)
HR head gaskets
New OEM valve stem seals
OEM valves
OEM Rev-Up Oil Pump
OEM Oil pick up screen
OEM Camshaft Bolt seals
JWT valve springs
North of $18k including JWT 50/50 clutch + fly , ST brakes , HKS coilovers , DS half shafts etc. Quaife LSD .
wow not a bad price for all of that
Old Dec 20, 2011 | 03:28 PM
G3po's Avatar
G3po
Shopped for deals for 4 years. Some parts such as coil-overs and ST brakes where second hand.
350Z_Al
Oct 29, 2020 07:44 PM
Justin100
Nov 29, 2015 03:58 PM
