VDC Slip, Now car won't Start
Old Dec 31, 2011 | 08:32 PM
OldManZ350's Avatar
OldManZ350
Default VDC Slip, Now car won't Start
Hay Guys,
Was out doing a Tuning Run Tonight. Did 2 Hard 3rd gear runs.
First Run with VDC ON, had to get in and out of the Throttle, major tire spin.
Second Run with VDC ON, eased on Throttle less tire spin, ran it to redline, got out of the throttle, VDC Light and Slip Light came on and Stayed on. Car was running like crap. Very Very Rich and Rough running, did not want to rev past 2000 rpm, so I pretty much just putted it home.
I shut the car off, checked codes and erased them. Of corse I did right them down....
Now, car fires then dies........
Nevermind, I Blow off the Intake...... Just didn't see it, Sorry
Any Ideas?
Old Dec 31, 2011 | 11:15 PM
- bigc -'s Avatar
- bigc -
sounds like you blew the welds on your intake...granny shifting, not double-clutching like you should...
Old Jan 1, 2012 | 12:18 PM
djamps's Avatar
djamps
What code?
Old Jan 1, 2012 | 12:51 PM
OldManZ350's Avatar
OldManZ350
Car is Fine Now......
I had Wheel Spin with VDC/ON, and at the same time I blow apart the Cloupling between the MAF and 45* elbow by TB....
It was Late, I was Tired and I Erased the Codes without remembering or writing them down....
I seams to me that VDC dose not work well under continous tire spin and WOT....
Originally Posted by djamps
What code?
Old Jan 1, 2012 | 12:54 PM
RetchedOne's Avatar
RetchedOne
My hung over mind took this as "dumb **** noob response..." then i realized you were kidding...
Old Jan 1, 2012 | 01:39 PM
binder's Avatar
binder
vdc hates all things. I disable it every time i get in the car.
Old Jan 1, 2012 | 02:44 PM
OldManZ350's Avatar
OldManZ350
Ya, I always have it OFF, but I had such extreme Tire Spin I thought I'd try it with it on. It does not work, like you said.... Thank God I'm 99% done with tuning....
Old Jan 1, 2012 | 03:05 PM
binder's Avatar
binder
never say that! I wish i felt like there wasn't anything else i could improve on my tune. Seems like every day there is something i find that i need to improve on.
Old Jan 1, 2012 | 03:27 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
you have one of these or oem maf tube? If you have the oem maf tube you really should get rid of it.
https://my350z.com/forum/forced-indu...-and-tube.html
Old Jan 1, 2012 | 08:12 PM
- bigc -'s Avatar
- bigc -
i have to be careful with my e-sarcasm sometimes
Old Jan 1, 2012 | 08:47 PM
djamps's Avatar
djamps
Tuning is NEVER done LOL it can always be better. At least SC there is less to deal with tuning wise so you have that going.
Old Apr 17, 2012 | 02:56 PM
nnismo03's Avatar
nnismo03
Hey I'm now having the same problem to. Did you ever figure out what might be causing the malfunction. My car will not stay running now only if I push on the gas but is running like dog poo..
Old Apr 17, 2012 | 03:54 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
^read the blue text in the op
Old Apr 18, 2012 | 06:14 AM
TopgunZ's Avatar
TopgunZ
Theres a way to default the vdc to not turn on when your car starts. You can put a toggle switch in that when off will not allow it to come on when car is started. But if you want it on you can switch the toggle over, but you have to shut the car off first.
Jusy FYI if you werent aware of that already
Old Apr 18, 2012 | 06:29 AM
str8dum1's Avatar
str8dum1
just unplug the yaw sensor box. all the good ems's have traction control built in, so no need for redundancy.
Old Apr 18, 2012 | 07:03 AM
350z006's Avatar
350z006
Yeah this has happened to me before....totally thought I blew my engine lol!
aarrgghh
May 1, 2022 11:04 AM
NFAC
Sep 26, 2015 10:11 PM
RyansZ33
Sep 15, 2015 05:54 AM
Darkspy
Sep 7, 2015 09:09 PM
