Dynosty: Haltech 350Z Pro Plug-In - OEM ECU Replacement
Old 07-25-2016, 05:54 PM
  #361
rcdash
rcdash's Avatar
You can trigger different compensation maps based on any signal source, including one of the generics... so it is possible. Download the software and setup a CAN I/O Box to give you additional I/O lines and see how it works.
For example, you could use the VDC switch to trigger max psi. or to trigger a 2D fuel compensation map that you would manually select to get the C16 configuration. Same for ignition timing.
You can also load "maps" using a laptop of course.
Old 07-25-2016, 06:48 PM
  #362
dikspiel
Chestons Toilet
dikspiel's Avatar
Carputer would be another option
Old 07-26-2016, 08:50 AM
  #363
Dynosty
Vendor - Former Vendor
Dynosty's Avatar
Changing entire calibration does require a laptop to upload a new file... but you don't need to upload a new calibration to do what you want.
Boost and fuel/timing can be changed by adding layered maps based on an input. We commonly use a multiposition switch to do what you are requesting.
Originally Posted by 350z-900whp
Guys I need help on how to run multiple maps on haltech pro plug in harness. I know the ecu it self don't have this feature.
So my question is their any external product I can add to run multiple maps on fly for haltech?
Say I want to run map 1 : 15 psi , map2: 19psi , map 24+ psi on c16. Is it possible? Without going back to my laptop to load the map
Thanks
Old 07-29-2016, 05:53 PM
  #364
nomyth46
nomyth46's Avatar
oh snap....is Hal back on the forum???
Old 08-01-2016, 04:03 PM
  #365
jdm-v35
jdm-v35's Avatar
wish this system could pass emissions! if so it would definitely be on my list.
Old 08-29-2016, 02:45 PM
  #366
accordfreak
accordfreak's Avatar
any hackers on this forum?
Old 08-29-2016, 08:12 PM
  #367
MartinZ
MartinZ's Avatar
The HalTech has a lot of optional correction tables, you can control what triggers them
Setup/Advanced/Main:
Boost - Generic Correction Table
Fuel - Generic Correction 1 & 2 Tables
Ignition - Generic Correction 1 & 2 Tables
There is no reason why the HalTech can't be tuned to pass emissions - the tune will cost you money
It's more likely that vehicle modifications cause emissions problems
Old 08-31-2016, 05:09 PM
  #368
jdm-v35
jdm-v35's Avatar
problem is it wont pass OBD2 reader. Its not about throwing codes - it doesn't have readiness checks available to scan.
Old 08-31-2016, 06:09 PM
  #369
rcdash
rcdash's Avatar
^ Even if it had the capability, it would be completely illegal to do this so you are not going to read about it in a public forum. You do have options - just takes some research of your local codes and regulations.
aarrgghh
05-01-2022 11:04 AM
speedsniper
09-14-2015 08:46 AM
ThreeFiveZero Z
09-12-2015 04:33 PM
Quick Reply: Dynosty: Haltech 350Z Pro Plug-In - OEM ECU Replacement
