APS Twin Turbo, Water Lines
Old Mar 18, 2012 | 10:24 AM
FineWine's Avatar
FineWine
Default APS Twin Turbo, Water Lines
Hey Guys,
I'm trying to finsish off this ensanely elongated TT build. I'm having a little trouble figure out where the end of the water lines actually go. The diagram on the instructions has it bolting into something on the A/C Compressor. I can't really make sense of this, since it seems like the water line should feed into another water line somwhere in the circuit to complete the loop.
Either way, can someone snap a picture of where this hose should be connected?
http://www.airpowersystems.com/350z/...A_01-Water.pdf
Old Mar 18, 2012 | 11:31 AM
Glex25's Avatar
Glex25
The lines get connected on the passenger's side by the bleeder valve and on the driver side drain bolt which you need to remove and terminate the connection there. The drain bolt is on the block itself. If you look at the installation for the extreme kit it shows it more clearly.
Old Mar 18, 2012 | 11:56 AM
b18ccivics's Avatar
b18ccivics
glex25 is correct.
Old Mar 20, 2012 | 06:39 AM
FineWine's Avatar
FineWine
Got it, thanks guys. The confusion was mostly from having the wrong sized straight adapter on the line.
Old Mar 22, 2012 | 05:55 PM
FineWine's Avatar
FineWine
Alright one more question related to this. I had to order a new straight adapter for the drain plug because mine was missing. The APS inventory calls for a "9/16"JIC x 3/8"BSP", I ordered a -6 AN X 3/8" NPT straight adapter. It doesn't go in smoothly, but it's possible I need to chase the threads. I tried putting in the drain plug, and it's got some hesitation as well (thought it feels more natural).
Can anyone verify that I have the correct size straight adapter in the mean time?
Old Mar 23, 2012 | 06:56 AM
str8dum1's Avatar
str8dum1
BSP is not NPT.
so no, you do not have the correct adapter.
Old Mar 23, 2012 | 07:53 AM
jerryd87's Avatar
jerryd87
damn britts always being different why cant they adopt to the american way already =P
Old Mar 23, 2012 | 10:17 AM
FineWine's Avatar
FineWine
Sigh, why british threads :-/
Trying to track down a 9/16 jic to 3/8 BSP straight adaptor now. If anyone can help me out, I'd appreciate it.
Old Mar 23, 2012 | 10:21 AM
Glex25's Avatar
Glex25
You can just make your own water lines if you can't find the adapter just make sure whatever adapter you get is the correct thread for the block and turbo
str8dum1's Avatar
str8dum1
https://www.pegasusautoracing.com/pr...p?Product=3230
that will be 100 internet credits please
Old Mar 23, 2012 | 12:46 PM
FineWine's Avatar
FineWine
Thanks man! I actually ended up finding the part at a local industrial supply shop. I'm keeping that link for sure, though.
Old Apr 13, 2012 | 08:12 AM
trapt350z's Avatar
trapt350z
i can't seem to find replacement oil and coolant lines for the aps kit because of the weird fittings, can anyone help me out? two of the lines frayed holes in them
edit: that sight finewine posted, may have helped...so if the fitting is 9/16 jic, a 6AN line will fit?
350z82
Oct 1, 2015 06:25 PM
