05 5AT build(newb)
Old Apr 11, 2012 | 05:07 PM
Pastmylife357's Avatar
Pastmylife357
Default 05 5AT build(newb)
So before I start I've read tons of forums and other sites for information on what I'm trying to do as cars and upgrades are a fairly new interest of mine.
Goal: about 350-400 whp future: 500's whp
EDIT: ALL NEW BUILD LIST
GTM motorsports stage 2 tuner kit (GT28RS .86A/R)
Fuel:
CJ motorsports stage 2 fuel kit
DW 850cc injectors
DW 300LPH Fuel PUmp
Exhaust:
Amuse R1 Titan exhaust
Motordyne ART test pipes
Motordyne XYZ pipe w/ HFC
EMS:
Haltech Platinum
Haltech boost control solenoid
Transmission:
IPT performance upgrades
Cooling:
B&M hi-tek trans cooler
Weapon R Neo-Ti secret weapon intake system
Setrab oil cooler
ARC oil catch can
Samco radiator hoses
NGK 1step colder spark plugs
Suspension:
Nismo S-Tune stabilizer kit
Other:
Billion racing power steering tank
Works bell paddle shifter neo
Goodridge g-stop brake lines
Engine:
CP pistons 8.5:1 CR, 96mm bore w/rings
Carrillo Super Pro-A Rods
ACL main/rod/thrust bearings
Cosworth twin plenum
ARP main/head studs
ARP rod bolts
AMS pulley kit w/ belts
Motordyne 5/16" copper ISO thermal plenum spacer
WPC treatment to crankshaft
Tomei 10.5 in/ex 272 Cams
Tomei Valvespring Kit
Engine will come at a later date after I'm bored of the original wow factor and go higher.
Last edited by Pastmylife357; Apr 19, 2012 at 02:08 PM. Reason: Changes to build list
Old Apr 11, 2012 | 05:47 PM
rcdash's Avatar
rcdash
"Monumentum" is out of business. Boosted Performance is your best bet for a DIY low budget ST build. PM BoostedPerformance. Also, add a trans cooler and skip the 3.9 gears. You may wish to read the sticky FI for noobs thread. Good luck.
Old Apr 11, 2012 | 06:28 PM
Pastmylife357
Didn't see anything about them being out of business, the kit is still avail for purchase. I'll pm him and find out more on bp's st. Trans cooler is on my other list just forgot to include it, will edit. Everythin I've read so far suggests at least 3.5gears but they like the 3.9's for turbo setup. Or is it jus the lack of any real performance difference?
Old Apr 11, 2012 | 07:45 PM
thisishk350's Avatar
thisishk350
you should talk to this guy.
https://my350z.com/forum/forced-indu...-friendly.html
Old Apr 11, 2012 | 10:22 PM
Pastmylife357
Thx. Sent him pm. If this post seems off I'm sorry, I've spent at least 60hrs+ reading forums trying to figure this out but keep running into out-dated information as is apparent by the monumentom bit. I'm just trying to move past this stonewall of information I've run into so I can learn more about this and don't waste 10-12k on a set-up that won't work or doesn't exist anymore after I bought half the stuff. Thank you for your help thus far.
Old Apr 12, 2012 | 03:50 AM
dj lizard's Avatar
dj lizard
List:
Monumentum st kit "if your power goal is around 410-600 whp then stick with it... it's a good quality kit. I was running that and I just switched to TT for more power.. I have it for sale by the way.
Borla td cat-back exhaust "not a good Idea since it's true duel, look for an exhaust that's not a true dual such as greddy TIC/SE, Nismo, and stuff like that"
Unorthodox pulley kit "if it's the stock crank size your ok, but if it's under-driven then stock is your only choice"
Jwt popcharger "don't need that.... almost all turbo kits comes with the intake and filter"
Transgo vb/shift kit
LSD w/ 3.9gears "why LSD.. if you already have the VLSD then no need for that.. your on 5AT so it's not a drift/autoX car it's a daily driven... your just wasting your money.."
and by the way yes... Momentum went out of business few months ago...
good luck on your build..
Old Apr 12, 2012 | 04:47 AM
eZg's Avatar
eZg
If your going to buy a new kit go with BP.....should be able to install it your self.
Used may seem like a good deal until you wind up with missing or broken pieces that take forever to source. Lizard seems like a good guy and is active on the forum so I would consider his momentum.
Personally i would consider MotorDyne (sp?) exhaust.
But the BIG question is who are you gonna get to tune it and how??
Also if you are having a shop install I would buy as much as possible from them. Issues ALWAYS come up and if it is the shop's product they are much kinder about labor rates dealing with said issue.
Old Apr 12, 2012 | 04:55 AM
Eno's Avatar
Eno
Originally Posted by thisishk350
I'm "that guy." PM sent!
I'm not sure if BP has yet had a chance to fab up the AT version of his kit so we may be left wanting in that department. Not to speak on his behalf but I'm pretty sure that's the problem we're going to have turning to the obvious best option here.
Old Apr 12, 2012 | 10:20 AM
Pastmylife357
All Thx for ur help so far. Talking to bp guy about the kit for a 5at so I should have more on that from him. I'll look more into exhausts to find something better but what is the problem with having a td exhaust? Haven't rly read anything bad about it except for the fab of a reverse y-pipe req'd. I want to keep the dual ends because I like the look don't know if that has an effect on the exhaust to purchase but will look more into this. I'll edit the lsd/gears n popcharger thx. The pulley kit is under-driven and I plan on keeping the engine stock but was thinkin of new rods jus for reliability n longevity. I'm moving in a couple months back to md so I was going to look into who to install n tune there but I wanted to have some knowledge of what I want and then purchase thro them. Thx for the help thus far. Rly do appreciative it.
Old Apr 12, 2012 | 11:25 AM
JERZ350's Avatar
JERZ350
Is sound a big thing for you? The motordyne is going to be loud, Borla TD is probably the quietest exhaust you can get aside from stock.
Old Apr 12, 2012 | 12:26 PM
Pastmylife357
Sound isn't rly something I'm going for. Def don't want that annoying ricer fart can sound, lookin more so on the side of deeper aggressive sound if that makes sense. Nothing too loud. Jus a bit up from stock sound but more performance obviously
Old Apr 12, 2012 | 01:15 PM
DaveJackson's Avatar
DaveJackson
Master
Originally Posted by Pastmylife357
...and I plan on keeping the engine stock but was thinkin of new rods jus for reliability n longevity...
It's important to realize exactly what this entails.
Old Apr 12, 2012 | 01:23 PM
Pastmylife357
Wut do u mean? I saw what can happen to the stock rods and I don't want to have that happen to me.and end up spending another 5k fixing everything. Or are you referring to doing a piston/rod upgrade and not just rods?
Old Apr 12, 2012 | 01:27 PM
Pastmylife357
talked to sasha and bp hasn't fab'd a st kit for at and don't foresee one anytime soon. Did see s&r is coming out with a new st trying to get more info from them to see what's in the kit and if it'll be for at or just mt. So for now researching PL, APS, and SFR st kits.
Old Apr 12, 2012 | 03:11 PM
dj lizard's Avatar
dj lizard
god... dude you are in a big knowledge miss under-standing over here...
First, you can't just replace the rods, and but your engine back together like
that!!! that's not the way it goes. there are several machining and balancing
involves in this... so it's a better idea to go all forged internals, if you are
taring you engine into pieces...
Second, there is no point of having under-drive pulley and Turbo !!! it will
just tare your belt apart I know I read about it somewhere on this forum.
third, reversed y pipe will create back pressure which = loss of power....
there are plenty of exhaust systems out there that are not true duel,
but does have the duel exit.
"and there not as loud as you expect them to be"
nismo is leaning more to stock when it comes to sound
f*** my BOV is even louder....
DO IT RIGHT THE FIRST TIME OR NEVER DO IT
Old Apr 12, 2012 | 03:21 PM
Pastmylife357
Ok.well thank you for clarifying that for me. Not doing internals so ill scratch that out.
Didn't know that about turbo/under-drive pulleys guess that's my fault for assuming they were fi with turbo or maybe them for talking about it in a fi forum either way. Thank u.
See no one mentions these things, cuz I've seen no one mentioned anything about back-pressure with the reverse y-pipe.
This is why I created my own thread so i can get the help I'm looking for with the feedback directed towed my goals and questions instead of this made of mis-leading and confusing information out there. I really do appreciative the help and have already made changes to my plans for my set-up. Edit coming to list soon.
Old Apr 12, 2012 | 08:10 PM
Pastmylife357
Made edit to parts list. Still a couple things left to go. Let me know what you think. Appreciate all the help.
Old Apr 12, 2012 | 08:39 PM
Ruthless18x's Avatar
Ruthless18x
Your goals aren't very extravagant. Why not just buy a Vortech and call it a day?
Old Apr 12, 2012 | 08:50 PM
Pastmylife357
Do my goals need to extravagant? So comment not needed since its not on topic nor help in anyway. I want to do a turbo build not a sc build.
Old Apr 13, 2012 | 04:50 AM
DaveJackson
Master
So, what's your cost estimate at this point now that you've modified your list?
