VQ35HR e85 conversion
Old May 12, 2012 | 11:53 AM
xslangx's Avatar
xslangx
Thumbs up VQ35HR e85 conversion
Thinking of starting early and just swapping to E85 as we speak,
Osiris UPREV tuner + Pump and injectors
Will I need DIFF fuel lines?
I know on my volvo we needed better compound fuel lines which is why I strayed because the custom cost would have been in the 1000$ range
What kind of gains on N/A should I expect??
Ill go 1000cc injectors and what size pump?? I will be boosting soon (See rear mount thread)
Only going to aim for 400whp but as for now just catback exhaust + test pipes are on.
Old May 12, 2012 | 11:57 AM
0jiggy0's Avatar
0jiggy0
If your goign for 400whp you dont need e85. Gains on N/A will be determined by how much you can advance the timing. Why couldnt this be asked in your other thread?
Old May 12, 2012 | 12:06 PM
xslangx's Avatar
xslangx
e85 for price of gasoline and engine reliability. Im in CA only 91...
more timing and cooler temps and higher detonation point...
Because this is different, dont hate.
Old May 12, 2012 | 12:38 PM
KingBaby's Avatar
KingBaby
Hardest Setting
Do it!
Old May 12, 2012 | 12:56 PM
xslangx's Avatar
xslangx
Originally Posted by KingBaby
Do it!
I plan to
any idea on fuel lines etc??
Im thinking 1000 or 1200cc injectors and what size fuel pump??
Old May 12, 2012 | 01:17 PM
str8dum1's Avatar
str8dum1
i dont understand how you say ID1000s are gonna run like crap in your other thread, but now want to run them?
you still use the exact same setup i mentioned in your other thread.
ID1000s and a walbro 485. The lines are fine. YOu also have to remember you have to have high Z injectors on the stock, so that really limits the brands you can use. Mainly on ID or Deatchwerks.
FWIW, i get 11mpg around town on E85. It will cost you alot more to run E85, and for such low whp, you wont see any difference.
Old May 12, 2012 | 06:00 PM
RudeG_v2.0's Avatar
RudeG_v2.0
でたらめ検出器
It makes absolutely NO SENSE to go E85 on a VQ for boost/power levels that can be safely achieved on pump gas. E85 is used in the aftermarket as a cheaper alternative to race gas.
At your stated power goal of 400whp on a 35R size turbo, you will be nowhere near the limits of a safe and conservative tune on 91 pump gas.
Old May 12, 2012 | 10:10 PM
xslangx's Avatar
xslangx
I get 11mpg right now x)
1000cc for e85 is WAY different than 1000c on gas .... comeon..
e85 = double consumption about 1.7 times so bigger injectors
Why are there so many haters hahahha jeez!! e85 is safer no matter how you look at it AT 280whp or 580whp doesnt matter! its a better fueling option no matter how you look at it x))
Old May 12, 2012 | 10:25 PM
KingBaby's Avatar
KingBaby
Hardest Setting
Well do it!
Old May 12, 2012 | 10:42 PM
xslangx's Avatar
xslangx
Well do it!
With you on this one!
Any cheap finds on ID1000's?
Old May 13, 2012 | 02:10 AM
MR RIZK's Avatar
MR RIZK
How u going to control the varying E85 % with Osiris as it doesn't have a flex fuel sensor option?
Old May 13, 2012 | 03:45 AM
Flo-ridaZ33's Avatar
Flo-ridaZ33
So are you piecing together an Ebay kit or going N/A E85?
Old May 13, 2012 | 04:08 AM
Cass007's Avatar
Cass007
- I sense Fail here....
Old May 13, 2012 | 08:47 AM
xslangx's Avatar
xslangx
Here is the current list of parts, If I buy them all at cost im looking at about 1700$ I have plenty of IC piping in my garage, will just need 1 more HKS BOV as I have one on my volvo.
INJECTORS (e85 I will run ID1000's anyone want to toss me a link?)
http://www.ebay.com/itm/Nissan-skyli...ht_2222wt_1396
$500
____________________________________________________________ ____
FUEL PUMP WALBRO 400 lph.
http://www.ebay.com/itm/Brand-New-Wa...ht_1352wt_1396
$164
____________________________________________________________ _____
OIL PUMPS x 2 (STS type, one feed one drain)
http://www.ebay.com/itm/New-Rear-Mou...ht_2462wt_1396
$125 x 2 = $250
EXPANSION TANK (Going to hold my oil) tapped for AN fittings up top.
http://www.ebay.com/itm/Aluminum-Coo...ht_3534wt_1163
70$
TURBO
http://www.ebay.com/itm/GT35-T4-Turb...ht_5315wt_1163
$300
V BAND
http://www.ebay.com/itm/Exhaust-3-V-...ht_1034wt_1163
$20
INTERCOOLER
http://www.ebay.com/itm/32-5-x11-75-...ht_3980wt_1010
$110
OIL COOLER
http://www.ebay.com/itm/8-Blue-Alumi...ht_2054wt_1163
$40 basic trans type finned cooler.
OSIRIS UPREV tuner
www.uprev.com
$700 have had multiple offers for a 500$ one on the forum i might take it
WASTEGATE tial.
http://www.ebay.com/itm/TiAL-38mm-Wa...#ht_500wt_1180
$230
Calculate in about $200-$500 in welding/additional costs and were talking about $2000-$2500 for fuel tune and boost.
Old May 13, 2012 | 09:12 AM
Flo-ridaZ33
Ok so are you going to talk about doing it... or do it?
Old May 13, 2012 | 09:13 AM
xslangx's Avatar
xslangx
Jealousy.
Dont be such a hater bro, wont get you anywhere.
Old May 13, 2012 | 09:38 AM
KingBaby's Avatar
KingBaby
Hardest Setting
Jesus.....quit kid.
Return when you've purchased something off eBay then post progress.
Old May 13, 2012 | 09:46 AM
Flo-ridaZ33
Originally Posted by xslangx
Jealousy.
Hater? "Gonna Do" threads won't get you far either little man:
Current set up:
Build info:
https://my350z.com/forum/forced-indu...ger-build.html
Build in Progress:
https://my350z.com/forum/forced-indu...hksgt8555.html
Old May 13, 2012 | 09:52 AM
xslangx's Avatar
xslangx
Is that supposed to impress me?
Lol posting up your build photos it seems your the "little man"
I could care less about your cookie cutter build
Old May 13, 2012 | 10:21 AM
Flo-ridaZ33
Hmmm... your definitely a Troll and a HKS GT kit is hardly is hardly a "cookie cutter", in fact an Ebay built kit would be more of a cookie cutter garbage set up anyway. BTW my HKSGT8555 will be the only one out of HKSJapan because it hasn't been formally introduced yet.
This is a dreamer thread... you came to post to hear yourself talk but your not going to do ****. Less talking and more doing.
