Boosted Performance & R/T Tuning..My build
Old Oct 16, 2012 | 10:20 AM
  #61
gixx76's Avatar
gixx76
Originally Posted by binder
bias ply are the best things for track use. They will absorb the impact off the line and save your axles as well. Not sure if anyone makes an 18" bias ply though.
This car will never see the drag strip..... My track days are road racing my good man
stock heads and cams from what I was told.
Stock heads and cams ...for now
Old Oct 16, 2012 | 10:34 AM
  #62
djamps's Avatar
djamps
Aftermarket turbos in auto-x or other road racing will make you so out classed it's silly (unlimited/outlaw type classes). Do you actually run your car at these events competitively?
Old Oct 17, 2012 | 05:25 AM
  #63
binder's Avatar
binder
I wouldn't get into a hurry on head work. It's crazy expensive and it pushed my curve to the right. The amount of power I use is well within the limits of the stock heads so I would have been better off with more midrange.
Old Oct 21, 2012 | 01:46 PM
  #64
gixx76's Avatar
gixx76
dj, I am not sure I follow you?
You meant that I would be out classing the rest of the pack I think,.....Yes that is the point Road racing is 80% driver 20% power, having all that power at your disposal just helps the ones who know what they are doing on the track, Fortunately for me 13 years of road racing puts me in that group
Nothing competitive, simply a hobby, as many track days a year(with the groups that have drivers that actually know what their doing on a track) that we can fit in as possible.
Thanks binder, Good to know, thanks for the heads up.. What about intake? worth any gains with cosworth or the Kintetix??
Old Oct 21, 2012 | 02:16 PM
  #65
binder's Avatar
binder
kinetix is junk. cosworth there were some gains but for forced induction you can get more from 1psi of added boost than an 1100$ intake.
I think what djamps was saying is your turbo puts you in a more competitive class in a sanctioned event. Those guys are ruthless.
  #66
Boosted Performance's Avatar
Boosted Performance
Vendor - Former Vendor
Depending on how far you want to go with the power, the cossworth manifold is a nice piece of hardware. However, before you start adding other components I would consider going to the larger .96 a/r turbine housing as well. It will open things up a bit more, and you could go to 650whp + with just that upgrade, and a couple of more psi of boost. The IAT's would go down as well, because the exhaust back pressure would also be reduced with the larger, housing that flows more. You are already making more power with a ST than any other production kit out there....and there is still room to go..
And remember, with any changes the tune should be adjusted.
Old Oct 21, 2012 | 02:21 PM
  #67
binder's Avatar
binder
from personal experience, after 600 the fun factor goes down and the stress during driving goes way up! it requires a lot more driver attention to keep it going.
350Z_Al
Oct 29, 2020 07:44 PM
Tochigi_236
Sep 27, 2015 03:40 PM
