Another built motor Vortech dreamer thread.
Old Sep 13, 2015 | 06:20 PM
  #821
OldManZ350's Avatar
OldManZ350
This Blower is Designed to turn CCW, Look at the Picture!
Can you tell the Direction? Looking at the Gear Case tells you nothing about rotation. You need to look at the Blower Side.
Cux350z, you make this very confusing for yourself.
Vortech only makes a CW and a CCW.
Focus you're attention to the Blower Side, not the Gear Side.
Originally Posted by Cux350z
There is an input shaft...some gears and then finally the impeller spins. The input shaft needs to spin the right direction to spin the impeller the right direction..not sure how many gears in between the input shaft and impeller.
Attached Thumbnails Another built motor Vortech dreamer thread.-fb3364d0-ff7b-44b3-8ca4-72d1a74190ba.jpg
Old Sep 14, 2015 | 02:08 AM
  #822
Cux350z's Avatar
Cux350z
hatersgonnahate
Dude I get that the Impeller is turning CCW. That was easy to determine without your 2 posts and just by looking at the volute/impeller shape.
What do you not understand about what I am asking? There is a input shaft..that is the direction that matters for the 350z application that could be different from say a mustang application. Key word INPUT.
Old Sep 14, 2015 | 03:18 AM
  #823
OldManZ350's Avatar
OldManZ350
I was try to help you.....
My IMPUT to you is, Josh has the correct Blower, it's a CCW.
Hope this helps you. Maybe re-read my last post in reguards to the Imput (Shaft) side or gear case side of the Blower.
TimRod
Old Sep 22, 2015 | 08:06 AM
  #824
meanz's Avatar
meanz
Played with this 4" intake. Had to trim some more and make adjustments. But the way the filter will be located, will be in direct airflow. The piece of piping on the end represents the filter I ordered. Still waiting..
Old Sep 22, 2015 | 01:56 PM
  #825
Resmarted's Avatar
Resmarted
Ballin
Old Sep 22, 2015 | 05:19 PM
  #826
meanz's Avatar
meanz
Originally Posted by Resmarted
Ballin
You know it, lol my cog finally came today. I'll be starting it up tomorrow for the first time.
Old Sep 22, 2015 | 05:25 PM
  #827
Conway_160's Avatar
Conway_160
Well I'll bet that's exciting!
Old Sep 22, 2015 | 07:30 PM
  #828
meanz's Avatar
meanz
Haven't made it home Getz, drinkin downtown..
Old Sep 23, 2015 | 02:31 PM
  #829
Resmarted's Avatar
Resmarted
Pour some alcohol in that gas tank man!
Old Sep 23, 2015 | 04:54 PM
  #830
meanz's Avatar
meanz
Man it was such a rough night. Drink after drink, lol
Finally got it all together and running. Everything seems to be doing pretty good. I'm seeing 17 psi at redline. Figure it's a bunch of slip. Haven't tightened down belt yet. But it pulls hard and more you rev it, the more it wants. Still waiting on my piping so I can go 3" on blower side.
Old Sep 23, 2015 | 04:59 PM
  #831
meanz's Avatar
meanz
Old Sep 23, 2015 | 05:15 PM
  #832
OldManZ350's Avatar
OldManZ350
Looking Good Josh.
Old Sep 23, 2015 | 06:14 PM
  #833
HRMoneyPit's Avatar
HRMoneyPit
That intercooler though
Old Sep 24, 2015 | 04:02 PM
  #834
Resmarted's Avatar
Resmarted
Your car is sick man. Love it!
Old Sep 24, 2015 | 06:37 PM
  #835
Conway_160's Avatar
Conway_160
Damn, cant wait to see how much you get out of this blower!
Old Sep 25, 2015 | 08:12 AM
  #836
meanz's Avatar
meanz
Thanks, wish it wasn't raining so I could take her for a spin. Finally got my bumper mounted up. Had to cut it up a little bit. Still a tight fit but it's on. My piping also came yesterday. Will be doing that next week sometime. Also I found out I forgot to put a clamp on brake booster port on the cosworth. Might have been loosing a little boost out of that. I'll take it for a ride soon and find out.
Old Sep 25, 2015 | 09:21 AM
  #837
Conway_160's Avatar
Conway_160
Does the YSI feel any different than the old blower or does it still pull the same?
Old Sep 25, 2015 | 11:05 AM
  #838
meanz's Avatar
meanz
Truthfully it feels the same, but I've been running it on my traction map. Haven't changed maps yet. And I'm only hitting 17 psi instead of the 22-24 I was normally seeing on the street. I'm sure there is a ton of power to be had with this beast.
On my ti trim I seen 3psi with filter on at 3000 rpms. I'm seeing about 3.8 at the same rpm with this blower. Haven't really logged anything yet to compare but that's one thing I did notice. Also I was hitting 17 psi at 6400 on the ti. Now it's taking me to 7200 to hit it. I think I might of had a couple boost leaks, so I'm gonna go test it out again to see after the rain stops.
Old Sep 25, 2015 | 08:05 PM
  #839
Conway_160's Avatar
Conway_160
Well let us know as soon as you get some dry pavement.
Old Oct 2, 2015 | 09:46 AM
  #840
meanz's Avatar
meanz
Was able to put some miles on the blower. Runs pretty good and pulls great. Still seeing 17psi. Haven't touched the belt tensioner on it. Just wanted to drive it. Getting ready to finish up my piping coming off the blower. Friend is on vacation right now. Gonna finally remove my maf sensor and install GM temp sensor. Still changing up some pulleys soon. Trying to work out a deal with Cux for his ATi crank pulley. Try to spin this this ysi a little harder.
Here is a pic from last night that Taywan took at a friends shop.
