Another built motor Vortech dreamer thread.
I have some piping the put the filter right behind the intercooler, very tight fit. Not the very best place to have a filter, but when I was running my crashbar/intercooler setup, it was the only place it fit.
Haven't tried yet. Just waiting to get car back together. I'll put a spacer and longer wheel studs on and should be fine. If it's really an issue, I'll run the base brakes again in the rear. But I should be fine.
Finally got home and started messing with this. When you first get it, it needs to be clocked almost 180*. Have to make the brackets that hold the volume around. No issue there. I mounted it up to the bracket and placed on the car. Surprising, everything is clearing. Have about a 1/4 gap under the blower so it does not run.
I have solid mounts and maybe that helped with the fitment. It's snug. But it fits! The exit on the blower is kinda heading straight for the radiator fans/housing. When I get my piping remade, I'll have to just angle it away a little bit and it should be fine.
Got my 4" intake piping, this is massive. Gonna be cutting up the core support to make this fit and cut to length. I have a filter ordered and it should be here shortly.
Here are some pics!
Here are some pics!
