Another built motor Vortech dreamer thread.
Old Oct 3, 2015 | 09:52 PM
  #861
Resmarted's Avatar
Resmarted
Originally Posted by OldManZ350
There have been people with a similar setup, 6 rib with a TimRod Radius Rod hold to 26psi.
That said, if I were to do a Ysi I'd go to a 10 rib serp and a much wider Cog.
It's not a simple as just changing out the pullies. Also the crank, PS, tensioner and Alt pullies would need to be custom made. And this is leaving the SC'er in about the same place. I put some work into this a few years back. It's about $2500+ for the custom pullies and you would also need 10 rib idlers, but those are available if you look hard enough.
I'd also think about a tandem Bracket setup much like a mustang YSi kit, but I must say with solid motor mounts and a TimRod Radius Rod the stock bracket becomes pretty stout!
Look we've heard the fckn tim rod radius plug a million times. FFS Josh has one. I know you've done a lot for the vortech z community, and I commend you on it, but the radius rod is not the perfect solution.
I don't understand why, but nobody on here has tried the pulley coating, and that has made all the difference in the domestic 6 rib cars.
The radius rod is scary to me, because you're solid mounting a plate connected to the engine to the chassis. The amount of flex I saw on Josh's voretech bracket scared me, and I think that we need to look at that seriously. Solid mounts or not, you're fixing a dynamic piece to the chassis, and that generally isn't good. Fortunately it helps with the flex that is already happening, but in general that much tension against the crank is not healthy either.
I think that getting more grip at the pulley is totally do able with larger pullies+coating, and higher rpm to compensate. Will it make boost as quickly? No. Will it have as aggressive of a torque curve? No. But the reduced load against the bearings will be worth it in my book. I'm going to be attempting this on my car, and I think that just going around preaching "TIM ROD RADIUS KIT" is silly, and not the only way to skin the cat.
Larger pullies make the actual grip needed on the pulley surface lower, as you have a larger pulley to turn the s/c etc (greater force multiplier), and increased friction will always always help. Increased belt tension is always a help too, but when you've got so much tension in the belt that you're causing this fat piece of aluminum to flex back and fourth, causing more belt slip, that's not good for the crank. It's not good for the bearings. It's not a proper solution.
I hate to be that "d!ck" on the internet, but it needs to be said.
Old Oct 4, 2015 | 11:57 AM
  #862
OldManZ350's Avatar
OldManZ350
Everybody has an Opinion!
Old Oct 4, 2015 | 12:08 PM
  #863
OldManZ350's Avatar
OldManZ350
Hay Josh, read this thread. Funny, after the post today on you thread.
https://my350z.com/forum/forced-indu...00whp-z33.html
Old Oct 4, 2015 | 02:38 PM
  #864
meanz's Avatar
meanz
Did some Things today..
Mocked this up today. Everything fits pretty good. Has good clearance. The black piping is because I ran out of the shiny stuff. But is all 3". Just need to go by and get it welded up to get rid of the couplers.
Old Oct 5, 2015 | 07:53 AM
  #865
Threads's Avatar
Not to hijack, but I actually have a coated pulley that's being used with my T-Trim. Having issues getting a properly sized belt with my ATi Crank Pulley, so I haven't been able to get good enough numbers to get numbers/tuned/dyno. I'll be using the radius rod as well however, FWIW.
Old Oct 5, 2015 | 01:52 PM
  #866
meanz's Avatar
meanz
My buddy at GE blasted my 3.12 pulley with white aluminum oxide 20 grit
Old Oct 5, 2015 | 01:56 PM
  #867
Conway_160's Avatar
Conway_160
Doing it to the 2.87 as well? Or does that depend on how much slip you get with the 3.12?
Old Oct 5, 2015 | 02:15 PM
  #868
meanz's Avatar
meanz
Gonna see how this holds up first. My friend can do it anytime for free. It was an idea we had that didn't cost anything. Gonna see what it does.
Old Oct 8, 2015 | 02:43 AM
  #869
meanz's Avatar
meanz
With the different pulley setup I'm doing now, blower should be spinning around 67k if I rev up to 7500 with this 3.12 pulley. Have a ati crank pulley on the way thanks to Cux. Only thing left to buy is the 27t blower cog. Have my piping at my friends getting ready to be welded up.
Edit, blower will actually be spinning around 71k at 7500rpms. I forgot I have a different jack shaft cog, just redid the vortech calculator.
Old Oct 8, 2015 | 08:52 AM
  #870
Threads's Avatar
If you don't mind, can you let me know if you experience any issues installing your new belt with the new ATi crank pulley. For me, it's almost impossible to get the proper size belt on there, and I think it has to do with the bigger crank pulley being so much closer to the tensioner.
With a new belt, I can get a bigger belt on, but the tensioner does not provide enough tension. With a belt that "should" fit well, it's feels impossible to get the belt on with the tensioner all the way down.
Old Oct 8, 2015 | 09:17 AM
  #871
meanz's Avatar
meanz
Could you add an extra idler into the mix and take up the extra slack with the bigger belt? That's what I'm going to try and do if I run into that problem.
Old Oct 8, 2015 | 09:18 AM
  #872
meanz's Avatar
meanz
And also on my old setup with a fresh belt. I had to use a pry bar to get the belt on. Was very tight to get on.
Old Oct 8, 2015 | 12:06 PM
  #873
OldManZ350's Avatar
OldManZ350
That's the way to do it!
Old Oct 9, 2015 | 04:54 PM
  #874
meanz's Avatar
meanz
Gonna be throwing it back together tomorrow.
Old Oct 9, 2015 | 05:03 PM
  #875
OldManZ350's Avatar
OldManZ350
Looking Good Josh! You did a nice job.
Old Oct 9, 2015 | 05:33 PM
  #876
Threads's Avatar
I think I'm going to try a variable tensioner in place of one of the pulleys on the vortech bracket. The hope being I can run a properly sized belt AND reduce some belt slip with the tensioner. The tensioner is relatively cheap, so if it works, great. If not, no big deal.
And OMG, that piping is just sex.
Old Oct 11, 2015 | 01:55 AM
  #877
meanz's Avatar
meanz
Seeing 20 psi and it pulls hard. I'll update with some pics later. Didn't change pulleys yet. Just tightened belt more. Pulls hard!
Old Oct 11, 2015 | 07:08 AM
  #878
Conway_160's Avatar
Conway_160
Is this with the new coated 3.12 Pulley?
Old Oct 11, 2015 | 08:43 AM
  #879
meanz's Avatar
meanz
No change in pulleys yet. Same setup.
Old Oct 11, 2015 | 03:15 PM
  #880
Conway_160's Avatar
Conway_160
So at this rate you may not have to change pulleys?
