Another built motor Vortech dreamer thread.
Old Oct 11, 2015 | 04:27 PM
  #881
meanz's Avatar
meanz
Originally Posted by Conway_160
So at this rate you may not have to change pulleys?
I'll still change. I have Cuxs ati crank pulley and this blasted 3.12. Need to buy the 27t cog and it should be spinning just right. Car is pulling great. Took my friend for a ride that did the welding. He had a smile ear to ear lol. Car is running great for the moment. Can't wait to try crank and other pulley out. Prolly start ripping it apart again on my next day off.
Old Oct 16, 2015 | 08:02 AM
  #882
meanz's Avatar
meanz
Went to the track to see what mph it would get. I'm running the 2.87 pulley and hitting 21psi. It's only hitting the traps at 95mph in the 1/8. Not to bad. Right now the blower should be spinning around 65k. When I install the ati, it should jump up to 72k.
Old Oct 16, 2015 | 02:28 PM
  #883
Conway_160's Avatar
Conway_160
So is that about the same traps as the t-trim?
Old Oct 16, 2015 | 03:56 PM
  #884
meanz's Avatar
meanz
Yeah till its tuned. It actually slower right now. Lol
Old Oct 16, 2015 | 06:42 PM
  #885
Conway_160's Avatar
Conway_160
Well you need more boost then, sucks to spend money to go slower :-(
Old Oct 16, 2015 | 10:17 PM
  #886
Resmarted's Avatar
Resmarted
That's actually really good. You should be able to squeeze some good power out of it upon retune, AND even more obviously when you up the boost and rpm
Old Oct 17, 2015 | 06:14 AM
  #887
meanz's Avatar
meanz
Just needs retuned... Last time I went to a bigger blower it dropped around 50hp right off the bat till it was tuned. I already know thAt this thing is gonna scream on passed the t trim blower come tune day.
Old Oct 17, 2015 | 10:38 PM
  #888
Resmarted's Avatar
Resmarted
Anyone who thinks otherwise is going to be sorely mistaken lol
Old Oct 18, 2015 | 02:44 AM
  #889
Conway_160's Avatar
Conway_160
Cant wait for results once you get it all sorted out.
Old Oct 21, 2015 | 08:04 AM
  #890
str8dum1's Avatar
str8dum1
How come? How much O2 correction do you need now? Are you expecting your MBT to jump alot so you can throw alot more timing? Are you running extra lean/rich right now? What part of the tuning do you think has to be fixed?
Curious if you compared your boost curves and how much different they are.
Old Oct 26, 2015 | 05:24 AM
  #891
meanz's Avatar
meanz
Been doing some testing with added idler pulley. I'm seeing 22.xx psi around 6300 now. I'm maxing my map sensor and car looses throttle. Hal thinks it's prolly a safety for over boost. Car is running great. It's seing 11.1 afr up top. With the smaller ti blower at 6400 at 17psu it made 580hp. Curious to see what this ysi is gonna do. Gonna spin it up to 7500 if it's still make good power and boost.
Old Oct 26, 2015 | 05:43 AM
  #892
HRMoneyPit's Avatar
HRMoneyPit
Dyno dyno dyno
Old Oct 26, 2015 | 05:47 AM
  #893
meanz's Avatar
meanz
Won't see dyno till after Christmas. I was just trying to work out any kinks in the setup and make sure my belt wasn't going to slip so much.
Old Oct 26, 2015 | 03:05 PM
  #894
Conway_160's Avatar
Conway_160
What do you need 4 bar map sensor? This is looking very promissing for ya!
Old Oct 26, 2015 | 04:44 PM
  #895
Resmarted's Avatar
Resmarted
I thought you had an external pressure sensor from the TI setup?
Old Oct 26, 2015 | 04:53 PM
  #896
meanz's Avatar
meanz
No still using the internal. That's one thing I don't understand right now. On the ti I was maxing it out, but still able to go higher according to my boost gauge. Before the crank pulley change, I was able to rev out to 7200rpms making 21psi. After the crank pulley change, I hit 22.xx and it stops pulling. Doesn't hesitate, buck, or cut out. It's like I just let off the throttle. Also no codes.
If I do a pull in 1st or 2nd, I get belt slip and won't make 22psi till around 7200. No issues. I might put my 3.12 pulley on and see if I can pull it to redline.
Old Oct 26, 2015 | 04:55 PM
  #897
meanz's Avatar
meanz
Yeah I'm hoping for great things with this blower.
Old Oct 26, 2015 | 05:27 PM
  #898
Cux350z's Avatar
Cux350z
hatersgonnahate
get the external map sensor
boost, ait and cfm can all vary. Especially with your new piping and blower.
Old Oct 26, 2015 | 09:38 PM
  #899
Resmarted's Avatar
Resmarted
Yeah the setup has changed drastically.
Id venture to guess that you werent actually going past maybe 23 24 psi with the last one. Whats your boost guage model?
Old Dec 3, 2015 | 08:25 AM
  #900
meanz's Avatar
meanz
Selling this ysi setup complete. Something else has come up and going different direction. If anyone is interested in everything, send me a pm. Will make a forsale thread soon.
