Another built motor Vortech dreamer thread.
Old Aug 11, 2013 | 08:58 AM
  #81
meanz's Avatar
meanz
Cux, still have stock motor mounts
Trij, I'm not sure how much I'm gonna be over spinning blower. I did a couple configurations on vortech's impeller calculator, but we still don't know how high were gonna rev to at the moment. I will find out for sure what it will be when I get the car back. I'm excited to see how your build does also!
Old Aug 11, 2013 | 10:28 AM
  #82
hellman_x's Avatar
hellman_x
Sorry, I didn't read from the beginning, don't know if you mentioned it or not but, why did pick a SC build over a turbo build if you built your engine?
Not criticizing because I have a Vortech SC myself but that is because I have a stock block, if I built my engine I would've definitely gone turbo.
Old Aug 11, 2013 | 11:48 AM
  #83
meanz's Avatar
meanz
Mostly because I already had a vortec to start with and already pushed over 400trq on stock internals. This build was really never a about high numbers, mostly just reliability..but figured if I have it, might as well push it and see what we get. If I ever got bored I could always sell and go turbo.
Old Aug 12, 2013 | 07:41 AM
  #84
meanz's Avatar
meanz
Tuning has started once again, but now they are having crazy belt slip with anything over 6k. They ordered a gates belt and going to be trying some different things to see if they can stop the slip..
Old Aug 12, 2013 | 09:39 AM
  #85
Threads's Avatar
Meanz, is your serpentine belt slipping or is it the cog belt? FWIW, I've heard that the Gates green stripe belts are one of the best micro-v belts you can get. I went ahead and got one for my setup. Likewise, I have my supercharger pulley carbonite coated. Unfortunately, I haven't had a chance to fully test these items, but it's what I decided to run with on my build.
Old Aug 12, 2013 | 09:46 AM
  #86
Triji's Avatar
Triji
What about the GTM pulley ad on? I did not see it in your pics... Or the TIMROD belt mod to help cut down on belt slip?
Old Aug 12, 2013 | 10:27 AM
  #87
meanz's Avatar
meanz
I had the gtm pulley added by the jackshaft on my old setup.. Need to make sure it's still in use. They said they were still looking at some things at the moment.
Old Aug 12, 2013 | 10:38 AM
  #88
Triji's Avatar
Triji
Gotcha.... I do see the hole for it in the bracket in some of the pics but I do not see the pulley itself in any... Tried to see if I could see it in the video but it's a tough angle... Didn't see any 'silver' glint of it though.
Could be part of the issue with the slip.
Old Aug 12, 2013 | 11:00 AM
  #89
Threads's Avatar
I assumed he already had this installed. With my previous setup and GTM pulley mod, I was able to hit 18psi at redline with no major signs of belt slip according to the dyno charts.
Old Aug 12, 2013 | 01:40 PM
  #90
Colombo's Avatar
awesome numbers so far man. i hope you get that belt slip issue handled. timrod setup gtm single or dual pulley setup and maybe even the timrod brace he recently put out. on my new setup im running 1 with the timrod belt setup and a GTM hopefully that takes care of belt slip. im so excited to see what she puts down at 6800+ i have such a simular setup just the 928m impeller and slightly lower CR same cams pulley n fluidamp. your giving me great hope once my motor is broken in! .. now get that belt slip handled and break deep into the 5's!!!!
Old Aug 12, 2013 | 02:01 PM
  #91
meanz's Avatar
meanz
Ha ha, yeah I cant wait for final out come. The shop hasn't contacted me since about lunch time, maybe they figured it out by now.
Old Aug 12, 2013 | 02:24 PM
  #92
Triji's Avatar
Triji
Hey, what fuel are you running? I didn't notice it posted... E85 or regular fuel and what octane?
Old Aug 12, 2013 | 02:49 PM
  #93
meanz's Avatar
meanz
93 octane
Old Aug 12, 2013 | 03:17 PM
  #94
OldManZ350's Avatar
OldManZ350
With a TimRod Belt Setup and a Timrod Radius Rod Strut you will Not have any Belt Issues. Can Hold 25PSI+ with this setup on a 6 Rib Belt.
GTM pulley is Not Needed
Read threads Below
https://my350z.com/forum/forced-induc...-solution.html
https://my350z.com/forum/forced-induc...fener-kit.html
Old Aug 14, 2013 | 12:02 PM
  #95
str8dum1's Avatar
str8dum1
woah, you are running 25psi now? any new numbers?
Old Aug 14, 2013 | 03:25 PM
  #96
OldManZ350's Avatar
OldManZ350
No, not me, I have a friend with the Radius Rod, making 25psi on a 6 rib
Old Aug 15, 2013 | 08:44 AM
  #97
str8dum1's Avatar
str8dum1
25psi on a VQ must be pretty sweet. gotta be so far outta rpm range on anything besides a HD model vortech. I like.
Old Aug 15, 2013 | 02:15 PM
  #98
meanz's Avatar
meanz
Little update, the new 850 DW injectors are nearly maxed out at over 90%. 1000s are on the way. Its tuned up to 6700 right now making 530hp and 448trq. Said they haven't even started with the cam tuning or anything. Its sitting right at 16psi. Going Monday so I should have a video of something to post! Anyone interested in some brand new DW850s? lol
Old Aug 15, 2013 | 03:23 PM
  #99
Triji's Avatar
Triji
Oh crap.... And I only have ID 725's going in.... May have to upgrade those as well... Ugh.... More $$... (lol)
Nice numbers!! Congrats!!
Old Aug 15, 2013 | 03:37 PM
  #100
OldManZ350's Avatar
OldManZ350
Can you layout your complete fuel system here?
As much detail as posible, feed line size, pumps, fuel pressure, ect.
