vortech/stock block let go...so *knock on wood, reliable build thread ;-)
Old Jul 27, 2017 | 08:09 AM
  #441
Colombo's Avatar
Not much worse than it was before. It's truly only ALOT LOUDER at WOT. Just driving around it's slightly louder but not crazy. The car gets trailered to and from the track so drone was never an issue I worried about. Car feels to pull much much stronger. I may toss her back on a dyno see what changes going from a tiny exhaust to a big one would make
Old Jul 30, 2017 | 05:26 PM
  #442
0taku's Avatar
0taku
Was the Ti trim a direct swap from the V2 S trim?
Ended up overspinning? my blower and tanked it so I'm just going to swap over to the Ti. (What are you spinning at and is the impeller stock as well?)
Old Jul 30, 2017 | 08:21 PM
  #443
OldManZ350's Avatar
OldManZ350
The New V2 Ti-Trim is an HD Blower, very Tough.....
Old Jul 31, 2017 | 01:05 AM
  #444
wizard's Avatar
wizard
When was this 'new' blower released?
Is it ok just to swap over the blower if you have an existing kit or will it not make the power?
https://vortechsuperchargers.com/col...i-supercharger
Old Jul 31, 2017 | 09:19 AM
  #445
OldManZ350's Avatar
OldManZ350
I think about 1-1/2 years ago.
Yes you can just swap it. But don't use this on a stock motor unless you turn it very slow.
It will make crazy HP, just look at Colombo's dyno on 93 octane @ 26 psi
Old Aug 2, 2017 | 09:06 AM
  #446
wizard's Avatar
wizard
Does the below mean you need bigger intercooler then the one which comes with the v3 kit? This is from Vortech's product page for the v2 TI:
V-2 Ti Tuner Kits Important Note
Tuner Kits with the high flowing V-2 Ti supercharger head unit DO NOT include a charge cooler, as the standard 350Z/G35 charge cooler is not capable of supporting the significant airflow capability of the V-2 Ti compressor. Customers looking to utilize this system will need to source their own charge cooler capable of flowing sufficient cfm to support the V-2 Ti supercharger.
Old Aug 2, 2017 | 09:43 AM
  #447
OldManZ350's Avatar
OldManZ350
Vortech just sells a tuner kit as well as a full kit so you can choose the compontents you want, that said, you absolutely need a better intercooler. I've done a ton of research on ic's and I have found that Treadstone make quality ic's for a very good price. The oe I use, and the one you should get to run with the V2 Ti-Trim is a TR-1245. It's a perfect fit for this application. It's also the that I recommended to Colombo for his setup with the Ti-Trim, and it works great for him.
Old Aug 5, 2017 | 03:17 AM
  #448
wizard's Avatar
wizard
From your research, do you know what the limit who is of the intercooler which comes with the v2 and v3 kits is?
Old Aug 9, 2017 | 03:08 PM
  #449
OldManZ350's Avatar
OldManZ350
The stock Vortech Intercooler is designed for the kit as they sell it.
Once you start raising Boost, Intake Temps go SkyHigh with that IC.
If you really want to make some really HP, then go with the One I suggested.
This will stop any Headeaches you will have along the way.
Note: With the TR-1245 My Intake Temps are no more than 10-12f Degrees above Ambient. And I'm Cranking on the Blower making 18-19psi.
Hope This Helps
Old Oct 13, 2017 | 06:05 AM
  #450
Colombo's Avatar
So decided I wanted to fit a big boy drag tire over some brembos so modified then to fit..
here are the results... 16x9 +25 275/55/16
Old Oct 13, 2017 | 03:23 PM
  #451
Conway_160's Avatar
Conway_160
What did you have to do to get them to fit? Just some grinding or spacers?
Old Oct 14, 2017 | 09:42 PM
  #452
OldManZ350's Avatar
OldManZ350
Time for the Drag Strip!
Old May 15, 2018 | 08:19 AM
  #453
Colombo's Avatar
Been a while since I updated this, the car is still running strong. A few changes have been made to the tune (increased timing about 2 degrees throughout the whole power range as well as raised limited to 7900rpm) car is holding a constant 26 possible 27 psi at redline
we managed a 167mph at the Wannagofast half mile event still spinning first and some of second, the car has a 170 in her for sure.
few plans for the near future are possible a C16 tune to see what this thing can really do in the half 👍🏽👍🏽
Old May 15, 2018 | 08:21 AM
  #454
Colombo's Avatar
Old May 15, 2018 | 09:03 AM
  #455
BluestreamDE's Avatar
BluestreamDE
Good Luck, your car is baddass as usual! C16 will have you north of 800whp for sure especially revving out to almost 8k
Old May 15, 2018 | 09:58 AM
  #456
wizard's Avatar
wizard
Amazing. My car with a vortech si blower is going in for a tune this week.
do you know what rpm you are spinning the blower at? Ti Trim is rated to 55K rpm? Think i am even faster then that ha
Old May 15, 2018 | 10:10 AM
  #457
Colombo's Avatar
Thanks man!
No idea. I’m deff spinning way past that tho. ATI crank, 3.12 pulley, stock Cogs, 7900rpm
Old May 15, 2018 | 11:43 AM
  #458
BluestreamDE
[Crankshaft pulley size ÷ Serpentine Pulley size] x [Jackshaft pulley size ÷ Drive cog pulley size] x [Step up ratio x Max engine rpm]
So..
(6.61' ÷ 3.12 = 2.118589743589744 ) x ( 32 ÷ 28 = 1.142857142857143 ) x ( 3.45 x 7900 = 27,255 ) = 65991.04
Old May 15, 2018 | 03:38 PM
  #459
Colombo's Avatar
So..
vortech not have the calculator on the website? That’s how I use to calculate it when I cared 🤣🤣
Old May 15, 2018 | 03:49 PM
  #460
BluestreamDE
Ohh, they do. I just wanted to do the work lol
