vortech/stock block let go...so *knock on wood, reliable build thread ;-)
Old May 15, 2018 | 07:40 PM
  #461
OldManZ350's Avatar
OldManZ350
great job john
Old Jul 13, 2018 | 06:22 AM
  #462
Colombo's Avatar
May be time for a pulley drop, 3inch piping, and potentially a race gas tune 😈
Old Jul 19, 2018 | 05:10 AM
  #463
wizard's Avatar
wizard
By 3 inch piping do you mean the vortech piping?
Is there any difference in diameter between your piping and the kits they sell for sci's, e.g. 2.5"?
Old Apr 2, 2019 | 12:45 PM
  #464
Colombo's Avatar
It’s been quite some time and some changes have occurred. To keep this updated I’ll post it here aswell. To have real updates on the car it would be easiest to follow me on IG @ Jfrancoooo
anywho we switched up some pulleys and swapped to E85/ a cjm twin pump setup with 1700cc injectors and did something stupid.
We made 837whp/595wtq on a Mustang dyno at RZG motorsports with the man Ray Rowe behind the computer. A lot a lot of boost and a large chunk of timing thrown at her. This motor has been solid racing for over 3 years now so we decided to throw the kitchen sink at it for next months wannagofast half mile event in Ocala. I also fabricated a Air dam style bumper. This thing is moving so much air that we are at 93% duty cycle on E85 WITH a twin pump and 1700cc injectors 😅
Again best way to get updates is my IG as I don’t check this often but here’s some pics check the IG for videos 🤘🏽💪🏽
This is now the HIGHEST recorded/documented Supercharged VQ not just DE (including VHR) but that’s not a record we care much about.
We will be swinging for this half mile record in two weeks 🤘🏽🤘🏽
Old Apr 2, 2019 | 06:34 PM
  #465
OldManZ350's Avatar
OldManZ350
Nice Job John...........You have come all long way.
I Hope to be there to see your New Record.
TimRod
Old Apr 2, 2019 | 07:07 PM
  #466
Colombo's Avatar
TimRod
Tim if you end up going message me on FB! Would be great to meet ya
Old Apr 4, 2019 | 03:56 AM
  #467
0taku's Avatar
0taku
Amazing to see the numbers you’re putting on the Ti.
Old Apr 4, 2019 | 09:26 AM
  #468
Colombo's Avatar
a lot of trial and error. I been messing w blowers for 6-7 years now trying different things. If the blowers will hold the boost it will make the power. These pulls were at almost 27psi
Old Apr 4, 2019 | 01:31 PM
  #469
knuckles899's Avatar
knuckles899
Nice! 27psi!!!! Guess I'll stick to the factory open deck instead of the other closed deck/ block guard options when building mine if yours held. Good stuff man.
Old Apr 4, 2019 | 03:52 PM
  #470
bealljk's Avatar
bealljk
I can relate (except that 27psi part)...but trying different things and different methods. If it doesnt work move on to the next idea. Dont be afraid to fail or move on from an idea.
Keep the good work going Colombo
Old Apr 4, 2019 | 08:08 PM
  #471
Colombo's Avatar
i never planned to push this far. No where near it honestly. If I had I deff woulda went w a closed deck option and 625 studs probably. It’s been super good at 706whp for 3 1/2 years. We will see how long it holds above 800. Regardless it’s beena wild ride last few years on this block
Old Apr 5, 2019 | 04:08 AM
  #472
Staisman's Avatar
Staisman
Great numbers ! Are you still on RevUp oil pump pushing to 7900 rpm?
Old Apr 5, 2019 | 12:04 PM
  #473
Colombo's Avatar
yep been revving to 7700 for prob 3 years and about 6 months or a little closer to a year at 7900
Old Apr 6, 2019 | 07:12 AM
  #474
0taku's Avatar
0taku
Are you still running the 8.8:1 or did you switch to 11:1?
Old Apr 6, 2019 | 10:15 AM
  #475
Colombo's Avatar
motor that has been in the car for 3+ years now is on a set of 10:1 compression JE pistons
Old Apr 6, 2019 | 01:14 PM
  #476
Conway_160's Avatar
Conway_160
Damn!
When i called Z1 to ask about the safe limits of the Rev Up pump Jon recommend staying between 7200-7400.
It's good to see that the pump can run a little higher if need be.
Old Apr 8, 2019 | 08:17 AM
  #477
Staisman's Avatar
Staisman
What pulley setup u are using currently ?
Tochigi_236
Sep 27, 2015 03:40 PM
