Supercharger Dyno Numbers
Old May 15, 2017 | 12:11 PM
  #161
philthethrill's Avatar
philthethrill
Originally Posted by 350z006
is it a k060935rpm belt?
k060926rpm
Old May 15, 2017 | 12:49 PM
  #162
OldManZ350's Avatar
OldManZ350
Do you have side by side dyno's for comparison....?
Did the HP still fall off at 17psi?
Originally Posted by philthethrill
No additional power was made with the filter off, car is makimg high570s low 580s constantly but the jacksahft is getting louder and louder. Im getting it towed home and replacing bearings myswlf si ce i cant afford anymore 130.00 hpur rate. New belt is great btw no slip
Old May 15, 2017 | 01:10 PM
  #163
philthethrill
Yes, same with and without filter.
Old May 15, 2017 | 01:17 PM
  #164
philthethrill
If i ran the 3.12 id make same power just later. Move the power band. Seems tho 680 hp at the engine is the limit for stock heads and cams. But i will be having another tuner play with it once its fixed to see if any room is left.
Old May 18, 2017 | 12:45 PM
  #165
philthethrill
So afr was a lil rich. 11.7s idk but i thoughr 11.1 was wot .anyway maybe there is a few more ponies left on the table but prob not much. Like i said afr was 11.7 threw out the rpms
Old May 19, 2017 | 01:30 PM
  #166
BluestreamDE's Avatar
BluestreamDE
Are you still using the oem plenum? For non revup supercharged setups power seems to fall on its face after about 6200rpm. You can try the Revup lower plenum to help move the power band some more to the right but that will sacrifice some low end an midrange power, which may not be worth it to some ppl due to less grunt during normal driving. Same to the kinetix Manifold. Just my .02
Old May 27, 2017 | 12:31 PM
  #167
philthethrill
I'm running I'm running the M rev 2 with 5/16 spacer. I'll save my money for a Cosworth I don't like the kinetics or think it's worth the investment although I'm sure I'd pick up 15 or 20 horsepower. We also found a idler pulley that was hitting a bolt and shredding in that could be possibly the cause of the sound we've replaced it and haven't had a sound since but still waiting and testing trying to get suspension sorted but so far it's making consistent 580 wheel horsepower pull after pull
Old May 27, 2017 | 12:32 PM
  #168
philthethrill
I have the rev up but I guess I have a non rev up lower since I upgraded to that with the spacer I was thinking that if I would have done my original rev up with a spacer that would have moved powerband but probably not worth it enough I'll just save for a manifold I plan on doing that and cams and porting the heads. And 150 shot
Old May 30, 2017 | 06:04 AM
  #169
BluestreamDE
(Deleted)
Wrong thread.
Old Oct 20, 2017 | 06:42 PM
  #170
philthethrill
Installed kinetix, dyno 6th.if I lose a on of mid range I'll go back. I love making 510 torqe
Old Nov 16, 2017 | 02:51 PM
  #171
philthethrill
Old Nov 16, 2017 | 02:52 PM
  #172
philthethrill
614hp 505tq
Old Nov 16, 2017 | 03:56 PM
  #173
OldManZ350's Avatar
OldManZ350
Very Nice Phithethrill
Old Nov 16, 2017 | 05:19 PM
  #174
BluestreamDE
Might as well say mine.
1 Vortech V-3 SCi-Trim with 928 Motorsports Impeller
2 Vq35de Built Stock Block (11.1), Stock Heads and Cams
3 E85 Break-in Conservative Tune
4 3.12 Pulley, 34/28 Cog, Fluidampr, Ebay 31x4x12 Intercooler
5 467whp and 425tq with 5 Gal E85 and some leftover 93 in the tank
(15 Degrees Timing till 5600rpm, 13 Degrees till 7100rpm redline)
About 1,300 miles on Rebuild. Scheduling dyno time early Dec to tune myself and make more powa with more stable Ethanol content.
Old Nov 16, 2017 | 07:46 PM
  #175
OldManZ350's Avatar
OldManZ350
How much boost?
That is extremely retarted timing. I'm at 17 degrees at redline with just 93 octane and 19psi.
What are your ATI's during a WOT Run? I question your ebay IC. Treadstone makes some nice Intercoolers and I have a TR-1245. Hi ATI's will just kill HP
Old Nov 17, 2017 | 05:08 AM
  #176
BluestreamDE
Originally Posted by OldManZ350
How much boost?
Morning Oldman, This setup is running 15psI at 7100rpm.
Yes, this is because I was tuned conservativly due to not having an exact ethanol content to advance timing any more since the tune was a mix of 5 gal e85 and a a little over a gallon of 93. I have since adcance to 17° thru out the entire Rev rance and noticed more power from logging.
WOT temp go to about 25° above ambient after a full pull. I am purchasing a TR1245 this xmas.
Old Nov 17, 2017 | 12:34 PM
  #177
OldManZ350's Avatar
OldManZ350
The important Temp is during WOT, not after. Glad you are getting the TR-1245
Old Nov 22, 2017 | 09:36 PM
  #178
philthethrill
thanks old man, I'm doing heads, cam , ysi and some nitrous. Going for z g qt mile record next season or following.should be making 900s to wheel. Doing all lil bits know like axles drive shaft ect..
Old Nov 22, 2017 | 09:41 PM
  #179
philthethrill
Originally Posted by 4SHIZZIL
Master List:
1. Columbo 608/446
2. Gzilla/4shizzil 557/455
3. meanz 550/460
4. OLDManZ 540/436
5. unvmyg35 515/445
6. bealljk 455/420
7. str8dum1 455/405
8. Threads 438/392
9. iStan 313/282
need this updated
Old Nov 23, 2017 | 04:24 AM
  #180
BluestreamDE
Damn you are going all out, good luck!
