Fuel Pressure Gauge
Old Feb 8, 2004 | 08:34 PM
narkotic's Avatar
narkotic
Default Fuel Pressure Gauge
Today I installed a fuel pressure gauge ( the greddy 60mm one ). It has the external sensor. Well I installed it using one of the SPX fuel taps that people have been using for No2, but that is after the regulator. I noticed that the needle stays at about 3.6 bar the whole time until the 2nd fuel pump kicks in going to about 6 bar... Did I put the sensor in the wrong place? Should it be inline before the regulator on the small hose? If anyone installed a fuel pressure gauge please lend some information my way, it would be appreciated. And if I am supposed to put it in-line before the regulator then how do I go about tapping into that line the right way? Thanks alot guys
Old Feb 9, 2004 | 12:10 PM
narkotic's Avatar
narkotic
Anyone?
Old Feb 9, 2004 | 12:32 PM
etx's Avatar
etx
The sender should be anywhere between the fuel pressure regulator and the fuel rail. That is where the pressure you are concerned with is. I am not faliliar with that 'tap' but you should be seeing the same amount if fuel pressure all the time. The only thing that should produce a drop in fuel pressure is if the FPR uses a signal line to drop pressure at high vac operation. Or if your injectors are spraying so much fuel that the pumps cannot flow enought fuel to keep the presure up.
I have not delt with the Z's fuel system yet, but after looking at some pictures it dosen't look like the fuel rails have a test port. The test port is the ideal location for a fuel pressure sender.
Old Feb 9, 2004 | 01:42 PM
mprowe350's Avatar
mprowe350
I currently have the ATI kit w/ secound pump. My sensor is located after the sec. pump where the fuel is on the way to rail/reg.
narkotic's Avatar
narkotic
Interesting... I keep getting different answers from everyone. I hear to tap right after the filter BEFORE the regulator... I mean I used the SPX fuel tap which is what the dealers use to test fuel pressure, so this should be a good spot.. I get a constant reading until I really get on it then it raises (aux fuel pump kicking in for S/C)... thanks for the reply!
Old Feb 9, 2004 | 01:48 PM
SKiDaZZLe's Avatar
SKiDaZZLe
Charter Member #34
dude... fuel pressure is always 51psi (3 bar) until your 2nd pump kicks in...
this is why you have that second pump! because the car uses a returnless fuel system, and the pressure regulator is actually in the gas tank, right after the pump...
hth
Old Feb 9, 2004 | 01:51 PM
SKiDaZZLe's Avatar
SKiDaZZLe
Charter Member #34
also... you installed it correctly... its working perfect.
Old Feb 9, 2004 | 01:56 PM
narkotic's Avatar
narkotic
Where does that fuel line goto? Is it the smaller one that goes to the top of the regulator?
Old Feb 9, 2004 | 01:58 PM
narkotic's Avatar
narkotic
it's all starting to make sense now..
btw nice car
hth
Old Feb 9, 2004 | 02:39 PM
mprowe350's Avatar
mprowe350
The hose that mine is connected to runs up towards the top rear passenger corner of the motor. There is some kind of regulator there or a simular device which the hose connects to.
mike
Old Feb 9, 2004 | 03:23 PM
etx's Avatar
etx
Oh, I did not realise your using the bootleg fuel delivery method. I wouldn't trust that fuel pump any further than I could throw it. The fp going up if how that system gets more fuel through the injectors. Good idea installing a fp gauge, keep your eye on it because if that pump goes haywire your gonna detonate under boost.
apex locator
Jul 23, 2021 02:27 AM
sales@czp
Sep 23, 2019 03:30 PM
