NA/supercharger E85 build
Old Aug 5, 2021 | 08:28 AM
  #61
350z-Helsinki's Avatar
350z-Helsinki
My goals for the car aren't really about big power. Actually I'm really happy with the current power levels. What I would wan't is for the car to be extremely responsive and somewhat reliable. For response and track driving superchargers are great. They also generate less heat which is a problem when you track the car. To be honest if I'd start again I'd stay NA and spend my money on chassis. Now that I have gone through this route if something fails and I need to invest more money I guess gaining a little HP while I'm at it helps to keep the motivation up.
I thought about drilling a hole to the thermostat, but I just wanted to know for sure if bringing back the by-pass hose would solve the thermostat issue. I think the Z is fairly hard to bleed properly. It takes a while to get all the air out...
Old Aug 5, 2021 | 09:26 AM
  #62
bealljk's Avatar
bealljk
Get a smaller ball bearing / billet wheel turbo ... You can size-out your turbo to max-out at your power ceiling. A small turbo will be extremely responsive and you wont lose torque related to the belt driven blower. Your charge pipe and intercooler sizes will impact your lag as well. The heat is the same regardless of turbo or supercharged (albeit it's concentrated at the turbo).
I bleed my car in 10minutes but it's because I dont have a heater core nor any of the miscellaneous pipes running everywhere.
Old Aug 5, 2021 | 04:00 PM
  #63
DarkZ03's Avatar
DarkZ03
Worries me about the blower, but much like you a don't care for turbos and I don't like Vortech so if it's being too much of a pain then I'll go NA+nitrous
Old Aug 24, 2021 | 02:06 AM
  #64
350z-Helsinki
Do you track the car? I would say my car is impossible to bleed in 10 minutes. I've tried a funnel and a vacuum pump.
In order to fit the turbo I would need to remove my Tomei headers and get all new piping. I think it's just too much work at this stage when the only problem is the compressor. It's been a long road and I'm not keen on making it any longer. I just want to drive!
Old Aug 24, 2021 | 11:52 AM
  #65
bealljk's Avatar
bealljk
I mostly do straight line stuff and run the car around town ...
Yeah, my system is stupid easy to bleed bc I took out all the dumb stuff...
Old Jan 5, 2022 | 02:48 PM
  #66
Timboj's Avatar
Timboj
Hey Helsinki, hope the build is progressing okay. When you installed the fuel pump, did you drill out the venturi opening? CJM recommends it at least for idle control.
@bealljk Did you try the oil cooler delete without drilling the hole in the thermostat? Get the logic, but I'm wondering if it's necessary. I've got a Mishimoto racing (lol) thermostat so I'm hoping the lower threshold will be enough?
Old Jan 5, 2022 | 10:53 PM
  #67
350z-Helsinki
Yeah when I I did drill out the venturi, but that didn't solve my fueling issues, but now I'm good with the surge tank and rails.
Build progress is slow, but I will get the c38-91/92 for summer since it looks like there isn't enough room for the 112.
Old Jan 7, 2022 | 01:55 PM
  #68
bealljk's Avatar
bealljk
I did remove the OEM oil cooler (the mechanism that is sandwiched between the block and the filter). At one point in time I probably had a normal thermostat with no oil cooler but I will probably always drill the hole in the thermostat - it really makes bleeding the coolant system easy.
Old Aug 16, 2022 | 02:21 AM
  #69
350z-Helsinki
Default Some updates
-osgiken differential
-ast 5300 coilovers
-spl toe arms, camber arms and traction arms
-new wheel bearings front and back
-295 Nankang AR1 an​​​d 18x10,5 gram lights-new hks8555 supercharger
-better cooling-ducting for radiator and oil cooler- dual Spal fans to replace shitty Mishimoto items.
- custom apracing/akebono brakes
Logiqal
Jan 11, 2017 07:18 AM
Astennu
Aug 24, 2016 03:44 AM
GT4Zed
Mar 27, 2013 04:25 PM
mthreat
NA Builds
60
Sep 11, 2009 03:31 PM
kzanard
Oct 19, 2005 01:10 PM
