APS twin turbo water feed return T-pipe help
Old Feb 24, 2016 | 01:22 PM
Zivman's Avatar
Zivman
Default APS twin turbo water feed return T-pipe help
Finishing up my recent motor build and found out that I am missing my T-pipe that splices in for the water return:
APS part: 435-966-000
T-PIECE - 19mm OD x 68mm x 9/16" JIC
I had removed it a couple years back when installing my expansion tank setup. I am switching over to Evans with this build and want to remove the setup and just go back to the regular return with no expansion tank.
anyone know where i could get such a component? any other options?
Old Feb 24, 2016 | 01:59 PM
Doober's Avatar
Doober
Google "Radiator hose fitting adapter" and from there you should be able to find something...get your 19mm ID size, and you might have to dig around for the 9/16 JIC to thread into the adapter but I'm sure its out there.
I had to do some searching for the fittings to re-create the setup that APS uses to T off for the oil feed to the Single turbo. I finally found a shop that was like 15 minutes away from home. Had to make a couple changes, and it was expensive, but i learned that there is a fitting out there for everything.
Old Feb 24, 2016 | 02:10 PM
Doober's Avatar
Doober
Actually I searched around a little more because I was curious...
what you want, if you cant find the ACTUAL APS piece, is a "water temp sensor adapter."
They are setup the same way. T into your coolant hose, and you will probably just have to find a 1/8th NPT to 9/16 JIC fitting.
Seems like this is the only 19mm one I can find: http://www.mattlewisracing.co.uk/pro...308787bb2d12c0
Old Feb 24, 2016 | 03:07 PM
rcdash's Avatar
rcdash
Can maybe just get a tee with the appropriate ends as separate fittings from summit racing. You could also simplify plumbing by running the output of one turbo to input of the other and then you just have a single return. With Evans, it's not going to boil and I doubt the one turbo heats up the volume of coolant flowing through it more than a couple degrees anyway. Dynosty ran it that way for my custom set up. Turbos clocked about 10 degrees with exits higher than entrance.
Old Feb 24, 2016 | 06:36 PM
Zivman's Avatar
Zivman
exactly what I was finding....
that is the way the APS kit is setup. only a single return feed up where the stock bleeder is.
I'll have to keep looking and see if I can find it around my buildings
Old Feb 26, 2016 | 06:46 PM
Zivman's Avatar
Zivman
I think I have it figured out.
what I need to confirm is that I can use AN fittings with JIC... that i am fairly confident with.... now:
is JIC 9/16" the AN equivalent of -6?
Old Feb 27, 2016 | 09:33 AM
Doober's Avatar
Doober
looks like it according to this chart: http://brennaninc.com/documents/BrennanThreadChart.pdf
and https://en.wikipedia.org/wiki/JIC_fitting
Old Feb 29, 2016 | 06:28 AM
Zivman's Avatar
Zivman
This is is what I am hoping for.
just need my mechanic to get down one more night to get the rest of this thing together so I can get it back in the car. I am running out of time. if I don't get it together this week, I'll be busy farming and won't have time to get it tuned till the fall......
Old Feb 29, 2016 | 05:07 PM
Zivman's Avatar
Zivman
for those interested, here is the hose adapter I purchased. shipping was very fast:
19 mm hose adapter
Old Mar 2, 2016 | 08:08 PM
whitecat's Avatar
whitecat
I ended up feeding and returning each coolant lines separate on my setup. This is the part I used.
http://www.ebay.com/itm/BOOSTEC-Forg...dVReYv&vxp=mtr
Old Mar 3, 2016 | 05:15 AM
Zivman's Avatar
Zivman
that one is perfect. thanks for the link!
Angel Dlc
Jun 29, 2016 08:05 PM
Doober
Mar 14, 2016 05:34 PM
christoc
Feb 29, 2016 09:32 AM
BossDJ
Feb 24, 2016 01:03 PM
EnjukuRacing
Body Interior
Feb 19, 2016 07:48 AM
