Questions about rods and boosting
Old Jul 25, 2016 | 01:26 PM
DreamZcometrue's Avatar
DreamZcometrue
Default Questions about rods and boosting
Okay... I've done research, I have money. I have a three questions that Im not 110% sure about. And I want to be positive.
1. What's the next weakest link after rods?
2. Do I need to lower the compression?
3. I know the stock rods won't last terribly long if I boost, but if I just upgrade the rods should it run reliably on 8 lbs of boost?
I know I will want more power in the future, but I don't have the money to build the engine completely but I do plan to.
Old Jul 25, 2016 | 02:17 PM
TT03Z's Avatar
TT03Z
If you are going to tare the engine down far enough to do connecting rods I would most certainly replace at least the pistons as well. Weisco makes a cost effective piston in 8.8-1 and in 11-1 compression. If you are doing boost I would suggest going lower compression. And as long as the heads are off for rods and pistons I would also upgrade the head bolts and head gaskets. My $.02. This is not something you want to cheap out on. If you are on a limited budget I would wait save the money up and do it right if you plan on disassembling the engine to upgrade.
Old Jul 25, 2016 | 05:57 PM
rcdash's Avatar
rcdash
^ agree. A basic shortblock build is pretty much cookie cutter these days from the reputable shops. Save up to do it all at once.
Old Jul 25, 2016 | 07:21 PM
DreamZcometrue
Great advice. Will be taking it. Thanks a bunch guys!
Old Jul 26, 2016 | 08:43 AM
Dynosty's Avatar
Dynosty
Vendor - Former Vendor
8 PSI should not be a problem on the stock engine with a good tune. I agree with the others- if you are going to upgrade rods then upgrade pistons at the same time.
GodISmE
Aug 12, 2019 02:27 PM
tuko316
Brakes
30
Dec 10, 2016 06:57 AM
Inspector71
May 25, 2016 10:14 AM
Swiggin
May 7, 2016 11:36 AM
Swiggin
May 3, 2016 04:07 PM
