northeast dynosty build aps tt
Old Jan 8, 2018 | 02:01 AM
  #101
35reilly's Avatar
35reilly
Originally Posted by silva350z
Its different from the momentum kit
Here is the crossover pipe from one header to another and just above it is the 3.5in midpipe that connects up to the 3.5in down pipe to the turbo . Very tight squeeze into the bay. 3in piping would be a much better fit here.
Crossover pipe then goes to an s pipe that fits very tightly around the steering joint and motor mount along the side of the block. When turning the wheel i found that i had a little clearance issue on the steering joint, I couldnt make a full turn. So i just raised up the joint.
The s pipe then conects to the turbo mount underneath the sway bar
As far as ac is concerned i need to make custom lines
Im assuming Hal made this as a custom kit? Only kits I can think of that are produced or were produced were 3 inch 😞. What flange are you running on the turbo? T4?
Old Jan 8, 2018 | 04:12 AM
  #102
silva350z's Avatar
silva350z
Originally Posted by CK_32
What did you use to paint that timing chain cover?
Dynosty powder coated the cover low gloss black
Old Jan 8, 2018 | 04:14 AM
  #103
silva350z's Avatar
silva350z
yes and yes , the kit was completely custom made and its a t4 flange.
Old Jan 8, 2018 | 02:54 PM
  #104
35reilly's Avatar
35reilly
Who makes that rad? Gonna be nice tho. That turbo is beautiful!!!
Old Jan 9, 2018 | 02:50 PM
  #105
silva350z's Avatar
silva350z
Did some wiring today for the map sensor and flex fuel sensor
Old Jan 11, 2018 | 09:24 AM
  #106
silva350z's Avatar
silva350z
Put my new bandsaw to work and made a new coolant pipe to connect to the radiator.
Only have it tacked up for now
Old Jan 11, 2018 | 09:38 AM
  #107
bealljk's Avatar
bealljk
Very smart on the coolant pipe...
I used a steel braided hose which made things way easier with the greddy passenger side blower!
Old Jan 11, 2018 | 02:12 PM
  #108
silva350z's Avatar
silva350z
Old Jan 11, 2018 | 05:14 PM
  #109
Conway_160's Avatar
Conway_160
That looks Sick as Fck, are you going to run a filter or just a screen over the turbo inlet?
Old Jan 13, 2018 | 10:59 AM
  #110
silva350z's Avatar
silva350z
I'm just going to do the turbo guard screen
Old Jan 13, 2018 | 01:57 PM
  #111
35reilly's Avatar
35reilly
So who makes the rad?
Old Jan 13, 2018 | 08:36 PM
  #112
CK_32's Avatar
CK_32
Look into a K&N filter or foam filter if you can.
Supposedly screen guards ruin the vortex and air flow into the turbine inlet more than filters. Don't ask me how but I've seen that stated on several forums from some big name drag guys. I was going to go screen guard my self until I read that. Also adds the EXTRA level of protection against fine dust and dirt which will ruin bearings and seals of time.
Old Jan 13, 2018 | 11:12 PM
  #113
bealljk's Avatar
bealljk
if it was me - I'd run a ~4" duct w/filter away from your IC & radiators? why heat your intake charge if you dont have to?
Old Jan 14, 2018 | 11:55 AM
  #114
CK_32's Avatar
CK_32
Yea I'd run a charge pipe out of the bay but I'm just saying screen is appariently worse than a filter. Filters also keep the tube way cleaner.
Old Jan 14, 2018 | 04:15 PM
  #115
silva350z's Avatar
silva350z
Saldana racing products
Old Jan 14, 2018 | 04:17 PM
  #116
silva350z's Avatar
silva350z
I wanted to run a filter but i need that spot to mount my oil cooler. I can't run my oil cooler on the passenger side like before because the intercooler piping is in the way.
Old Jan 15, 2018 | 02:45 PM
  #117
silva350z's Avatar
silva350z
Finished welding the upper radiator pipe
Old Jan 15, 2018 | 02:53 PM
  #118
silva350z's Avatar
silva350z
Powder coated the coolant overflow reservoir and mouted it
Old Jan 16, 2018 | 02:12 PM
  #119
silva350z's Avatar
silva350z
Managed to fit the oil cooler on the passenger side so the driver side is free for me to use a filter now
Old Jan 16, 2018 | 02:30 PM
  #120
silva350z's Avatar
silva350z
Using a fuse block to run alot of my accessories, fuel pumps, haltech wideband controller, gauges , ect, i tryed out fabric sleeve heat shrink thru the inside of the car its cheap and looks awsome.
