How many lbs with vortech?
Old Apr 26, 2004 | 09:40 PM
350zer's Avatar
350zer
Default How many lbs with vortech?
I was wondering what other people with vortechs are get in the way of boost. Today I recorded the split second box with my laptop and the highest boost it saw was 6.4 lbs at 6845 rpm. I have wideband and boost gauge on order so that is the only way I could get boost for now. Vortech said it was lower because 8 lbs is with stock car, no mods.
Old Apr 27, 2004 | 05:59 AM
tig488's Avatar
tig488
i was getting around 8.2 @ 6800
Old Apr 27, 2004 | 06:01 AM
zimbo's Avatar
zimbo
Last time I hooked up to my laptop it showed 8.5 lbs of boost, but the time before that I wasn't getting full boost and it turned out to be due to a loose belt.
How tight is your serpentine belt?
--Steve
Old Apr 27, 2004 | 07:12 AM
fluidz's Avatar
fluidz
7.8 at 6,600
Old Apr 27, 2004 | 09:56 AM
dollar99's Avatar
dollar99
I've hit .65 bar once or twice, but I'm constantly hitting .6 bar at 6700 rpm. My ecu isn't reflashed, but my rev limitor doesn't kick in until 6800 for some reason.
Old Apr 27, 2004 | 08:33 PM
350zer's Avatar
350zer
Default lbs of boost
--Steve
could you here it slip? what were you getting before you tightened the belt? how tight should it be? thanks for any info.
Old Apr 28, 2004 | 03:47 AM
zimbo's Avatar
zimbo
I could not hear it slip. Before I tightened the belt the boost was falling off at around 4psi.
IMO, if the car is cold and you can turn the serpentine belt upside down without difficulty then it's definitely too loose. In my experience it tightens as it warms up so IMO you want it so you can't quite flip it upside down cold.
--Steve
Old Apr 30, 2004 | 05:47 PM
booger's Avatar
booger
I had the guy at the shop ride with me and watch the gauges .Got on the interstate and did a run from 3rd through 4th [AT5] . I took it to 7,500 rpm on my tach in 3rd....[I know its off] and got 10.2 lbs of boost . A/F never dropped down passed 11.2 to 1 . Im wondering if the boost gauge is right. It comes calibrated , but it was more than likely done at a different elevation. So i'll read the book on it and see if I can recalibrate it
Old Apr 30, 2004 | 07:40 PM
zimbo's Avatar
zimbo
If your rev limiter has been raised you'll definitely see more than 8 psi under normal conditions. The "true" way to see the boost level is to drive with the R4 connected and have a friend watch the fuel map while you go to WOT. Or better yet, use the record feature (see my other thread to that effect).
--Steve
Old Apr 30, 2004 | 09:52 PM
booger's Avatar
booger
Gonna have to buy a lap top .Looks like there is a alot of nice features to the R4 ,Zimbo....do you run the com port through the fire wall ? Installer said he had barely enough room to get the split sec. wiring though there
Old Apr 30, 2004 | 10:52 PM
bigern1970's Avatar
bigern1970
Default r4
Does the r4 and laptop hook up to the SS box or does it hook up to the cars ECU?
Old May 1, 2004 | 03:57 AM
zimbo's Avatar
zimbo
The software connects to the SS box which is in the battery compartment (at least in my case it is--I'm assuming everyone's is like that).
I don't have my serial cable permanently installed. I just take off the entire battery cover and run the serial cable under the hood and up past the windshield wiper and into the passenger-side window.
--Steve
350Z_Al
Oct 29, 2020 07:44 PM
sales@czp
Sep 23, 2019 03:30 PM
bcoffee20
Nov 19, 2015 06:39 PM
Rowlett
Misc.
Oct 2, 2015 10:38 AM
EnjukuRacing
Sep 30, 2015 06:55 AM
