Vortech Oil Return Other Options Pic
Old May 8, 2004 | 09:40 AM
bigern1970's Avatar
bigern1970
Default Vortech Oil Return Other Options Pic
Do you think the oil return set up For JWT, Will work with the Vortech SC . so you dont have to do any drilling its now offered by JWT Separately
Attached Thumbnails Vortech Oil Return Other Options Pic-vq-oil-pan-spacer-installed-small.jpg
Old May 8, 2004 | 10:47 AM
350zer's Avatar
350zer
Default Re: Vortech Oil Return Other Options Pic
you still have to drill a hole. there is no hole on the oil pan.
Old May 8, 2004 | 12:14 PM
n8vz's Avatar
n8vz
you also increase your oil capacity by a quart
Old May 8, 2004 | 12:51 PM
teh215's Avatar
teh215
If I hadn't already drilled the oilpan, I would get this instead.
Old May 8, 2004 | 02:29 PM
baptist's Avatar
baptist
Would that JWT item tapping be above the oil level, though???
Doesnt look high enough to me.
Old May 8, 2004 | 02:32 PM
tig488's Avatar
tig488
hmm, it looks like they somehow aluminum welded that inch wide sleeve onto the block and tapped that, its not above the oil line tho, i guess you could try and let us know.
Old May 8, 2004 | 07:42 PM
bigern1970's Avatar
bigern1970
Actually the tt version has a J spout that comes out and pours above the level
Old May 10, 2004 | 03:56 PM
G3po's Avatar
G3po
Default JWT pan
Bigern1970 is that a pic you shot at the JWT shop?
If so , got any more?
Any more info on when the full TT kit will be released?
Old May 10, 2004 | 04:38 PM
350trackz's Avatar
350trackz
I was thinking the same thing. No other FI kit out there empties above the oil line. This is the option available for the JWT turbo, the PE turbo empties to the top of the pan and the Greddy the same. Why would this not work for Vortech ?
Old May 10, 2004 | 04:46 PM
bigern1970's Avatar
bigern1970
Default Re: JWT pan
Actually its on their site. I saw it in person, and verified that the spacer you see is for the sole purpose for adding more oil. The picture with the return line is the example of how the spacer will fit.I talked to Ben Pilas today at JWT, he said they are not going to sell the TT return version as of now, who know maybe in the future they willl..By the way the spacers are on 3 week back order
Old May 10, 2004 | 04:48 PM
bigern1970's Avatar
bigern1970
Talked to JWT today the spacer would have to be modified, because they are not releasing the TT oil return version separately
Old May 10, 2004 | 04:51 PM
350trackz's Avatar
350trackz
Question still remains ...
If you were to drill the spacer instead of the oil pan, use the Vortech supplied return, why would this not work ? I have been looking for a way to n ot drill the oil pan for some time. I am just about ready to order the PE or ARC oil pan and drill the top of it out and put the Vortech return in it. This is MUCH less expensive !!!
Old May 12, 2004 | 11:26 AM
ForceInduction's Avatar
ForceInduction
For a second I thought the tread was about this....
Old May 12, 2004 | 01:07 PM
G3po's Avatar
G3po
Default oil return
That adapter is part of the solution on the oil "feed" side.
What people are looking for is a bolt on solution on the "drain" side.
If you buy the JWT "NA" pan extender, not only should it be drilled and tapped , but a a "j-pipe" must be fitted inside to get the drain point above the oil level. Apparently this is exactly what JWT does in the TT kit. If Vortech adopted this solution, it would attract a few more DIY buyers.
Old May 12, 2004 | 02:02 PM
teh215's Avatar
teh215
Technically this will give the oil a return path to the pan but, I don't think it is a good idea after reading this thread again. The Vortech oil return is a gravity drain line. If it is below the oil level that *may* mean that the oil will not drain properly, or quickly enough, from the SC head unit allowing oil to get very hot inside the SC and break down. My 2¢.
350Z_Al
Oct 29, 2020 07:44 PM
