vortech r4 settings
Old Jul 29, 2004 | 06:27 PM
freezeg35's Avatar
freezeg35
Default vortech r4 settings
Once i get the baseline install done i want to get the system tuned. Could someone tell me what the sequence is to create a new custom r4 file so i dont have that aux fuel pump not coming on problem. Also what is recommended in the secondary fuel pump rpm AND psi? I see some people have it quite low others are at 2.9 psi. Im thinking 1000 rpm and 1psi?
Old Jul 29, 2004 | 06:39 PM
zimbo's Avatar
zimbo
Mine has always been set to come on at 3000rpms and 2.5 psi. The additional fuel pump is not needed before then, IMO.
---Steve
Old Jul 31, 2004 | 08:46 AM
dfw350z's Avatar
dfw350z
Default Output Settings
Is this how yours is set?
Old Jul 31, 2004 | 10:38 AM
zimbo's Avatar
zimbo
Yep, that's pretty much how I have mine set.
--Steve
Old Jul 31, 2004 | 10:54 AM
booger's Avatar
booger
Its rpm OR preasure......not AND......right ?
Old Jul 31, 2004 | 11:40 AM
zimbo's Avatar
zimbo
I think the AND setting is better. No need for the pump to come on at 3000 rpms if the boost is 0.
--Steve
Old Jul 31, 2004 | 01:50 PM
teh215's Avatar
teh215
--Steve
Agreed. Too much unneeded fuel could potentially cause the oil on the cylinder walls to break down and increase the friction between the rings and the cylinder walls. This would cause premature ring wear, blow-by and potentially increased oil consumption. I believe it is referred to as "fuel wash" ... my 2¢.
Old Jul 31, 2004 | 05:53 PM
booger's Avatar
booger
The fuel preasure ...when the aux.pump is on...is at the FMU and your motor doesnt see that extra preasure . The FMU increases fuel preasure to the injectors as needed with boost . The only think about having the Aux pump coming on sooner is that its working [or on] when it not needed . Its not going to hurt your motor with extra fuel
BEBO'S ZEE
Jun 7, 2016 07:48 AM
NissanZcrazy
Nov 2, 2015 06:03 PM
kevinapex
Jul 29, 2005 06:26 AM
Rogue350z
May 17, 2005 08:22 AM
gersteinp
Feb 24, 2005 08:49 PM
