Vortech made a spit/sputting noise around 6500 rpms
Old Aug 16, 2004 | 04:01 PM
Houston G35's Avatar
Houston G35
Default Vortech made a spit/sputting noise around 6500 rpms
I heard a new sound today that made me worry. At full throttle, around 6500 to 6800 rpms, the engine made a sound that is hard to describe. The best way I can describe it is that is sounded how I imagine a clogged injector might sound as it tries to force gas out. Could this be the injectors dumping fuel? I remember John at Grubbs telling me that they took massive amount of timing out up top and they made it very rich at 6800 rpms. If I remember correctly, he said they would in essence act lake a governor. Does any of this make sense? It is so difficult to describe sounds in print.
I am not sure if this was pinging, as I have never actually had someone point out to me exactly what pinging sounds like. It was not high pitched, but there were very distinct sounds that were close together and numerous. I heard these noises with the windows up and the radio off.
I intend the take the coupe to a shop this week to have it checked out. In the meantime, I will take it easy on the engine. Any thoughts?
Old Aug 16, 2004 | 04:23 PM
booger's Avatar
booger
I had mine on the dyno when tuning the 3.125 pulley . Had so much fuel going in that it popped at high rpm's. But Yours sound like its making a diff. noise . I havent heard ping either , so take it easy till you get it in . You may have gotten some bad gas and it is pinging...good luck....bill
Old Aug 16, 2004 | 05:27 PM
bigern1970's Avatar
bigern1970
Default Re: Vortech made a spit/sputting noise around 6500 rpms
Pinging sounds like a bunch of metal ***** ( like bee bee gun *****) if you were to take them put them in a coffee can and shake them up sounds real tinny ..........thats detonation(pinging) trust me I learned the hard way during my honda days
Old Aug 16, 2004 | 08:10 PM
Houston G35
bigern,
If only I could do it again without any consequenses!! I would say your discription is very close to what I heard, but put cotton ***** around the coffee can.
Maybe I will get to the bottem of this in the next few days.
Old Aug 16, 2004 | 08:21 PM
lorinserbenz's Avatar
lorinserbenz
Was the ECU reflashed ? Your sig says you have a 04 Automatic so I dont think you do since the 04 flash isnt available yet.
....... it sounds like you are hitting the rev limiter.
I have auto too and have hit the rev limiter and it scared the crap out me.
Old Aug 17, 2004 | 05:13 AM
t32gzz's Avatar
t32gzz
What boost were you running? Do you know the peak value? I changed my plugs to Denso Iridiums, 2 steps colder, and under 8.5 psi, I have a lag at around 6200 rpm's. It does not really produce a sound, but rather, it sounds like the car pulled timing for just a second. The WBO2 is reading at around 11.4 and is not moving, so I know mine is not fuel.
The best way to describe it is almost as if the motor hesitates for just a second. I think this may be an issue with the plugs, as it did not happen with my old plugs. I am having the plugs changed as soon as I can get a new set. I will let you know what I find out.
Old Aug 17, 2004 | 07:30 AM
dfw350z's Avatar
dfw350z
Default Miles
How many miles do you have on your Vortech?
Did you get the Oil change issue resolved?
Old Aug 17, 2004 | 07:49 AM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
If you felt a power loss and sputter/spit noise, it's probably not pinging. Could be a misfire or bad plugs or whatever. The pinging sounds like metallic rattling noise...very distrinct. Instead of your motor sounding smooth and vrrooooom...it its like vrooom..rattle...rattle.
Old Aug 19, 2004 | 01:06 PM
booger's Avatar
booger
Houston......Did you find out what the trouble was oon your car ?
Old Aug 19, 2004 | 06:02 PM
Houston G35
Booger,
Not yet. I've been real busy this week (catching up from vacation last week). I will try to get to the shop early next week.
Obadabot
Jun 18, 2023 11:31 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
samansharif
Sep 25, 2015 12:31 PM
