Update: Ultimate Racing TT install
Old Aug 26, 2004 | 01:07 AM
aalzuhair's Avatar
aalzuhair
Thumbs up Update: Ultimate Racing TT install
Hi all,
First of all, during the install we noticed some differences in specs between US and SA, this include the radiator, which has 2 rows instead on one and the deferential housing, which is fined all over. I guess this is directly related to the differences in temperatures between the two countries.
Anyway, back to the install, overall, the install is going smooth, the only thing that is delaying the completion is me I keep on upgrading things as we are installing.
Ok, this picture shows the deferential housing and the fins
The mufflers. Before we installed the TT I toke the car for a spin with the new exhaust system, man it sounded really aggressive. The white stuff is from painting the car, I blocked the little holes behind the rear emblem and a door dent
Another picture of the deferential housing. As you can see the piping is so close to it, and it was touching the housing cover, so we had to shave off a bit of the fins from the left side
Some more
Intercooler. We had one setback here on the SA specs just like the europen specs we have the headlights washer thing, so that had to go. And I will use the button inside the car (Stock look) and the pump to spray the intercooler with water, the good thing I can use the same windshield washer tank to supply water to it.
One of the things I wanted to upgrade was the oil return lines. I did upgrade them to stainless steel and AN fittings. The driver side was ok, but on the passenger side the thing keeps on bending, so I’m going back to what Darryl suggested in the first place normal fittings
In this picture you can see the hose and all that space around it. Man if I can only take some of that space to the other side, that would be great
Dump pipes
I’m planning to shield off the fuel feed lines.
The quality of the pipes is great, I'm really happy with the kit.
Can you see the little K&N breather filter. One in the front and one in the back
I will keep you all posted. Happy Zeeing
Az
Old Aug 26, 2004 | 06:07 AM
kudos's Avatar
kudos
Looks great man, good luck.
Hope you get it running just in time for the good weather. Keep us posted.
Old Aug 26, 2004 | 06:22 AM
ColecatZ's Avatar
ColecatZ
looking good so far, congrats.
Will be waiting for follow ups.
Old Aug 26, 2004 | 06:30 AM
daddyz's Avatar
daddyz
Thats a nice set-up! Keep up the good work.
Old Aug 26, 2004 | 10:59 AM
turbo-maxima's Avatar
turbo-maxima
looks nice
Old Aug 26, 2004 | 02:38 PM
aalzuhair's Avatar
aalzuhair
Thanks guys
Old Aug 26, 2004 | 02:48 PM
accordfreak's Avatar
accordfreak
i like the wastegate setup.. open loop..
the quality of the kit looks really good too.
Old Aug 26, 2004 | 08:35 PM
AmyCroft's Avatar
AmyCroft
Smile aalzuhair - a question?
Originally posted by aalzuhair
Thanks guys
Hello..
It took a little while to figure out the TT plumbing..
But the "Kit" does make sense.. I think you will be fine with UR..
The "High Temp" differential looked familiar.. With the case fin's and Finned rear plate.. The question I have is : What is your "Final Drive Ratio" ?
3.51, 3.76 ? ?
BJ at Evo350 has a 3.90 Rear drive... That would be good for track use.. Poor for high speed or daily use..
Reply when you can..
Cheers Amy -
Old Aug 26, 2004 | 11:35 PM
350Now's Avatar
350Now
Looks good.. keep us updated when you can.
Old Aug 27, 2004 | 01:50 AM
aalzuhair's Avatar
aalzuhair
Default Re: aalzuhair - a question?
Originally posted by AmyCroft
Hello..
3.51, 3.76 ? ?
Cheers Amy -
Hi Amy,
The final drive ratio is 3.538 according to Nissan Middle East 350z ME
Az
Old Aug 27, 2004 | 04:31 AM
Spy Guy's Avatar
Spy Guy
Default Re: Re: aalzuhair - a question?
Finally you've done it!!
all the best...
Mr Aryan from Gulfgt.com (Bahrain) ..
Old Aug 27, 2004 | 06:29 AM
etx's Avatar
etx
Ick, That's a terrible location for your o2 sensor. Don't expect it to last long mounted like that. It's supposed to be mounted from -45* to +45* to keep condensation from forming on it and cracking the element.
Man, Those half shafts look beefy, I never took a good look at them until now.
Old Sep 4, 2004 | 06:59 AM
aalzuhair's Avatar
aalzuhair
Default Pics update
Here you can see that I blocked the rear emblem holes... bye bye emblem(s)
Attached Thumbnails Update: Ultimate Racing TT install-dsc00578.jpg
Old Sep 4, 2004 | 07:02 AM
aalzuhair's Avatar
aalzuhair
In the pic above you can see the fuel lines and fittings in the UPS box I got today. Anyway, here is another pic of the engine bay
Attached Thumbnails Update: Ultimate Racing TT install-dsc00580.jpg
Old Sep 4, 2004 | 07:05 AM
aalzuhair's Avatar
aalzuhair
Radiator overflow tank
Attached Thumbnails Update: Ultimate Racing TT install-dsc00581.jpg
Old Sep 4, 2004 | 07:07 AM
aalzuhair's Avatar
aalzuhair
FPR and new fans
Attached Thumbnails Update: Ultimate Racing TT install-dsc00583.jpg
Old Sep 4, 2004 | 07:11 AM
aalzuhair's Avatar
aalzuhair
From the front.
Anyway, the car will be out tomorrow and I will be doing some fine tuning on the e-manage, and in about a week time I should take it back to install the Cusco RS LSD
Attached Thumbnails Update: Ultimate Racing TT install-dsc00584.jpg
Old Sep 4, 2004 | 07:43 AM
Spy Guy's Avatar
Spy Guy
hey man, which garage is doing all this work for you? what's the name and location?
Old Sep 4, 2004 | 12:22 PM
aalzuhair's Avatar
aalzuhair
It’s Nissan (Al-Hamrani) doing all the work and I’m supervising all the work with Darryl’s’ help from Ultimate Racing.
Depravity
Oct 1, 2015 04:49 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
