14.5 psi tonight
Old Sep 20, 2004 | 07:40 PM
ravaz's Avatar
ravaz
Default 14.5 psi tonight
Tonight I was out doing some road tuning because I installed 650cc injectors. It was 55 degrees tonight and made a few WOT runs at 9psi, which is what I was tuning for. I got it dialed in pretty quick, about 3 or 4 pulls in 3rd gear, and 4th, this is on 100 octane. I decided to make a map for some higher boost, about 12psi. I was running out of gas so I went home and threw 5 gal of 112 octane for the high map. Went back out and richened it up a little and let her rip. I really didn't mean to, but I ended up hitting 14.5psi. So I richened it up a little a little more, like 11.0 A/F at redline and said screw it lets go for broke. Made a 2nd - 5th gear pull on the highway. EGT's were about 540 celcius, J&S pulled 2 degrees of timing out, but that could have been some road noise or the turbos spooling being that I turned up the sensativity **** a bit. Some how my stock clutch is still alive, but I did smell clutch.
Some how, my motor made it. Maybe it's the 112 oct, the cool weather, or maybe the J&S. Either way, if I didn't have the J&S I wouldn't hae even attempted this. Props to John for making the J&S Safeguard, I'm sure without this my motor would have been gone already.
Old Sep 20, 2004 | 07:42 PM
slay2k's Avatar
slay2k
hey, I just realized that ravaz backwards is ZAVAR.
AHAHAHAHAHAHAHAHAHAH.
Owned.
Old Sep 21, 2004 | 09:21 AM
JimRHIT's Avatar
JimRHIT
what is Zavar?
good job bill, do you plan on keeping the boost levels that high for track use, or was this a "why not" type of experiment?
Old Sep 21, 2004 | 10:42 AM
ravaz's Avatar
ravaz
I'll just run 9.5 daily, and up it to like 11 when I run someone or go to the track. Last night was just a why not, lets go for broke and put the new motor in if it blows up. It held up, but who knows for how long..
Old Sep 21, 2004 | 10:57 AM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
amazing things can happen with 112 octane fuel.
Old Sep 21, 2004 | 11:15 AM
350Zteve's Avatar
350Zteve
Is this on stock internals?
Old Sep 21, 2004 | 11:16 AM
ravaz's Avatar
ravaz
Yes, stock motor.
Old Sep 21, 2004 | 11:20 AM
Sharif@Forged
Forged Performance
how does the car idle and cruise with the 650 injectors? Do you notive a rougher idle or rich condition? Did you TS reflash for it...or just scale with eManage?
Old Sep 21, 2004 | 11:31 AM
ravaz's Avatar
ravaz
No TS reflash. Just used the map that came with the E-Manage, and scaled them. I had to modify the map alot, it didn't want to idle at first, and when I turned my AC on it got lean as hell, and would just stall, it drove like **** and just ate my gas. Got it fixed now and runs just fine.
Bill
Old Sep 21, 2004 | 12:33 PM
350Zteve's Avatar
350Zteve
Originally posted by ravaz
Yes, stock motor.
Damn impressive!! With that kind of boost, your well over 500rwhp. Just goes to show that the stock internals are not all that weak. It's all about the tune.
Old Sep 21, 2004 | 12:52 PM
ravaz's Avatar
ravaz
I agree, a good tune goes a long way. I'm sure it will take the power, but it might take it for only a week, who knows. I might have screwed something up last night and not even know it yet, but then again, it might be just fine. We'll see what happens.
Old Sep 21, 2004 | 01:16 PM
JeffR116's Avatar
JeffR116
***** man. You've got *****.
...Or the money to back it up
Old Sep 21, 2004 | 05:19 PM
dueche's Avatar
dueche
I thought you had a built motor
Old Sep 21, 2004 | 06:37 PM
ravaz's Avatar
ravaz
*****, yes. I do have a built motor, but not complete.
I ran it up to 13.5 tonight a few times. Punched it from an 80mph roll and she started to go sideways. I think I'm done abusing it, not.
Old Sep 21, 2004 | 09:07 PM
7 eleven's Avatar
7 eleven
Default Dyno!
Come on, it would be great just to see those numbers. I'll say that I don't have the ***** to run that much psi.
You'd be the first 500+ on stock internals. I think you get a bowl of soup for that.
Gary
apex locator
Jul 23, 2021 02:27 AM
seagrasser
Oct 11, 2015 03:27 PM
Detailed Image
Cleaning & Detailing
Sep 18, 2015 11:43 AM
