which cams to go with
Old Oct 10, 2004 | 12:58 PM
booger's Avatar
booger
Default which cams to go with
The engine rebuild should start soon . In wondering what cams to go with . JWT....and get good top end power ? Nismo....and get good power in the lower and mid range ? Or is there other cams I could go with ? My set up is going to be...9 to1 pistons and Vortech SC with either the 3.12 or 2.87 pulley.....Oh....does Nismo have more than one set of cams..with diff. lift and duration ? thanks.....Bill
Old Oct 10, 2004 | 01:28 PM
GMADD's Avatar
GMADD
Good quetion,
I too would like to know.
I'm getting the 9.0:1 pistons too and a TT kit as well.
I thought the nismo ones give mid to top end power, no low end
is this true ?
Tasso-
Old Oct 10, 2004 | 01:40 PM
whosdady's Avatar
whosdady
Booger you know my thoughts concerning cams and a 5AT. The Nismos will help throughout the powerband. If you need more high end power turn up the boost on the SC. The only downside is that the Nismos cost a little more.
Old Oct 10, 2004 | 01:44 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
For FI, I would go with a cam who's intake and exhaust profiles are near equal to each other. The staggered setups out there for these car are staggered in the reverse of what a forced induction car wants.
Old Oct 10, 2004 | 01:51 PM
booger's Avatar
booger
Yes and thanks again for your advise . Just looking for some other opinions . I will more than likely go with the nismo's . I know there are other cams out there and was wondering if any one has tried some thing different....Bill
Old Oct 10, 2004 | 08:30 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
How about the mildest of the Tomei cams? I am leaning towards Tomei if I do the cam swap, simply becuase a few people have used them already with F/I setups.
Old Oct 10, 2004 | 08:55 PM
mchapman's Avatar
mchapman
Tomei let you buy their cams in pairs, so you can run different cam specs for the intake and exhaust. Ive seen skylines etc which run different intake and exhaust cams so id find out what the benefits/differences are and then decide.
You could probabally look at what people have done with the 300zx and use similar techniques on your TT 350zs. See what works for them in terms of cam setups, not exact specs of course.
Old Oct 11, 2004 | 06:36 AM
NismoGCoupe's Avatar
NismoGCoupe
Default Re: which cams to go with
Nismo came out with a few new set of cams a couple months ago but not sure if there ideal for FI your gonna have to check the specs on them, I think there called Nismo S1 Cams I think theres 3 different set.
Old Oct 11, 2004 | 06:49 AM
Sharif@Forged
Forged Performance
I am kinda cam stupid here...but if I bought a cam that only increased lift, but not duration, would that give me some power gains without upseting my idle?
Old Oct 11, 2004 | 09:01 AM
350zSpeedRacer's Avatar
350zSpeedRacer
With my experience, the Nismo cams and the Vortech get along VERY well. I had the cams for 6 months before I went with the blower and lost a little bit on the low end, but picked it back up in the mid range and top end.
Old Oct 11, 2004 | 01:41 PM
booger's Avatar
booger
I ordered the Nismo cams today , with the heavy duty springs . Now if the dang Pauter rods would come in , I would be set to go
Old Oct 12, 2004 | 10:18 AM
LOU's Avatar
LOU
Good choice with the Nismo's Bill. I think the JWT's are the best for FI after doing some research. They have the highest lift and the shortest duration which means there shouldn't be any valve overlap. The Tomei cams have a longer duration and a shorter lift. This may cause problems with FI. The Nismo are in between. I know two people running JWT's with a Vortech and they have had no problems. Let me know how the Nismo's work out. I am guessing better mid-range than the JWT's, but less top-end.
Old Oct 12, 2004 | 01:54 PM
mchapman's Avatar
mchapman
Ive searched the net for a 300zx project car that has had the cams changed hoping to learn something about the needs of a V6 TT in respect to cam theory.
From Project 300zx - Sport Compact Car
Camshafts & Valvetrain
We opted for JWT's turbo cams. JWT's cams have increased duration and lift for improved high-rpm power. JWT also grinds the cams with a minimum of overlap to reduce the chances of turbo backpressure-induced reversion. Reversion is caused when the high backpressure created by the turbine is more than the boost pressure at high-boost levels and rpm. This causes hot exhaust gasses to back flow through the engine during valve overlap (the point in the four-stroke cycle where both the intake and exhaust valve are open). This back flow causes the internal temperature of the engine to rise, promoting detonation which further increases heat. This can create a vicious circle where the engine has a thermal runaway, overheating to destruction. Excess overlap can also cause charge dilution at idle, resulting in the lopey eight-stroking misfire race-car type of rough idle.
http://www.sportcompactcarweb.com/pr...scc_proj300zx/
OK so the needs of a FI car are different to that of a NA tune car. We've learnt for FI you want more lift and duration but very little overlap at the right moment to avoid exhaust going into your intake manifold. Normally overlap helps get rid of the burnt exhaust gases and suck fresh air, fuel through into the cylinders (scavenging effect) , but because your gas/exhaust is under pressure you dont need it as much.
So what cams out at the moment meet this criteria? Or what combination of cams would help achieve this?
Old Oct 12, 2004 | 04:55 PM
aron's Avatar
aron
I dropped in the JWT cams in with the vortech on my 5AT and i netted 370whp, a lot more than what others are getting without cams. Loads of power up top, but a noticeable loss down low. After 5k the car just explodes.
Old Oct 12, 2004 | 05:01 PM
booger's Avatar
booger
Thats why I decided to go with the Nismo cams . I heard several people have the JWT cams and A SC and didnt like the low end power .
Old Oct 12, 2004 | 05:37 PM
aron's Avatar
aron
Yeah, i definitely feel a loss of power down low. Different pulleys should help the boost kick in quicker though and some more agressive tuning I hope
Old Oct 12, 2004 | 05:53 PM
Sharif@Forged
Forged Performance
I know..I know...I feel bad.
I am patiently waiting for the UPS driver to pull up...I can FEEEEL the rods are near!
Old Oct 12, 2004 | 08:19 PM
G3po's Avatar
G3po
Default rods
Just got mine , sweeet.
pslamp32
Feb 8, 2017 09:07 AM
B Esquire
Sep 24, 2015 07:52 AM
EnjukuRacing
Drivetrain
Sep 14, 2015 11:15 AM
