Boost in cold weather?
Old Nov 13, 2004 | 04:19 AM
Barzten1's Avatar
Barzten1
Default Boost in cold weather?
Its getting pretty cold in New Mexico. I get off work at 3:30 in the morning. I warm up my car pretty good before I take off. Is it bad to get on the throttle in cold weather? (25-35 degrees F)
Old Nov 13, 2004 | 04:28 AM
dansouliere's Avatar
dansouliere
When you get into the car you must realize that the oil that is in the engine is at the bottom, and is probably cold and “hard” (like cold saturated fat that forms around meat in the fridge)…you can start the car, but do not drive immediately, because your engine starts to move when you crank it up, but it is moving without oil (this is why you MUST warm up your car) many people say “WARM UP YOUR CAR” without giving you a reason (well I just gave you one)...but do not 'OVER WARM " your car... yes you can do this...this is more complex to explain but basically do not warn your car up over 5 minutes.
During the summer I would recommend you warm up the car for at least 35 seconds…(yes 35 is the minimum)…during the winter it takes about 1 minute and 50 seconds for the oil to reach the top of the engine…so I recommend a 2 min. minimum warm up time…(as a side note, I don’t even start my car when I go to the store, because if it’s close enough I’ll just walk and save the engine a little)DON'T…I REPEAT DO NOT REV your engine during the warm up period, because you are making the engine work harder with no oil…I’ve seen so many people do this during the winter, and it’s just not good (I don’t get on their case, because there was a time that I didn’t know this as well).
Old Nov 13, 2004 | 04:48 AM
booger's Avatar
booger
your boost level will go up also . In the summer you may make 8lb's and when its 35 degree's you may make 9lb's . And with the denser air you may run leaner also . Just some thing to be aware of. Bill
Old Nov 13, 2004 | 05:05 AM
Barzten1's Avatar
Barzten1
Thanks Boog! Thanks dansouliere! Great explenation...thanks for the time fellas!
Old Nov 13, 2004 | 06:54 PM
350zDCalb's Avatar
350zDCalb
builtZmotors
barzten.. havent heard from u..i'm assuming you are frightened??? the twin turbo will play nicely... =-)
Old Nov 13, 2004 | 06:56 PM
350zDCalb's Avatar
350zDCalb
builtZmotors
you'll prolly take me off the line though...i'm still running stock wheels... they just spin through first and second if i get on the throttle at all.
Old Nov 13, 2004 | 07:11 PM
MEGA_BB6_Turbo's Avatar
MEGA_BB6_Turbo
explain the overwarming theory ?
Old Nov 14, 2004 | 04:00 AM
Barzten1's Avatar
Barzten1
Are you calling me out Doc? Oh no you dittn't! haha....Win or lose I'll race anybody. Been so busy at work. I'm really wanting to get together with you and a couple other Z buddies and beat the town up. Can't wait!
lapham3
Oct 7, 2022 03:15 PM
codek
Sep 28, 2015 03:03 AM
