timing-NEED your HELP-PLEASE!!!
Old Nov 15, 2004 | 02:46 PM
350zDCalb's Avatar
350zDCalb
builtZmotors
Default timing-NEED your HELP-PLEASE!!!
#1) so the install of the timing harness is fine, diodes and all... but i am still in the process of figuring out why the E-01 is not communicating w/ the e-manage, soon, i will know if it is simply because the USB cable is not connected... if it is connected, have you guys experienced some cables being compatible and others not???
next question...
#2) initializing the e-manage: this clears out the settings, right? what are the next steps from here....
#3) does anyone have the e-manage factory settings, so i can initialize, put in the factory settings and then tune from there???
also... is there an airflow map to compensate for the larger injectors???
THANK YOU ALL IN ADVANCE!!!
Old Nov 15, 2004 | 03:08 PM
350zDCalb's Avatar
350zDCalb
builtZmotors
ok... cable was not connected...now it is .. and communicating...anyone have the factory values????
Old Nov 15, 2004 | 04:58 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Once you initialize the eManage, you need to do a couple things.
1) Injector scaling in the parameters screen. Make it scale from 280-440
2) Add injector Map--input stock values...I dont have them handy...PM ETX or do a search....he posted them 6 months ago
3) Boost cut limiter: This is your voltage clamp, and it should be set to 5.0 across the board. THis way, your ECU will never see more than 5.0Volts of airflow.
4) Ignition timing map: This is where your tuner will retard the timing. Initially, it will contain all zeros in the map.
Thats all you need to mess with. The airflow adjustment map is not utilized for this application.
Old Nov 15, 2004 | 05:07 PM
Sharif@Forged
Forged Performance
Here is the link from ETX...but look like the pictures to the fuel tables are down. PM him.
https://my350z.com/forum/showthread....ghlight=Greddy
Old Nov 15, 2004 | 05:25 PM
westpak's Avatar
westpak
SFZCC
Here is a timing MAP I pulled off one os the MAPS I had in tool support, it looked like a little too much timing but it is a start, that is the problem with the emanage timing you really don't know when you are pulling too much, which why I like the J&S
http://www.sfzcc.com/gus/timing.tif
And if ETX can't get you the base MAPS, I have them in my laptop but I am waiting on a new charger
Old Nov 15, 2004 | 05:55 PM
350zDCalb's Avatar
350zDCalb
builtZmotors
thanks guys... etx's inbox is full....any other ideas????
Old Nov 15, 2004 | 05:57 PM
Sharif@Forged
Forged Performance
yes...email him through the board.
Old Nov 15, 2004 | 06:34 PM
350G's Avatar
350G
I can email the base maps to you . . . the file is too large to append (sorry, not too computer savvy ) . . . I'll check back in a little while . . . and BTW, you have your profile set to not have emails sent to you through the boards.
Gary
Old Nov 15, 2004 | 07:05 PM
350zDCalb's Avatar
350zDCalb
builtZmotors
you've all been a great help...and very quickly never the less!!!
i think i found the maps...called d-4 add injector map???... i found it at
https://my350z.com/forum/attachment....&postid=793648
https://my350z.com/forum/attachment....&postid=793650
Can you guys confirm that this is correct??
THANKS!!!!!
Old Nov 15, 2004 | 07:08 PM
350G's Avatar
350G
That looks just like what I sent you
G
Old Nov 15, 2004 | 07:09 PM
cquence 350 [Z]'s Avatar
cquence 350 [Z]
I want a copy of the base map as well. Can you guys send me one too? Thanks
Old Nov 15, 2004 | 07:18 PM
350G's Avatar
350G
Sure, drop me an email at:
gljohn0@yahoo.com
and I will send it to ya
Old Nov 15, 2004 | 07:26 PM
cquence 350 [Z]
Email sent!
Old Nov 15, 2004 | 08:01 PM
350zDCalb's Avatar
350zDCalb
builtZmotors
thanks for emailing it... the maps i found on this website were the same...thank you very much though for the help
-todd
350G's Avatar
350G
Hell, I've been getting emails from a few of ya without your screen names . . . so I sent every damn one of ya a base map
Good luck fellas . . . and Tim, hope you like my theory
Old Nov 15, 2004 | 08:16 PM
350zDCalb's Avatar
350zDCalb
builtZmotors
Thanks Gary!!!
Old Nov 16, 2004 | 12:04 AM
cquence 350 [Z]
Thanks Gary!
Old Nov 16, 2004 | 05:28 AM
Sharif@Forged
Forged Performance
woohoo!!!! I am saving that to my computer for future reference
Old Nov 16, 2004 | 06:29 AM
etx's Avatar
etx
Hrm, my inbox is full? wicked.
edit: Here are the maps again.
Old Nov 16, 2004 | 10:31 AM
350zDCalb's Avatar
350zDCalb
builtZmotors
thanks again everyone... you guys are definately the "go-to" guys when a question/hurdle arises...
