need help w/ clutch b4 going to dealership
Old Mar 23, 2008 | 04:06 PM
infinite_636's Avatar
infinite_636
Default need help w/ clutch b4 going to dealership
i've had my 05 6mt sedan for 1 1/2 years now. As many know, those years have a high engagement point. All day today, the clutch seems to be "stuck" down to the floor. The engagement point now; it doesn't come up high like it use to, AND now, I can barely get into 1st, 2nd, 3rd, 4th, and REVERSE! WTF?! Its like i have to force it in hoping it'll go in. i know i didn't do anything wrong. It Grinds like a B*tch now!
Is it my syncros? or is it just the assmebly? or the short shifter i installed? or does the whole transmission need to be replaced. Someone said that if the brake fluid is low, the clutch will stick to the floor like that, but thats STUPID. brake fluid and clutch has no affiliation.
HELP! PLEASE! NEED HELP!
Old Mar 23, 2008 | 04:23 PM
Spork's Avatar
Spork
Check your fluids, really.
I can't remember really, but the Z might be one of the cars that shares the same reservoir for the brakes and clutch.
Old Mar 23, 2008 | 04:35 PM
infinite_636
hmm..ok then, THANKS for replying. i'm going to do it right now.
Old Mar 23, 2008 | 05:03 PM
infinite_636
i checked it, all fluids are ok.
Old Mar 23, 2008 | 05:29 PM
MDeezy's Avatar
MDeezy
might be a leak somewhere. examine the clutch lines. If you can give it a bleed and see what happens after that.
Old Mar 23, 2008 | 07:07 PM
XKR's Avatar
XKR
Bleed the line...sounds like you have air bubble in there. How many miles on your car?
Old Mar 23, 2008 | 10:07 PM
infinite_636
30k is on there, how do i bleed the lines? it isn't a problem with the brakes, its the clutch.
Old Mar 24, 2008 | 09:26 AM
chobble19's Avatar
chobble19
could be ur slave cylinder...take it the stealer!
Old Mar 24, 2008 | 11:11 AM
XKR's Avatar
XKR
Because they both work off the same system.
nlsqba
Oct 15, 2005 10:32 AM
forgeur
Jul 7, 2005 02:42 PM
IsatteliteI
Aug 10, 2004 03:24 PM
InternetABYSS
Oct 16, 2002 08:36 PM
