What will happen if I take out my Z tube and...
Old Feb 8, 2004 | 07:42 PM
Tailspinz's Avatar
Tailspinz
Default What will happen if I take out my Z tube and...
leave the space with nothing? I am returning the Z and want to ripp the z-tube off as i am also taking my pop charger off.. now I wanted to know if the z is still drivable with no z -tube and if something bad can/will happen if u drive it like that? The leasing company won't give a crtap if i take it... dont worrie.. lol
(i plan on using the z-tube on my g35c)
Old Feb 9, 2004 | 05:12 AM
G-Ryder's Avatar
G-Ryder
Default Re: What will happen if I take out my Z tube and...
What no intake arm??? That's preettty crazy. Your car would probably roar like a beast. Not to mention suck up alot of debris into the engine. Not good....
Old Feb 9, 2004 | 05:37 AM
2003z's Avatar
2003z
probably won't run, since there is a vacuum line that attaches to that tube.
Old Feb 9, 2004 | 10:54 AM
SPEEED's Avatar
SPEEED
I'm not sure you'll be even able to turn the engine on since the AF sensor won't detect any air flow passing by....
Old Feb 9, 2004 | 11:03 AM
ranger5oh's Avatar
ranger5oh
What is the point of this senseless mod? The whole point to that arm is to get cooler air from further away from the engine...??? If anythign you would want to extend the arm further.
Old Feb 9, 2004 | 11:34 AM
SPEEED's Avatar
SPEEED
He is not modding his car, he is trading it in. He wants to take out his Z tube + JWT pop charger to this next car - a new G35....
Old Feb 9, 2004 | 09:15 PM
350Z 2+2 ???'s Avatar
350Z 2+2 ???
Do you already have your G35? If so, then you should swap them out instead of trying to remove the Z tube. You would probably have to whack off... sorry, I mean cut off... the lower resonator on the G tube, but like you stated... the leasor won't know the difference. Just be sure to seal the opening you make in the G tube after removing the resonator or you'll run into the same problem that Speedoholic mentioned, namely incorrect air flow readings from your MAS.
Old Feb 10, 2004 | 06:39 AM
glennp_1999's Avatar
glennp_1999
Have you even tried starting your car without the tube? Try it and see what happens. 2 things will happen if you do this. 1) if you don't have the tube in place your car will crank and start but will shut off off immediately. Or 2) it will run but your check engine light will come on because the MAF sensor is not reading any air coming into the engine. Either way it will mess up your car.
Old Feb 10, 2004 | 11:04 AM
wonko99's Avatar
wonko99
Just spend the 50.00 and buy a new tube.
Old Feb 10, 2004 | 02:41 PM
snolden's Avatar
snolden
you are playing around with two 35k automobiles and can't spare 70.00 for a new z tube? c'mon man. that is nothing to new tires in a couple short years.
Old Feb 11, 2004 | 03:30 PM
qirex's Avatar
qirex
cheap a$$ ****...
07ZEKE
Aug 23, 2021 09:15 PM
apex locator
Jul 23, 2021 02:27 AM
3vilbunny
Jul 18, 2017 05:10 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
