brake squeek/ brembos
Old Nov 12, 2004 | 05:49 PM
HIg35's Avatar
HIg35
Default brake squeek/ brembos
my car isn't even broken in yet (200 miles) and noticed it squeeking when brakes is hot with light pressure at about 5-10 mph, and i do have brembos. any of you guys have that problem?
by the way, i am bringing it back to the dealer.
Old Nov 12, 2004 | 06:08 PM
NismoGCoupe's Avatar
NismoGCoupe
yes it normal nothing you or the dealer can really do except get aftermarket pads
Old Nov 14, 2004 | 02:20 PM
SIN3's Avatar
SIN3
same here when i first got my g i worried about the squeeky noise but you a "skyline" now so get used to it. hahaha
Old Nov 16, 2004 | 02:33 PM
StarcraftBW's Avatar
StarcraftBW
same problem w/ the non-brembos
Old Nov 16, 2004 | 02:52 PM
ezee's Avatar
ezee
you need to break in your brakes, put in 8-10 hard braking maneuvers from 50-60 mph down to 10-15 without stopping and let your brakes cool before stopping, just cruise for 15 minutes. Do it again the next day and you're brakes will be broken in and the noise will be gone.
Old Nov 22, 2004 | 05:13 PM
n1cK!'s Avatar
n1cK!
Infiltrator!
well, the brakes are already bedded in at the factory, so there shouldn't really be a need for a break in period. i have never experienced that squeeking noise, though i only have a little over 6k on my '04. i would expect that squeeking noise to come in after the pads have worn out (the time which will vary depending on how you drive the car). i would definitely take the car into the dealer and have them check it out. see what they say.
n1cK!
Old Nov 26, 2004 | 07:22 AM
ZeroGen's Avatar
ZeroGen
n1ck
How did you find out that the Brembo brakes on the 6MT are already "bedded in"? I remember when I took delivery of my G, there was a card signed by a guy at the factory stating the car was driven for 5 miles prior to shipment. I've always wondered if they did the leg work for me on the brakes.
Old Nov 26, 2004 | 01:16 PM
n1cK!'s Avatar
n1cK!
Infiltrator!
Originally posted by ZeroGen
n1ck
they do it before the brakes are even installed on the vehicle. it's basically on a machine that has the rotor, a caliper, and brake pads. they run different "loads" until the brakes are bedded in. brake pad/rotor manufacturers do this as well (but not all).
n1cK!
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
samansharif
Sep 25, 2015 12:31 PM
