yes i just installed my dads last week and after we got done the ilde does dipp a lil everyonce n a while but theres no pattern to it. And as far as the sound goes we have the same deal its not a leak but if you pinch the vacum line comin out of the valve cover it goes away. And i was doing some messing around and if you plug up that hole with your finger it idles perfectly so i dunno.it almost sounds like you just hear the air whistling through that line.....
didnt they have a problem with vacuum leaks where the IM bolts to the manifold ? I think several guys had to have thiers sanded or milled flat , so it would seal.
I installed and got the whistle. I removed the throttle body and re-installed using blue RTV to seal and the whistle went away. Idle is a little HIGHER than it used to be, at 1K with A/C on...
I think i might do the same since the whistle is still there and the idle is lower
