apexi active tail system
This is a pretty cool concept. It is a removable silencer that fits in the back of a typical N1 muffler. The ATS has a spring loaded valve that keeps shut at low flow/small throttle openings. Hit it hard, and the valve is forced open by the exhaust gas, and you get full unobstructed flow. Has any one tried one of these?
Good point. As I understand it, there is a calibrated amount of spring pressure that keeps the valve from fully opening except at wide open thottle. If the engine is running, the valve must be partially open. So perhaps it is not truly unobstructed flow. Does any exhaust really provide unobstucted flow?
ever heard of a silenced exhaust can?
it sounds WEAK
no apexi n1 can isnt ferrari/porsche dual stage muffler...
so that concept is right but the material/part used isnt there yet
it sounds WEAK
Whatever this is http://www.hypersprite.com/auto/pict...b/DSC03869.jpg
I was talking to him about how cool his exhaust sounded and he said all he did was remove the vacuum exhaust valve. That normally it only sounded like this when you got on it but by removing it, it loud all the time.
Chris
Chris
Justin100
Nov 29, 2015 03:58 PM
