Test pipes or High Flow Cats?
Old Mar 22, 2006 | 05:48 PM
StillAlive2029's Avatar
StillAlive2029
Default Test pipes or High Flow Cats?
I want to replace the stock cats but i do not want it to smell, i assume that test pipes smell and high flow cats dont right? are there any test pipes that you guys have that do not emit the smell of fuel?
Old Mar 22, 2006 | 06:06 PM
TeCKNeiC's Avatar
TeCKNeiC
I am also wondering about this...
Old Mar 22, 2006 | 06:42 PM
plumpzz's Avatar
plumpzz
its not the test pipe that emits the smell... its NOx and sulfurs that you smell, that a cat would otherwise break down. Without a cat, it will smell, and even with a HFC, there will be some smell. Test pipes are illegal....you'll have to swap back stock if you want to get an emission test done. thats about it. test pipes make more power usually, are louder and raspy.
Old Mar 22, 2006 | 06:49 PM
DG350Z's Avatar
DG350Z
TP's if your going for performance, HFCs if you just want a boost in power and want to pass emissions without re-switching to stock.
Old Mar 22, 2006 | 07:10 PM
StillAlive2029
when would i ever want to pass emissions? like when would i have to take the test?
Old Mar 22, 2006 | 07:35 PM
Bubble's Avatar
Bubble
-REPLICA ARMY-
I would recommend Testpipe over HFC. You'll get the same performance gain (HP) but it is cheaper to use testpipe and you will have a deeper sound.
DOn't worry about emission for now since you have 5 years before you have to smogcheck your car again.
For testpipe, i would recommend:
1. Strup
2. Topspeed.
Old Mar 22, 2006 | 07:59 PM
StillAlive2029
do those two not rasp so much?
Old Mar 22, 2006 | 08:01 PM
Bubble's Avatar
Bubble
-REPLICA ARMY-
In my case, i don't have that problem. You will see a MIX review of "rasping" issue. Even with HFC, you still have rasp. Price range for HFC in the $300-$400 while testpipe in the $100-$200. Half price. Same gain. Deeper sound.
Old Mar 22, 2006 | 08:08 PM
StillAlive2029
but how about the smell?
Old Mar 22, 2006 | 08:09 PM
Bubble's Avatar
Bubble
-REPLICA ARMY-
it will goes away after 500-1000 miles.
Old Mar 22, 2006 | 08:16 PM
StillAlive2029
its not just the smell of uncleaned gas fumes or wahtever?
Old Mar 22, 2006 | 08:18 PM
Bubble's Avatar
Bubble
-REPLICA ARMY-
the gas fume smell will goes away. Even with HFC, you still smell it unless you buy an "USED" unit then you don't have to deal with it.
Old Mar 22, 2006 | 11:05 PM
99atlantic's Avatar
99atlantic
test pipes will cause you to run a lot leaner than hfcs will...........if you're doing other stuff like headres and such and no tune, i wouldn't run test pipes
Old Mar 23, 2006 | 04:39 AM
350Z007's Avatar
350Z007
Is there a way around getting the SES light when you run test pipes? I'm interested in running test pipes, but I don't want to stare at a SES light all the time.
Old Mar 23, 2006 | 09:07 AM
99atlantic's Avatar
99atlantic
spark plug non-fouler trick
or buy an 03 model, they don't have that problem most of the time ^_^
Old Mar 23, 2006 | 09:11 AM
Bubble's Avatar
Bubble
-REPLICA ARMY-
after few thousand miles, SES is gone. My SES is not on for awhile now. My car is 05 btw.
Old Mar 23, 2006 | 09:44 AM
first350's Avatar
first350
I just hollowed out a psare set of OE cats and bought the non-foulers for $15 at Kragens autoparts...I should install them within the next few weeks (as soon as work lets up). From what I hear, the non-fouler trick works well.
http://www.*********.com/zwiki/Tutor...ith_Test_Pipes
-Peter
Old Mar 23, 2006 | 09:45 AM
first350's Avatar
first350
Old Mar 23, 2006 | 09:49 AM
first350's Avatar
first350
sorry, the link isn't working...I attached the pdf of the website.
Old Mar 23, 2006 | 10:49 AM
buzzardmountain's Avatar
buzzardmountain
Replace the ****** with 350z - tech.com No spaces in the address.
AbrasiveRaysive
Sep 20, 2021 02:29 PM
codek
Sep 28, 2015 03:03 AM
