I was the test car and WOW! GOOD NEWS!
Old Apr 13, 2006 | 08:09 AM
  #121
ISMSOLUTIONS's Avatar
ISMSOLUTIONS
Hey all:
Fresh clips, vids and pricing coming out next week. Group buy info as well....
Tell a friend...
Rick
Old Apr 13, 2006 | 09:35 AM
  #122
HockeyZ39's Avatar
HockeyZ39
It's not nice to keep teasing....
Anyinfo on an independant dyno? Maybe offering a reduced price to a person that is will to go get a basline, put the exhaust on, then another dyno?
Old Apr 13, 2006 | 10:20 AM
  #123
ISMSOLUTIONS
Call the guys...not my call or place to make that deal..
Old Apr 13, 2006 | 10:22 AM
  #124
ISMSOLUTIONS
Keep in mind though - the car was dynod on a DynaPack - a pretty conservative unit...
Old Apr 13, 2006 | 11:36 AM
  #125
HockeyZ39's Avatar
HockeyZ39
I would just like to see an un-bias person dyno it. It is nothing against the company, I am just the type that likes to be sure. I am not asking for me to be the independant, b/c I am not stock, and I am not local.
Old Apr 13, 2006 | 12:26 PM
  #126
ISMSOLUTIONS
That's cool...as I said before in previous posts - I'm the same way - someone should step up though if it's a critical point for a majority.
I'm sure several will do so as they get the systems and you will wait until someone posts a result....that's OK...the guys and the systems aren't going anywhere....other than those that do buy them.
I'm here and so are they via phone call for any other questions...don't be shy.
Rick
Old May 10, 2006 | 06:49 AM
  #127
ISMSOLUTIONS
Hey all - we're baaaaccckkkkk!
Rick
Old May 10, 2006 | 06:53 AM
  #128
ISMSOLUTIONS
Default ooopsss....forgot!!!
You'll want to see this...
https://my350z.com/forum/showthread.php?t=190252
Rick
Old May 10, 2006 | 10:59 AM
  #129
FastIntentions's Avatar
FastIntentions
Fast Intentions
Default Group Buy Is Here - Group Buy Is Here!!!!
Just in case you all didn't catch the hints below...
Rick
Old May 10, 2006 | 11:28 AM
  #130
hunter6's Avatar
hunter6
Default Weight?
Will this cat-back weigh less than stock?
Old May 10, 2006 | 01:30 PM
  #131
ISMSOLUTIONS
No, it can't for simple reasons that is it a true dual. The aluminized version will weigh the most.
Rick
Old May 10, 2006 | 05:35 PM
  #132
ISMSOLUTIONS
Default Group Buy Info And Sign-up Has Moved!!!
I have moved the info to non-premier member areas:
https://my350z.com/forum/showthread.php?t=190252 for the info thread
AND
https://my350z.com/forum/showthread.php?t=190253 for the sign-up page
Rick
Old May 10, 2006 | 06:10 PM
  #133
DG350Z's Avatar
DG350Z
Not that it isnt nice but it sounds pretty much like borla to me...a little bit higher pitched perhaps...
Old May 11, 2006 | 05:52 AM
  #134
ISMSOLUTIONS
Originally Posted by DG350Z
Not that it isn't nice but it sounds pretty much like borla to me...a little bit higher pitched perhaps...
It's nothing at all like the Borla..nothing at all.
ZERO drone and effective through all RPM ranges. The Borla resonators are metal mess packed and can't handle high rpm's and flow and basically do nothing when the car gets going. Once the car gets hot, the car drones out too, and it only gets worse over some time as well.
Don't get me wrong either - I have said this in the past - the best system I think out of all the others out there, that I personally liked the best in all my testing was the Borla, but it didn't mean that it didn't have it's issue either.
This is such a different class product.....sound and build-wise.
Hey - I still have my Borla muffler in the garage and I kept nothing from any other system!
Rick
Old May 11, 2006 | 11:23 AM
  #135
hunter6's Avatar
hunter6
Are the weights for the cat-backs known? How do they compare to stock?
I'm very excited about this set-up. Great sound and power without the drone? It's a no brainer.
Old May 11, 2006 | 02:09 PM
  #136
DG350Z's Avatar
DG350Z
Didn't say it was built like borla, I said it sounded like borla. If your really buying an aftermarket exhaust for the difference in power (assuming your NA)...lol then the difference between systems is so negligible its silly. 8 whp from borla and 11 from this system, which is basically within the range of varience on dynos....
Edit: About the drone, I can hardly hear a thing at anything below 3K on the highway. Not that drone bothers me.
Old May 11, 2006 | 06:23 PM
  #137
ISMSOLUTIONS
The aluminized is 2 lbs heavier than stock and the stainless is 3 lbs lighter than stock.
Rick
Old May 11, 2006 | 06:26 PM
  #138
ISMSOLUTIONS
I understand - I just wanted to further compare a bit - no harm or foul. I always have loved the Borla myself. On dyno's I never saw 8 HP from the Borla though.
We all have our tastes - that's why we have so many to chosoe from...
Old May 11, 2006 | 06:57 PM
  #139
ISMSOLUTIONS
Default Testpipes Are Now On Group Buy!!!
OK ALL - if you don't think we really are trying to make you all happy and do our best for you.....you asked for it...we crunched it out and made it happen!
Check out the GROUP BUY ON TEST PIPES!!!
Go to the marketplace....
RICK
Old May 12, 2006 | 07:10 AM
  #140
hunter6's Avatar
hunter6
Thanks for the weights Rick. Good luck.
