MREV+ Dyno Tested On The 287 HP Engine!
Originally Posted by Hydrazine
If you already have been tuned to all thoes parts, you may not need another tune.
If you simply bolted everything on without a tune, yes, you will need one.
Otherwise you would just run leaner and not make much (if any) power from it.
Keep your tune between 12.5-13 A/F for optimum results.
I'm w/o a tune and I know that when I did the spacer install I immediately felt power all over, same with headers and hfc and other breathing mods.....I guess I'm curious though at what point the a/f become too affected by the breathing mods.
Originally Posted by 99atlantic
Hmmmm, so are you saying then that this shifts the a/f enough that w/o a tune it won't be that worth it
But those without a tune that have mass modes will lean out even more in the range of 14.XX and will make less hp until they are properly tuned. Get it now?
Originally Posted by Mr_pharmD
If you are already tuned like me with the unichip, then you will not need to retune it again bc it will only lean the A/F ratio alittle and still make optimal hp (A/F shifted from 12.8 to 13.0 now with the MREV++).
MOTORDYNE-MY350Z SPONSOR
somewhere around 0.2 A/F shift.
It won't make a difference at 12.5 A/F but if you are already in the high 14's, it will.
On a different note.
Everyone going to Church Automotive tomorrow. If you plan to install a plenum mod while at the shop, try to make accomodations before leaving.
1) Remove your strut bar before going. Time flys when you are at the dyno shop. Whatching cars get dynod. Chatting with friends and stuff. Save as much time as you can. You can always bring the strut bar with you so you can reinstall it.
2) BYOT Bring your own tools. Download a copy of the installation manual from the Motordyne website and study it before leaving. It will save you considerable time bending over the engine bay.
I'll have tools too but don't rely on me because i will be busy with dyno installations. --> You can use my torqe wrench though.
See you at the Dyno!
Originally Posted by racinzrookie
Any results with the Nismo CAI would be nice to see, cuz i dont want to put that away. it would be a waste of money
Tony...Would you recommend a Long Tube CAI to be combined with a MREV V2, and the 5/16 spacer??
Originally Posted by OCG35Coupe
Tony can you end this once and for all for everyone asking what kind of gains would be made with the MREV V2, 5/16 Spacer, and a Long Tube CAI...
Originally Posted by Road Warrior
aslo, although probably the same as Mrev+ on 287 with spacer
Mrev+ with modified upper plenum, such as crawford or aps on 287
I am just waiting for all this $hit to me made available for purchase!
yea, but i would never core exchange; i want to keep all my stock **** ^_^
Oh, and I 2nd the other G35 Owner helping you...This mod will help your car, and yes the testing was on a non rev up 287 BHP 350Z with the MREV++...which for the record, differs from the MREV+ by Tony simply porting and polishing 2 more of the 6 intake ports on the lower manifold of non RevUP motors...and obviously some secret squirrel stuff he's keeping secret...as he should.
Originally Posted by Z BOY
so the dyno you posted where the a/f actually decreased with the mrev++ was just an anomaly?
It typically goes up more often than it goes down. Any shift is typically within +/- 0.2 A/F.
so you didn't see the recent dyno in this thread which showed the long tube losing power?
I was going to put the quote in my sig..
And technically that dyno does not show the long tube losing power, because there was no stock baseline run, the long tube was the baseline.
But still i do understand Long Tube CAIs are not recommended for these mods, i just want a blatant quote from Tony
Hydrazine,
You have a plenum for me right? I just wanna know cause I suggested the meet thing! Oh man, cant wait to see the results....
