MREV+ Dyno Tested On The 287 HP Engine!
Old May 4, 2006 | 09:46 AM
  #481
Hydrazine's Avatar
Hydrazine
MOTORDYNE-MY350Z SPONSOR
Originally Posted by FOO_G
? about the core return. Do we need to make a coment in he note area of our shopping cart before we submit it?
Yes. Please do.
I will also send paperwork in the package for lower collector returns.
PS Everyone - Clean and package your lower collectors very well before shipping. Thanks!
Old May 4, 2006 | 09:48 AM
  #482
Hydrazine's Avatar
Hydrazine
Originally Posted by Mr_pharmD
is the MREV ++ the same as the MREV 2 TM + lower collector?? I only see that on the site. Anyone got a link for the MREV ++?
MREV++ is a horrible name for a product so it is officially now called MREV-2.
Its the same part though.
Old May 4, 2006 | 10:32 AM
  #483
amG35's Avatar
amG35
Originally Posted by wren57
About to install the modified lower 287 manifold on my 287 engine that already has the crawford v5. Will report back in a few hours.
Thanks wren, your feedback is anxiously awaited. Thanks for taking the plunge. I trust we won't be dissappointed.
Old May 4, 2006 | 10:48 AM
  #484
FOO_G's Avatar
FOO_G
Originally Posted by Hydrazine
Yes. Please do.
Thanks.
Now back to the grind stone , not me you.
well I guess I should too ehh. thanks again.
Old May 4, 2006 | 11:02 AM
  #485
tomcatm's Avatar
tomcatm
Yes. Please do.
Dohh...i didnt put anything in the comments box...hope its okay. Order #87 btw.
Old May 4, 2006 | 11:11 AM
  #486
Mr_pharmD's Avatar
Mr_pharmD
damn 87 ppl already purchased the MREV 2. Tony's making a killing
Old May 4, 2006 | 11:36 AM
  #487
six3mike's Avatar
six3mike
I didnt either. I'm order 91. Let the waiting game begin.
Old May 4, 2006 | 11:48 AM
  #488
jeeper78's Avatar
jeeper78
Hi Guys,
Yes, the test results on Wired 24/7 Z were very good. A significant increase in area under the TQ curve and great HP gains in the highend. This mod likes to make TQ unlike the usual upper plenum mods.
I also tested it on my REVUP engine (without a spacer) and the results in my opinion were unacceptable. It made ~25 ft/lbs TQ in the midrange but it lost too much at peak. So far, it looks like the REVUP may still require a spacer for optimum highend response. I would have liked to continue testing but it was getting late for us and for the shop owner.
And I'll get cracking on the data for detailed analysis.
Tony
PS It was good meeting everyone! Finally got to place a face on all the board names. Maybe we can do Sushi when more time is available.
It has been stated that the results of the MREV-2 were unacceptable when installed on a REVUP engine. Let's not forget that the MREV and MREV+ started out as mods for only REVUP engines... has it been shown yet that adding a spacer to the MREV-2 on a 300hp engine produces a more acceptable result? Will MREV+ still be offered for those with 300hp REVUP engines?
Also, I thought the whole point of these independent dynos was to verify that MREV-2 is better than MREV+... and yet (other than your own initial dyno) I don't think I've seen anything but a baseline dyno compared to MREV-2 with and without a spacer. Where are all the MREV-2 to MREV+ comparisons?
Old May 4, 2006 | 12:15 PM
  #489
Zincognito's Avatar
Zincognito
Order number 93!!! Cant wait. Tony, PM'ed
Old May 4, 2006 | 12:44 PM
  #490
mikead_99's Avatar
mikead_99
Good questions. I was hoping to get some sort of a deal during this if V2+Spacer worked out on revup, but seeing only V2 and no "MRev+" or "V1" listed on the site leaves me sitting and watching you guys have all the fun.
Old May 4, 2006 | 12:49 PM
  #491
anotheraznguy's Avatar
anotheraznguy
i am looking to purchase
5/16" Iso Thermal plenum spacer (with all Iso Thermal components, Aramid gasket and CCV)
MREV 2 TM + lower collector - Standard lower collector with modified Intake Runners for reduced pressure drop
How much is the total?
i tried doing it online and couldn't input the coupon code?
Old May 4, 2006 | 01:14 PM
  #492
pingbling23's Avatar
pingbling23
So do you reuse all of the gaskets or do new ones come with the kit.
Old May 4, 2006 | 01:22 PM
  #493
wren57's Avatar
wren57
Well I was going to go ahead and install my lower plenum but have decided to wait a while. Even after sanding with 60, 100 and 200 grit sandpaper AND rubbing down the manifold hard with grade 4, 2, and 0 steel wool it still looks like crap... NOTHING like the smooth/shiny version shown on the website. I've contacted Hydrazine and am awaiting a response before installing. I've attached pictures of *edit* the manifold I recieved from motordyne */edit* vs. the advertised manifold for reference; the first two pictures are my manifold, the third is what is advertised.
Look a little different to you?
Attached Thumbnails MREV+ Dyno Tested On The 287 HP Engine!-1.jpg   MREV+ Dyno Tested On The 287 HP Engine!-2.jpg   MREV+ Dyno Tested On The 287 HP Engine!-3.jpg
Old May 4, 2006 | 01:27 PM
  #494
ATL_Red_G35's Avatar
ATL_Red_G35
Tony, I know there is a time frame limit for the sale, is there a quantity limit as well?
Old May 4, 2006 | 01:29 PM
  #495
bilinghm's Avatar
bilinghm
Well I was going to go ahead and install my lower plenum but have decided to wait a while. Even after sanding with 60, 100 and 200 grit sandpaper AND rubbing down the manifold hard with grade 4, 2, and 0 steel wool it still looks like crap... NOTHING like the smooth/shiny version shown on the website. I've contacted Hydrazine and am awaiting a response before installing. I've attached pictures of my manifold vs. the advertised manifold for reference; the first two pictures are my manifold, the third is what is advertised.
Wow, no blending of the milled off tops of the two front runners at all. Sharp edges. Not what I would expect to see. So this is an Mrev++?
Old May 4, 2006 | 01:33 PM
  #496
Grommit's Avatar
Grommit
So can those of us in Southern California drop off our old lower plenum and pay/pick up the MREV2 some where? I don't want to go through the hassel of paying online, packing up my old plenum, shipping it off and then waiting for the refund.
Thanks!
Old May 4, 2006 | 01:36 PM
  #497
pingbling23
So if you were to pick a setup wich one would it be, mrev 2, 5/16 spacer, or mrev 2 with 5/16 spacer. I want to buy this but im not sure if its worth the time and money.
Old May 4, 2006 | 01:42 PM
  #498
Mazinger Z's Avatar
Mazinger Z
I'm wondering the same thing...don't leave us Rev-ups w/ no answers...c'mon tony, you've got a rev-up too! Let us know!
Old May 4, 2006 | 02:25 PM
  #499
amG35's Avatar
amG35
anyone have trouble with the Paypal method of payment? Thanks.
Old May 4, 2006 | 02:26 PM
  #500
Road Warrior's Avatar
Road Warrior
i think your looking at the wrong pic...the mrev is the pic to the right...the other two are dyi
