MREV+ Dyno Tested On The 287 HP Engine!
Old May 4, 2006 | 05:36 PM
  #521
ATL_Red_G35's Avatar
ATL_Red_G35
Tony, you have PM
Old May 4, 2006 | 05:37 PM
  #522
wren57's Avatar
wren57
Originally Posted by Hydrazine
WREN57,
What you have attached on the third picture to the right is not an MREV of any kind.
That's alberts (EK's) collector. You can see his pictures posted here.
https://my350z.com/forum/engine-drivetrain-and-forced-induction-diy/187392-diy-plenum-porting-3.html
So you used a picture of someone else's work on your website? Hmm... well, ethics of that aside, the real issue of this whole thing is this;
Is the manifold I have the Motordyne MMP 287 manifold and will it perform according to all positive dyno charts that have been posted of it?
Old May 4, 2006 | 05:42 PM
  #523
godmans's Avatar
godmans
Default Problem: did NOT get the discounted price on MREV-2
Hi Tony,
I have pm-ed you on this: I entered the discounted code: "Hydrazine" with my order but just discovered from the shipping confirmation that the order price stays the same: $446.00 + the huge $90.61 for shipping...
please do help me out to get back the difference and let me know if there is any problem with the system...
Cheers
P.S. I am #102..
  #524
ATL_Red_G35
I just checked, if you click on the picture of the website, it's the same as yours.
Old May 4, 2006 | 05:49 PM
  #525
Hydrazine's Avatar
Hydrazine
MOTORDYNE-MY350Z SPONSOR
Thoes pictures were taken during an important independant dyno event with the intent of being used by Motordyne. Ask Albert (EK) yourself.
If you purchased the lower collector from StarcraftBW, you have some prior version of MREV+... not an MREV2.
Old May 4, 2006 | 05:51 PM
  #526
Hydrazine's Avatar
Hydrazine
Originally Posted by godmans
Hi Tony,
Cheers
P.S. I am #102..
Try entering "hydrazine".
But you won't need to, I can adjust your invoice from here.
What is your shipping location?
Old May 4, 2006 | 05:52 PM
  #527
brigz's Avatar
brigz
Whats the discount with the mrev++ I have a rev-up engine and im possibly thinking about dynoing this with and w/o a spacer.
Old May 4, 2006 | 05:56 PM
  #528
godmans's Avatar
godmans
my shipping location is Canada, Toronto
For the details, I will pm you =)
Thanks Tony, I was quite upset when I saw the shippment confirmation saying: $446.00; I was like oops.. am I not entitled to a discount?
I guess it is probably the uppercase and lowercase problem, cause I entered "Hydrazine" as opposed to "hydrazine"
P.S. just sent you a pm with all my details... I understand that you have too many pms to check and reply all of them
Old May 4, 2006 | 05:57 PM
  #529
six3mike's Avatar
six3mike
Hi Tony,
Cheers
P.S. I am #102..
WOW. I'm in NY and my shipping was under $15.00. Cant be right.
  #530
Hydrazine's Avatar
Hydrazine
MREV-2 is $344 after the "hydrazine" discount.
If you can do the install on the dyno and post your results here, you will get an additional $100 rebate.
Old May 4, 2006 | 06:00 PM
  #531
Hydrazine's Avatar
Hydrazine
I'll adjust your charges to the sale price.
And yes, the shipping to Canada has always been high.
Old May 4, 2006 | 06:02 PM
  #532
Hydrazine's Avatar
Hydrazine
Hey guys,
I have to break away from the internet for a few hours. I will get to all of your posts and PM's!
Tony
Old May 4, 2006 | 06:03 PM
  #533
godmans's Avatar
godmans
Thanks Tony
I will confirm with you when I see the bill on my credit card
Old May 4, 2006 | 06:05 PM
  #534
gooleung's Avatar
gooleung
My location is also toronto, Canada. I did get the discount price by enter the code but is the shipping cost really $90.61??? Seems little high for me.
Please let me know.
Thanks
Matt
Old May 4, 2006 | 06:12 PM
  #535
MustGoFastR's Avatar
MustGoFastR
How long is the discount good for? Hoping someone will dyno the MREV-2 with a Crawford plenum soon; waiting to see that before I decide to buy...
Old May 4, 2006 | 06:15 PM
  #536
godmans's Avatar
godmans
It is probably the way they calculate..
FYI: the shipping cost of a 18lbs coupe middy (that used a freaking large box..you know how talk that freaking thing is) was around US$50 from NorCal to Toronto..
but well
Old May 4, 2006 | 07:35 PM
  #537
Mr_pharmD's Avatar
Mr_pharmD
did u have to pay tax?
Old May 4, 2006 | 08:08 PM
  #538
Hydrazine's Avatar
Hydrazine
but well
FYI the shipping charges are calculated by a direct link to FedEx.
We don't make a single cent off shipping.
Old May 4, 2006 | 08:12 PM
  #539
Hydrazine's Avatar
Hydrazine
Back to crunching down the number of PM's.
I recieved a good question from PharmD.
[quote=Mr_pharmD][quote=Hydrazine]
Originally Posted by Mr_pharmD
great, ill be sure to post up the pre/after dyno results.
Also, does it make a big difference of turning on the AC before each dyno runs compared to not running the AC before hand? I have seen many dyno runs and this is the first I ever heard of running the AC, maybe running the heater after each run to let out the heat from the engine bay.
The AC is used to simply turn on the radiator fans.
The purpose is to pump out a lot of heat and reduce coolant temps. The radiator fans are much more effective at reducing coolant temps than the cabin heater.
Use a OBDII scanner to regulate coolant temps to 190'F before each pull.
Old May 4, 2006 | 08:13 PM
  #540
Hydrazine's Avatar
Hydrazine
Only if you are in Ca.
