HELP! plenum spacer install problem
ok so i did the motordyne 5/16 plenum spacer install yesterday and everything went really smooth... yesterday the car ran fine and i was very happy...today i start it up and it sounds good again...im driving and i put it in neutral from 4th gear and the car just dies...anyone know what could be the problem...i just started it back up and it worked fine for a while but it did it again at a stop light after i put it in neutral and i had to start it back up again...ive been driving it some more and it hasnt done it but i am starting to notice a little lag or something mid range in 2nd gear...anyt thoughts on that either....thats not such a big deal as it is slight...my only concern tho...what (if anything) are you supposed to take out of your engine and not put back in when you are done installing... i have the small piece that i replaced with the aramid gasket or whatever...but i left the little black plenum thing that goes right under the spacer...thanks for any input
Originally Posted by 99atlantic
sounds a lot like the old nismo cai issue.
edit* didn't read your mod list. Could be a similar issue as the popcharger though.
check for any leaks, but this is not a typical sympton of plenum spacer but that of CAI ... as other people have already stated =)
Good luck with taking it apart and check for leaks and put it back together
StillAlive,
Your description really does sound like a classic CAI related symptom. I had the same thing happen to me when I installed the Stillen CAI.
As an experiment, try putting on your stock air tube and air box to see if that changes anything.
Originally Posted by StillAlive2029
lol im not gonna just not do the one thing that messes it up...i dont ever want it to mess up
You could try raising idle rpm. Either get dealer to do it for you, or drill a hole in your throttle lol
thread: https://my350z.com/forum/intake-exhaust/184506-drilled-hole-in-throttle-plate-uh-oh.html
