MREV V2 Independent Dyno Tested on Bone Stock 287HP Motor (Wired 24/7's 05 Touring)
Old Sep 12, 2006 | 10:30 AM
  #241
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
If you're planning to get a tune that sounds good road warrior.
I personally don't see why crawford plenum should perform much better than a simple spacer. Both mods do the same thing, increase plenum volume.
If you check out my thread on my results with cipher, you can see I still need some tuning. After 4 months the stock ECU just can't adjust to where it should be, clearly the stock ECU is not meant for max power, it is meant for economy.
https://my350z.com/forum/engine-and-drivetrain/215703-my-progress-with-cipher-charts-included.html
The fact that the car still seems to be pulling strong gives me a good indication that there is plenty of power to be unlocked with tuning.
Old Sep 12, 2006 | 11:04 AM
  #242
Road Warrior's Avatar
Road Warrior
https://my350z.com/forum/showthread.php?t=215703
i know i need a tune for sure...but i am considering swapping out my crawford with the spacer...hence my aforementioned question. would there be any benefit, or disadvantage in changing these out as far as performance goes?
i am getting the mrev 2 for sure....this seems to be worth the money imo but i also want the best combo to go with
thanks for the info
Old Sep 12, 2006 | 11:25 AM
  #243
Hydrazine's Avatar
Hydrazine
MOTORDYNE-MY350Z SPONSOR
The plenum and spacer will all perform similarly but there will be some amount of difference.
In fact, you can see how they compare on the 287 engine by seeing the dyno plots from the Sport Z Magazine Plenum Mod Shoot Out.
I also compared the spacers in a similar manner and found the same results.
The 5/16" spacer makes a lower peak power but a higher average power than the 1/2" spacer when used with the MREV.
You can expect to see very similar gains between a 1/2" spacer and a cast plenum.
Click on the "shootout" link below to see how they compare.
Old Sep 12, 2006 | 01:06 PM
  #244
Road Warrior
can you hook me up on an mrev2...please pm...money burning hole in my pocket
Old Sep 12, 2006 | 01:36 PM
  #245
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
yeah just keep the crawford plenum then, you paid money for it, no need to replace it.
Old Sep 12, 2006 | 02:10 PM
  #246
Road Warrior
hey wired, how do you like the spacer?
were you able to keep the stock strut?
also, did you get the thermal or just spacer and how much?
i know....too many damn questions...but hey, thats what forums are for
Old Sep 12, 2006 | 02:12 PM
  #247
Road Warrior
the bottom line here guys,
is having the spacer better than having my crawford?
lets take into consideration a full tune and the addition of the mrev2 in my particular case and strictly speaking performance.
thanks for the responses
Old Sep 12, 2006 | 05:21 PM
  #248
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
I'll let you know how I like it after the tune.
Yes this kit included the iso-thermal gasket. For pricing, check out MD's website or mynismo.com
no, unless you want to keep the stock strut bar instead of using crawford's.
no offense but you should be able to find the answer to this one on your own. It should be listed on MD's website. Hint: the answer is yes
Old Sep 13, 2006 | 06:26 AM
  #249
Road Warrior
thanks for the info wired...just getting lazy...and i hate myself for it
Old Sep 13, 2006 | 12:38 PM
  #250
ACEMAN's Avatar
ACEMAN
Master
I think you made a wise choice in keeping the Crawford Plenum. There is really no difference between the two. But if you still want to sell it, give me first dibs
Later
Aceman
Old Sep 13, 2006 | 01:00 PM
  #251
Road Warrior
Later
Aceman
you put 2 and 2 together my man...if i do decide you were the first on my list anyways.
i am going to get the mrev2 and keep my crawford, and then giver a tune and see what happens...then i will decide...but for now i am going to hold on to it.
thanks for your interest
Old Sep 13, 2006 | 01:13 PM
  #252
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
If you're planning any other mods, such as cats, test pipes, headers, exhaust, or aftermarket intake, I would wait to install those before tuning.
Old Sep 13, 2006 | 01:17 PM
  #253
Road Warrior
they're already done...i am ready to tune at this point
Old Sep 13, 2006 | 01:37 PM
  #254
ACEMAN's Avatar
ACEMAN
Master
Hmmm, did it have anything to do with me saying i would buy it
You know i need a new plenum ever since i got rid of the wonderful SSV plenum
Later
Aceman
Old Sep 13, 2006 | 01:38 PM
  #255
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Old Oct 16, 2006 | 12:29 PM
  #256
Road Warrior
ok...reviving from the dead.
i now have the mrev2 + crawford plenum with stock 06 intake and a utec tune. i will be going to the dyno soon for results.
my mods were CDA intake and crawford plenum with utec tune on my last dyno.
i am hoping for some better results this time!
pop charger on stand bye
Old Oct 16, 2006 | 02:21 PM
  #257
lb's vq35's Avatar
lb's vq35
wow i need to get myself a mrev2 already have the motodyn 5/16spacer
Old Oct 16, 2006 | 03:27 PM
  #258
ZLadie2000's Avatar
ZLadie2000
When are you going to dyno it? Cant wait to see the results! Also, you going to do a dyno with stock intake and then add the popcharger and see if there is a change? That would be interesting!
Did you tune it already? If so did you notice a performance difference on the butt dyno? Do you have a nonrevup?
Sorry for all the questions but I am getting ready to buy the MRev2 and thinking about the spacer too, but am interested in what kind of difference I'll see with the added spacer and a UTEC tune . Since your Crawford plenum is kinda like the spacer it will be interesting to see the results!
Old Oct 17, 2006 | 06:51 AM
  #259
Road Warrior
well i do feel a difference to be honest...but that could be attributed to the tune also. i was still dialing in my tune before the mrev2 and now i am very close to being done with it installed. i do have the non revup btw
i guess the dyno will tell the story.
as far as the pop charger...i am still enjoying my stock air box right now. i would be real curious too if the pop charger made more hp...it is a wait and see right now. i don't have the cash to keep getting on the dyno.
Old Oct 17, 2006 | 09:13 AM
  #260
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
I think the pop charger is only useful when the car is in motion. When the car is sitting still like on a dyno, it's hugely susceptible to heat soak.
Higher intake temps will lower HP on a dyno. Most likely if you start with a cold stock airbox, do a dyno run,... then switch to popcharger, let everything cool down, and do another dyno run, you will see better HP.
But if you do a few dyno runs back to back, as the whole engine bay heat soaks the popcharger will probably lose power.
My $0.02
