plenum spacer question
Old May 10, 2006 | 11:04 AM
ncy's Avatar
ncy
Default plenum spacer question
hey guys, i'm just wondering what you think of the AAM plenum spacer? i'm thinking about getting one, but there's a couple on the market and i've done the research, both here and other related forums, so i'm just gonna ask straight up, what do you think is better and why? your help would be really good. thanks
Old May 10, 2006 | 11:06 AM
HarvesterUT's Avatar
HarvesterUT
well......i think the Motordyne kit is the best solution for the intake side of things.
Old May 10, 2006 | 12:25 PM
Dubai's Avatar
Dubai
+1 for AAM spacer
Old May 10, 2006 | 12:28 PM
steela2110's Avatar
steela2110
Had the aam spacer... great mod + easy as hell to install!
Old May 10, 2006 | 02:08 PM
DavesZ#3's Avatar
DavesZ#3
The "usual" Motordyne spacer is 5/16" which allows the stock strutbar to work with no problem.
I have the AAM spacer, it will require you to put washers (provided) under the strut bar to raise it so the plenum fits under it.
Old May 10, 2006 | 03:12 PM
ncy's Avatar
ncy
keep it coming>>> are there any forseeable problems?
Old May 10, 2006 | 04:08 PM
ChazzReinhold's Avatar
ChazzReinhold
i bought the skunk2 yesterday cuz i got a sweet deal on it, no strut bar now. It gave me a reason to buy a nicer 1
Old May 10, 2006 | 04:43 PM
Question
And the results of the Sport Z magazine plenum vs plenum spacer shoot-out were?
Old May 10, 2006 | 05:41 PM
ncy's Avatar
ncy
hey david, i've never heard of or seen the sport z magazine up here in calgary. i went to the website and it looks like i'd have to order it. and it looks as though there are not retailers here, so no matter what i would have missed out on that particular article. but thank you for pointing that out. anyways, if you would be so kind to share with me the result of that test that would be great. thanks
Old May 10, 2006 | 05:48 PM
350Zenophile's Avatar
350Zenophile
https://my350z.com/forum/showthread....cer+comparison
This is old, but now there is no reason not to go MD. Everything is easier about the install with no chance of rubbing the strut tower.
Old May 10, 2006 | 06:01 PM
ncy's Avatar
ncy
zedophile, that was a damn good review, thanks, that was really helpful. you should be a writer for those car mags. thanks again
Old May 10, 2006 | 06:14 PM
350Zenophile
Thumbs up
Thanks bud, I toy with the notion every once in a while.
Old May 11, 2006 | 06:55 AM
350Zenophile
Originally Posted by William@Altered
well, personally speaking - when I install the plenum spacer - i have to adjust the strutbar from the adjustment bolts n the left side of the strutbar - did you do this in your initial review?
Yes, lots of tweaking...it just turned out my clearances were tighter than most:
Originally Posted by 350Zenophile
Following AAM’s instructions, I initially tried two washers on either side and had vibration issues when the engine would come into contact with the STB. After adding additional washers to the driver’s side and increasing tension to bow the STB upwards, I was still experiencing vibration. More so when the car was hot, the A/C was on and when turning left. I was at the limit for hood clearance at that point and accepted the fact that build tolerances vary from car-to-car and I had one of those cars. This is an unlivable circumstance which can be resolved a number of ways, mine being the decision to use the ME unit which maintains a large amount of clearance on the first try with zero vibration tinkering.
Old May 11, 2006 | 08:08 AM
g_torphins's Avatar
g_torphins
I didn't have to add any washers under either side of the strut brace. Just tightened it up and had enough clearance!
Old May 16, 2006 | 12:55 PM
omernazeer84's Avatar
omernazeer84
does any thread have a picture of the actual spacers?...sorry just got interested in the plenum spacer, keep comin up empty.
Old May 16, 2006 | 12:57 PM
omernazeer84
nevermind, found it.
Old May 17, 2006 | 12:21 AM
New2350's Avatar
New2350
Would this be good to install if you plan on a S/C in the future or is it a waste? Thanks guys.
Old May 17, 2006 | 07:45 AM
Hydrazine's Avatar
Hydrazine
MOTORDYNE-MY350Z SPONSOR
They are good to go with FI.
If FI adds 50% more HP to your engine, you can expect to see approximatly 50% more gains from a plenum spacer.
So far the MD plenums spacers are being used at up to 22 PSI boost @ 700+ HP.
They are good to go FI!
