View Poll Results: Which one will give me the best price/performance?
Espelir
1.39%
Injen
19.44%
HKS
40
55.56%
None of those, I recommend (please post below)
17
23.61%
Voters: 72. You may not vote on this poll
Help me decide between 3 TD systems.
I can't make a decision on which of these three systems to get. I have a Power Enterprise TT kit, and am currently running Kinetix HF cats and NISMO exhaust. When I make the exhaust change I will be using resonated test pipes. Prices are the best I could find so far. I'm no turbo expert, so any EDUCATED advice on diameter, restriction, X or H pipes and how they will affect my relatively small turbos is very welcome. I am runing around 400 rwp on 9 psi.
The three I am looking at are the:
Espelir JGT 500 (Pic1)
PRO:
Price ($899 shipped)
Good reviews
No known fitment issues, in fact, looks
like it gives the most clearance of the three from installed pictures.
GOOD OR BAD? Removable silencers
CON:
No H or X pipe
Smaller diameter pipes (50mm)
Injen Titanium Tip Track Edition True Dual (SES 1986TT) (pic 2)
PRO:
Somewhat of a copy of the HKS
Price ($995 shipped)
60 MM pipes
H pipe
Titanium tip (100 mm)
CON:
Haven't heard any sound clips or reviews
Some bad reviews of the previous (SES 1985C)
Unknown fitment
HKS Dual Hi-Power Ti Exhaust (Pic 3)
PRO:
Titanium Adjustable tip (120 mm)
Many good reviews
Quiet at low rpms
60mm piping
CON:
Price ($1299 shipped)
Some bad reviews on fitment (knocking againts differential)
Price.
Thanks for your input
PRO:
Good reviews
CON:
No H or X pipe
PRO:
60 MM pipes
H pipe
CON:
Unknown fitment
PRO:
Many good reviews
Quiet at low rpms
60mm piping
CON:
Price.
Group Buy going on now!!!
Threads located at:
https://my350z.com/forum/intake-exhaust/180725-i-was-the-test-car-and-wow-good-news.html
https://my350z.com/forum/vendor-group-buys-115/
http://g35driver.com/forums/showthread.php?t=91857
And the website at:
http://www.fastintentions.com
Threads located at:
And the website at:
The Espilir is a copy of the Injen, and both have piping too small for turbo.
HKS is good, but i think it sounds a little ricey (flame awayyyy)
You can check out APS (should've bought it when you had the chance :-p )
Aps is 2.5TD, good fitment and its pretty quiet but it has a unique tone in the 350z world..
SVRTech 2.5' TD is great, since itll give you quite a torque boost in the midrange, up to 70 torque as i saw in 1 independant dyno, as well as a nice HP boost. It has an X pipe, so the resonated TP will be of no use, actually you WONT need TP's because it comes with test pipes. It'll also nvr drone because of the X pipe. Check out the 3' TD if you want more power (or lower boost)
Flex pipe? The exhaust is held on by rubber, it'll flex enough. If anything, the injen and espilir are way too small in diameter, even tho the PE turbos are tiney
edit: The look of the muffler? You ricer :-p
2nd: I voted for HKS without looking at the actual thread (oops!) i would rechange my vote to other because all of the exhaust systems you listed are too small diamater wise for a turbo set up.
Originally Posted by AParshall04
Dude an x-pipe has nothing to do with a test pipe, they are in completely different areas of the exhaust system. Also i had test pipes on my 2.5" true dual with hks carbon/ti mufflers and it DRONED and rasped like crazy. I have HFCs now and it still drones a little but no rasp.
edit - i also hear that the greddy evo2 is a good exhaust for fi. the performance shop owner here on maui has a boosted g35 and is running the evo2. i saw a comparison when my evo2 was getting installed next to the injen and WOW what a difference. it was coming off of a Z that got a custom 3in. exhaust.
I switched out the Kinetix HF cats for Tpros resonated TPs. The sound level is the same, not louder, less restriction, slightly different sound. Perhaps somewhat more "gurggling" on decel.
Originally Posted by dkmaxitus
i second that. was kinda misleading title. just get a custom 3 in. one.
I've heard good things about this one from SVRT..
https://my350z.com/forum/intake-exhaust/182659-svrtech-2-5-dual-exhaust.html
https://my350z.com/forum/intake-exhaust/189030-my-attempt-at-svrtechnologies-3-exhaust-sound-clips.html
Guest
Posts: n/a
I recomemmend our true dual exhaust systems -
http://www.alteredatmosphere.com/mm5..._Code=350Z_EXH
I had some fitment issues with my HKS, the shop that installed it for me said that they had to bend the pipes atleast 1" on each side to get it to clear the diff (though it still rubbs and needs further tweaking).
The sound is amazing though, VERY exotic (even more then i was hoping for)!
/Roger
/Roger
Just as an update, the HKS and the Injen Ti are 2.37" diameter, the Espelir 1.97". Looks like all of them will be somewhat restrictive, I would think 2.5" minimum is what I need. The Espelir is eliminated for sure.
I just put the APS 2.5" TD on yesterday. I installed it myself along with my brother. I'm going F/I next saturday (have everything just need to be installed) and I hear wonderful things about this exhaust as well as other APS products. Actually I've never heard 1 complaint about APS exhausts in general, only postive remarks. Fitment was excellant, the only issue we had was we had to loosen the strut bar in the rear to get the pipe over, then tighten back up. Install time on the lift didn't take more than 45 minutes max. It sounds nice right at startup, quite at low rpms but exotic at higher rpms. Its pricey (1290+shipping or tax if u buy it in state), but i think its worth it. If you would like sound clips of it on N/A or F/I, i can do both, as i wont have my vortech sc on for another week. Just let me know. Good luck man.
msrp is 1895 and shipping cost about $100-120
Seems ya just cant get a Ti tipped exhaust for FI without cutting out a kidney
