Kinteix v+ plenum installed
Old Jul 6, 2006 | 08:16 AM
Changvi's Avatar
Changvi
Default Kinteix v+ plenum installed
Just finished installing Kinetix v+ plenum. I definitely noticed an immediate engine growl from the plenum due to more air going in. WOT for about half a mile and defintely noticed a difference, but not much. I have Apex S-AFC set at -8 percent. I know that with the plenum the engine tends to lean out a bit. Where should i set my SAFC at to run at an optimum with the plenum? Thanks..
Old Jul 6, 2006 | 08:25 AM
350Zteve's Avatar
350Zteve
You need a wide band O2 meter to tell you what setting are best. That and some time on the dyno
Old Jul 6, 2006 | 11:43 AM
Changvi's Avatar
Changvi
Just adjusted the AFC to -3 all across the board. It actually ran so much better. Much better pull.
Old Jul 6, 2006 | 12:58 PM
Bubble's Avatar
Bubble
-REPLICA ARMY-
Originally Posted by Changvi
Much better pull.
= more gas?
Old Jul 6, 2006 | 05:49 PM
Changvi's Avatar
Changvi
No, i don't think it eats more gas s long as i adjust the ratio correctly. Since its running a bit leaner than before, i had to richen bit. Interested in getting rid of your Nismo cold air v2?
Old Jul 6, 2006 | 05:58 PM
Bubble's Avatar
Bubble
-REPLICA ARMY-
then what i'm going to use man? hehe
Old Jul 6, 2006 | 06:10 PM
techcontrol's Avatar
techcontrol
You could just get CIPHER and monitor the Widebands (05-06) with data-logging. From what I've done with CIPHER thus far it appears to be a much more useful tuning tool than stand-alone widebands.
Old Jul 6, 2006 | 08:11 PM
Changvi's Avatar
Changvi
I will trade you with my pop charger...hehehe
Old Jul 6, 2006 | 08:12 PM
Changvi's Avatar
Changvi
Where can i get my hands on Cypher?
Old Jul 6, 2006 | 08:15 PM
FrickU's Avatar
FrickU
Altered Atmosphere
Old Jul 8, 2006 | 11:46 AM
UpRev's Avatar
UpRev
Only 2004.5+ Nissans come w/ WB, so keep that in mind.
03 and early 04 are out of luck
-Jared.
Nismo350Z_00
Jul 16, 2011 07:43 PM
Redfoot
Jul 31, 2007 09:09 AM
edwin350z
Tuning
Jul 28, 2006 03:47 PM
timdawg
Apr 1, 2005 01:29 PM
